Duce95
Big Deezy
2024 TRD Off-Road Premium
I know https://dongar.tech/ makes a solution but I wanted to make my own for less because I’m cool like that….
While I was waiting for my truck to arrive at the dealer, started doing some research. I wanted to find a dash cam hardwire solution. I found the new 4th GEN trucks are pre-wired with a pigtail to connect the OEM dash cam sold as an option for $500.
I ordered one part from AliExpress and another from Amazon.
I successfully hardwired my Viofo dash cam. Came out super clean.
2024 Tacoma Installed dash cam using factory pigtail connector IMG_3688
Dongar
Norcal
Haha right on, man! I would've done the same thing. FYI lets connect in a month or so... I have a new parking mode adapter with 100% custom buck converter designed by our new engineers in Europe (not a generic OTS converter)... low voltage protection, and timers. Would love to send you one for field testing. Can't reveal the final product & enclosure yet because we're still filing patents. Check out a demo here:
Drakka01
Scott
I'd be excited to test this for you as well. My Regtiger is currently wired with your 5 pin connector. Would love one that plugs in up there somewhere with parking mode functionality.
Dongar
Norcal
you got it! :cool: . I'll post renders sometime this week and reach out when we get the new revisions in. I'll be honest that our current adapter left a lot of room for improvement... it uses an off-the-shelf USB module that's basically found in generic car chargers and this new one is significantly more intelligent in terms of power control, has a USB-C port and allows up to 12V now, etc. The parking mode and low-voltage protection alone will be a game changer!
Also FYI, there's a second 10-pin port powering the mirror with both constant and ignition-switched lines. You could hypothetically run a second camera (rear cam) to this port if you wanted. In my video, that's the 10-pin Type B adapter on the left.
Drakka01
Scott
I was aware of the 10-pin but I was a little unclear on requirements there as I saw some things stating they didn't work with it if you have the digital mirror and others saying it was part of the safety system wiring so best to avoid tapping into it. In any case, my Redtiger has the rear camera as part of the kit and it plugs into the main camera via what looks like a fairly standard 1/8" stereo jack for both power to it and video feed from it. It's actually a pretty clean little setup.
2024 Tacoma Installed dash cam using factory pigtail connector 20240415_162438
Kielly
2024 Tacoma Sport+ 6M
Genius! I never would've thought of looking but I'm glad someone did their research. Still got to get around to installing mine highly glad I seen this.
Tekoma
Michael
North Carolina
I am very interested! I’m ready to install my Garmin Mini dash cam and really want to tap in without routing the parking mode harness all the way to the fuse box (or tapping in elsewhere). Is there a way to get on a waitlist?
Pootklopp
Usa
2024 Bronze Oxide TRD OR
Do you all have any products to connect radar detector native RJ11 cords?
Dongar
Norcal
For our current product line, this works just fine in conjunction with our dashcam adapters: https://www.stickerfab.com/products...ne-uniden-radar-detector-power-cord-universal
For our upcoming USB-C products, you could use one of these: https://www.stickerfab.com/products...r-power-cord-universal?variant=44323500458303
I'd say though that since you have two ideal connectors both already at 12V (the 5-pin connector dashcam harness in the domelight, and the 10-pin autodimming mirror connector under the rearview mirror plastic shroud) it would probably be a quick DIY project to use a product from mirrortap or one of the many clones on Amazon. Their stuff has friction-fit pins that slip into the back of the connectors.
I'm somewhat a fan of the stuff from Radenso which performs well for $350: https://www.vortexradar.com/2021/08/radenso-ds1-initial-test-results/
Here it is running off a USB-A to USB-C cable + dongar dashcam adapter, powered from my autodimming mirror:
2024 Tacoma Installed dash cam using factory pigtail connector 1713417612629
Pootklopp
Usa
I figured a 10 pin to USB would be the way to go. I am coming from a Jeep wrangler so max range is not the most important to me. Hard to speed that much in a brick. I have a stealth installed V1 running JBV1 to my mounted cell phone. Android Auto is running my navigation and music with my phone screen showing all radar info provided by the JBV1 app. It's an amazing setup that I hope I can bring over in some way to the Taco. Most importantly I can leave the roof off on the Jeep with no worry of someone finding the V1.
Senrusho
Sam
2024 Tacoma Off-Road
When will this be available? Trying to decide if I can wait a little bit or if I should just grab the non parking mode one you have available now.
Dongar
Norcal
Unfortunately at least another 2mo from now... we're working very carefully on electrical design and our extremely engineer wants to swap out some components and increase the amount of copper in the pcb for heat performance at really high limits.
Either of our 10-pin Type B or 5-pin Type A adapters will work for you in the meantime.. and I can send you a pre-production unit of the new adapter when available.
Senrusho
Sam
Alright cool. I'll order one of those. And yes, I would love to help test one of the new ones when they are available. Should I PM you?
Dongar
Norcal
Yeah, PM your email address and shipping address and we'll figure something out.
Dongar
Norcal
How to access the OEM dashcam connector in all 2024+ Tacoma:
Please note this video features our parking mode adapter & 5-pin pigtail which isn't due for release until around late July. These install steps are still roughly the same for this in-stock product: https://dongar.tech/products/toyota5pin
