Disgusting metal on metal sound shortly after shutting off engine
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Does anyone else have this issue? I took a video after immediately turning off the engine. The worst sound starts about 2 minutes after turning off the engine. It sounds like someone is pulling a nail through a rusty can. Absolute nails on a chalkboard noise, truly disgusting to hear.
Anyone else have this? Is it related to the ac chirp? wtf?
Cabby30
CA
2024 DCLB TRD OR
Maybe a loose heat shield scraping on a bolt as it cools / shrinks. Sounds terrible haha
I just want to know if you live next to a swamp? Frogs? Gators?
395North
TRD PreRunner
CA
2025 TRD PreRunner
Contracting metal somewhere. Stock exhaust?
RutsyBucket
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
I am not getting the same visceral reaction as you lol
It’s really bad in person, or maybe I’m just really sensitive to nails on chalkboard / grill scouring noises.
Running the Toyota trail dump exhaust
Carlsbad… a few miles from the ocean. Regularly by the beach.
395North
TRD PreRunner
CA
2025 TRD PreRunner
dumb question but did you tighten the bolts down real good?
RutsyBucket
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
not dumb. I did torque them down pretty well, but I never redid it. I’ll give that a shot in the morning and see if it helps.
Will721
Will
Quad Cities
2025 TRD OR
Sounds like metal contraction. Perfectly normal, my trucks only done it once since I've owned it. But I did buy in October so only a few days have actually been warm.
It's especially common in motorcycles and turbo engines. Even more so if there's a highway right before shut down. If you know of a bar or hangout where harley riders tend to congregate you can hang out and listen to the bikes after they shut down and compare the noise.
Longpatterned
Tim
New Orleans, LA
Toyota Tacoma 4x4 SR5 Double Cab Long Bed
Mine “farts” about two minutes after shut down. I think it’s part of the evaporative fuel system….
lpsoldia311
Chief
North Carolina
25 Tacoma Limited, 16 4Runner Trail
All of those sounds aside from the big one at the end are pretty normal. It still sounds like a metal cooling but something is binding up a little more and then popping / releasing after relaxing from the thermal expansion. I'd check all your normal bolting connections at the exhaust points for looseness and all heat shields. If it's pretty reliably doing this after every run I'd take it to the dealership to get noted and see if it's an easy fix, but if it looks like they're just wasting time and not really doing anything about it then I'd grab a roller creeper and use my automotive stethoscope to narrow down the area is coming from and go from there.
RutsyBucket
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Totally, I want to be clear that I’m only talking about the sound at 00:57, the rest all sounds very normal.
I’m gonna crawl under there and poke around in a bit.
RutsyBucket
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Well, update here. I recently had new shocks and rear springs installed. The rear was quite saggy due to topper weight / extra weight on stock springs. I asked them to take a look around the exhaust heat shields to see if anything was extremely close.
After the taller springs and shocks were installed, I haven't heard this once. I didn't ask them if they looked and fixed anything while they were in there, or if the extra clearance was all that was needed, but thankfully, that nasty af sound is a thing of the past.
