- First Name
- Cameron
- Joined
- Apr 2, 2025
- Threads
- 22
- Messages
- 283
- Reaction score
- 407
- Location
- New Mexico
- Vehicle(s)
- 2025 Tacoma TRD OffRoad
I wanted to share a recent situation because it is a good reminder that aftermarket accessories can sometimes cause damage far beyond the accessory itself. This is not meant to call out the customer or the manufacturer of the grille lights, and I have his permission to share the story. The goal is to show Tacoma and 4Runner owners how an accessory wiring issue can lead to damage you would never expect.
The chronology
This customer’s 4Runner had previously run correctly on the completely stock calibration, a COBB calibration, and my custom calibration. There were no performance concerns with any of them.
Then, during normal driving, the truck suddenly developed poor power, a misfire, and a check-engine light. The immediate problem turned out to be a blown ignition fuse in the underhood fuse box.
After the fuse was replaced, the engine ran normally again, but the truck was noticeably down on power. It felt like the turbo was no longer producing normal boost, and it eventually set a P0420 catalyst-efficiency code.
Because this happened after the vehicle had been tuned, the customer initially suspected the calibration. He was frustrated and understandably upset.
From his perspective, the timeline was simple: the truck was tuned, something failed, and now it felt weak and had an emissions code. However, it continued to feel weak on every calibration afterward, including the stock and COBB files. That was an important clue that the issue was mechanical or electrical rather than something within my calibration.
Instead of becoming defensive, I kept asking questions and gathering details. My goal was not simply to prove that the tune was not responsible. It was to understand what had happened and help get the customer’s truck working correctly again.
The detail that uncovered the root cause
After some additional questioning, I learned that the truck had an aftermarket grille with integrated lights. Those lights had been wired using an add-a-fuse installed in the ignition-fuse slot—the exact fuse that blew.
When that fuse opened, the interruption to the ignition system allowed unburned fuel to enter an already-hot catalytic converter. That fuel burned inside the catalyst and generated enough heat to melt the internal substrate.
Once the converter melted and became restricted, the truck felt down on power regardless of which calibration was installed. That also explained the P0420 code.
Nobody installing grille lights would normally expect them to contribute to a melted catalytic converter, but that is exactly why this situation is worth sharing.
The broader lesson
Modern Toyotas have a lot of systems tied together. A wiring problem does not always stay isolated to the lights, compressor, switch panel, stereo, or other accessory being installed.
An add-a-fuse in the wrong circuit, an overloaded circuit, a poor ground, a pinched wire, or an improperly wired relay can affect engine operation and damage something that seems completely unrelated.
This does not mean owners should avoid aftermarket lighting or other accessories. It just means the wiring and choice of power source matter. Critical ignition and engine-management circuits are not good places to add accessory loads.
The outcome
The customer has now ordered a high-flow catted downpipe to replace the damaged factory catalyst. Once it is installed, I will recalibrate the vehicle for the new hardware and review the data to make sure everything is operating correctly.
Most importantly, the customer now understands what happened and is satisfied with the path forward.
This situation required considerably more diagnostic support than would normally be expected from a remote tuner, especially because the underlying failure was unrelated to the calibration. However, I continued asking questions, reviewed the evidence, and helped identify the actual root cause.
My job is not just to send a calibration file. I want the vehicle to run correctly and the customer to be happy with the end result, even when the support goes well beyond the tune itself.
Hopefully, this saves another Tacoma or 4Runner owner from learning the same lesson the expensive way.
The chronology
The broader lesson
The outcome
