5w-30
BLtheP
TX
Let’s be cognizant on understanding oil grades.
0W20
5W20
both are same weight at operating temperature. At cold one is slightly thicker. Tight tolerances, thinner oil is best at start up, especially in areas that have cooler weather.
5W30
10W30
at start up, the 5W30, is the same as a 5W20, and it being slightly thicker at operating temperature. 10W30, slightly thicker yer at cold, operating temp, same as 5W30.
here’s the thing, Toyota has decided 0W20 is best in most cases except Mexico, which makes sense, want to run 5W20, sure go ahead, little thicker at start up, operating temp, it’s the same,
in the end. Everyone making a big hoo haw out of the difference between a W20 and a W30 doesn’t amount to a whole hill of beans, the cold rating, isn’t where we concern ourselves with wear on the life of an engine, wear (over the life of an engine) occurs where most of the engine running happens - at operating temperature. with such a little difference in the rating, the whole conversation is just sensationalized, use the oil recommended, if you are concerned about longevity, double down on oil change frequency plain and simple.
You’re explaining basic multigrade oil concepts as if anyone here was confused about them. Nobody was. I understand perfectly well what the W rating means and how viscosity behaves at operating temperature. That wasn’t the point of the discussion.
The point was that people constantly claim engines require 0W-20 because of “tight tolerances,” which simply doesn’t hold up when you actually look at the service specs. Engines that recommend everything from 0W-20 to 20W-50 often have nearly identical bearing clearances. I already pointed out several examples of this, and none of that was addressed in your reply.
Instead you pivoted to explaining that 0W-20 and 5W-20 behave similarly at operating temperature. Ironically, that actually reinforces my point. If the viscosity difference is small enough that it “doesn’t amount to a hill of beans,” then it certainly isn’t something that would suddenly make an engine fail if someone used a slightly thicker oil.
You also repeated the “tight tolerances need thinner oil at startup” line, which again doesn’t really make sense when you look at the actual physics. Even very thin oils become extremely thick when cold. A cold start on 0W-20 is still far thicker than that same oil at operating temperature, and often thicker than heavier oils at warmer ambient temps. Engines are designed to tolerate that entire viscosity swing every single time they start. That’s why the “tight tolerances” argument falls apart — the engine already experiences a huge viscosity range regardless of what oil you choose.
And the comment about wear mostly happening at operating temperature isn’t really accurate either. Most engine wear occurs during startup and warm-up, before the oil film is fully established. Once the engine is warm and operating in hydrodynamic lubrication, wear rates drop dramatically.
But more importantly, none of this addresses the original point I made about regional viscosity recommendations. The same exact engines are sold around the world with different oil charts, sometimes allowing everything from 0W-20 to 10W-30 or even 15W-40, and those engines are not built with different clearances depending on the country. The hardware is the same. The difference is regulatory environment and fuel economy targets.
So explaining what the numbers on the bottle mean doesn’t really move the conversation forward. The real question is why identical engines are approved for such a wide range of viscosities depending on market, and that’s something your reply didn’t touch at all.
If someone wants to run the manual’s recommended oil, that’s perfectly fine. But pretending the recommendation is purely the result of mechanical necessity rather than emissions and efficiency targets just ignores how modern regulations actually influence these decisions.
Also, no, a 5W-20 and 5W-30 will not be the same thickness when cold. Look at the centistoke ratings - the 5W-30 will almost always, if not always, be thicker.
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Another comment I'd like to throw into the ring, so to speak, is that while today's vehicles run lower tension rings for EPA nonsense, "typically" boosted vehicles have stronger rings to deal with the compression loads of boosted air pressure. With that said, I was wondering if the rings in these taco's an even the tundra are actually not low tension. I dont know the answer to that, anyhow food for thought. Perhaps some day we'll know the answer to that.
Pretty sure I saw they are low tension oil rings.
GSPHerder
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
@GPSHerder I'm using Pennzoil Ultra Platinum 5w30 in my truck (hybrid), which has so far seen operating temperatures down to -40c. There's been zero issues, and I do NOT give a shit about Toyota's warranty! NOTHING bad is going to happen to this engine by running 5w30.
My main reasons for switching are that the engine does dilute the oil during extreme cold conditions (which very quickly turns your beloved 0w20 into 0w10...however the rate of dilution has minimized with my switch to 5W30....). Second reason is that I want ultimate longevity - no compromises for a 1% fuel mileage gain or EPA emissions standards. Ford, GM, even shitty Hyundai/Kia...they all recommend 5w30 for their respective turbocharged engines. Why not 0W20 ??
I had a second gen Tundra with the 5.7L for well over 10 years, and it never got anything but 5w30....it didn't blow up, it didn't spin a bearing, didn't throw a rod, didn't burn oil, or even so much as leak a drop. And guess wutttt?!? The 3UR-FE has tighter bearing clearances than the T24A !! Riddle me that ! The supreme and strict dedication to 0W20 by the Toyota crowd needs to be formally studied and researched for mental reasons....like honestly
Exactly what Im thinking.. Like I said I'm not trying to convert anyone just wanted to know before I hit a 1k miles if anyone had any adverse affects with a 30w. thanks
(last vehicle was a power wagon and peeps swore by redline, I tried the Pennzoil PUP and was amazed at how much smoother the engine was, Gonna run the PUP 05w-30 in the Taco)
Miqie
2024 TRD Sport-Bronze oxide.
Just be aware that for the U.S. Tacoma, if you have a major engine issue under warranty, they will send the oil out for analysis. If you're running 5W-30, good luck on making your case for a new engine at Toyota's expense.
DENNISD
Dennis
Omaha
^^ The EPA has entered the chat…
That sounds more like a teenager warning their friends that their parents just got home and everyone should start behaving.
Until the laws change, the EPA will largely dictate what manufacturers can and cannot do. Whether you like it or not really doesn’t matter when it comes to your wallet. If you choose to use oil other than what the manufacturer recommends, you’re potentially putting thousands of dollars at risk.
DENNISD
Dennis
Omaha
Whenever you choose to use products or practices that differ from the manufacturer’s recommendations, you open yourself up to potential issues with future warranty claims. Those risks could result in having to cover damaged parts or repairs out of your own pocket.
BLtheP
TX
That’s the generic concern, sure. It is unlikely that anybody can actually blame anything on viscosity though because by the time the oil is tested, a 5W-30 will have sheared down to near-new 0W-20 and will be even thinner if there is any fuel dilution. In other words, there are too many outside factors to accurately blame oil viscosity as the reason for failure, upon testing it.
Put another way, what if your engine blew and they tested your 0W-20 and found its viscosity to be equivalent to 0W-8 because of shear and fuel dilution. Now they’re blaming you for running oil too thin. What then? There are too many variables. If they aren’t going to cover it, they aren’t going to cover it. 5W-30 isn’t likely to ever be the reason why they won’t cover it. They’ll come up with other reasons not to cover it first and the oil analysis reason is illogical and will never favor the customer because the oil starts changing the first time the engine runs after it’s dumped in.
And alas, a recommendation is simply that: a recommendation. It isn’t a requirement.
DENNISD
Dennis
Omaha
Tell that to their lawyers.
Have you ever heard the saying, “You can’t fight City Hall?”
While the chances of a problem may be slim, changing your oil viscosity based on what you personally think is better isn’t very wise. Doing so could risk losing coverage if something goes wrong, all for the sake of trusting your gut over the manufacturer’s recommendation.
BLtheP
TX
Maybe so for the first 60K, however I don't buy my vehicles for the warranty period. Not worried about it.
Will721
Quad Cities
I would also point out that Toyota is a business, and their business is selling trucks to make money. They don't make money on warranty claims, that is cost going out. As inexpensive as oil analysis is these days, it would not surprise me in the slightest if part of engine failure SOP is testing the oil for data logging. Especially with the issues they have been having with the Tundra engines.
DENNISD
Dennis
Omaha
More often than not, if an engine fails it will happen during the warranty period due to a defect. While that defect would most likely have nothing to do with oil viscosity, the gray area still exists.
My guess is that you would probably be fine using a thicker oil, but I still think this whole discussion is a bit silly. The life of your engine will likely outlast much of the truck anyway, so in my opinion it’s largely a moot point.
24tacoman
2024 TRD OR 6M
I use Pennzoil Ultra Platinum 0w20 and have run used oil analysis showing minimal (below average) levels of wear metals. I live where it gets to -40C regularly for 7 months of the year so a thinner oil suits my use case better. Starting an engine with 5w30 in those temperatures results in no protection from the oil at startup, as it is well below its pour point. I am at 60k and my truck does not burn a drop of oil. I change at 5000km intervals and have not noticed significant fuel dilution (UOA says less than 0.5%). Now, if I lived in the south and never experienced below freezing temperatures, I would probably switch to 5w30. It all depends on use case...
