A Cautionary Tale About Aftermarket Accessories—and an Expensive Unexpected Failure
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
I wanted to share a recent situation because it is a good reminder that aftermarket accessories can sometimes cause damage far beyond the accessory itself. This is not meant to call out the customer or the manufacturer of the grille lights, and I have his permission to share the story. The goal is to show Tacoma and 4Runner owners how an accessory wiring issue can lead to damage you would never expect.
The chronology
This customer’s 4Runner had previously run correctly on the completely stock calibration, a COBB calibration, and my custom calibration. There were no performance concerns with any of them.
Then, during normal driving, the truck suddenly developed poor power, a misfire, and a check-engine light. The immediate problem turned out to be a blown ignition fuse in the underhood fuse box.
After the fuse was replaced, the engine ran normally again, but the truck was noticeably down on power. It felt like the turbo was no longer producing normal boost, and it eventually set a P0420 catalyst-efficiency code.
Because this happened after the vehicle had been tuned, the customer initially suspected the calibration. He was frustrated and understandably upset.
From his perspective, the timeline was simple: the truck was tuned, something failed, and now it felt weak and had an emissions code. However, it continued to feel weak on every calibration afterward, including the stock and COBB files. That was an important clue that the issue was mechanical or electrical rather than something within my calibration.
Instead of becoming defensive, I kept asking questions and gathering details. My goal was not simply to prove that the tune was not responsible. It was to understand what had happened and help get the customer’s truck working correctly again.
The detail that uncovered the root cause
After some additional questioning, I learned that the truck had an aftermarket grille with integrated lights. Those lights had been wired using an add-a-fuse installed in the ignition-fuse slot—the exact fuse that blew.
When that fuse opened, the interruption to the ignition system allowed unburned fuel to enter an already-hot catalytic converter. That fuel burned inside the catalyst and generated enough heat to melt the internal substrate.
Once the converter melted and became restricted, the truck felt down on power regardless of which calibration was installed. That also explained the P0420 code.
Nobody installing grille lights would normally expect them to contribute to a melted catalytic converter, but that is exactly why this situation is worth sharing.
The broader lesson
Modern Toyotas have a lot of systems tied together. A wiring problem does not always stay isolated to the lights, compressor, switch panel, stereo, or other accessory being installed.
An add-a-fuse in the wrong circuit, an overloaded circuit, a poor ground, a pinched wire, or an improperly wired relay can affect engine operation and damage something that seems completely unrelated.
This does not mean owners should avoid aftermarket lighting or other accessories. It just means the wiring and choice of power source matter. Critical ignition and engine-management circuits are not good places to add accessory loads.
The outcome
The customer has now ordered a high-flow catted downpipe to replace the damaged factory catalyst. Once it is installed, I will recalibrate the vehicle for the new hardware and review the data to make sure everything is operating correctly.
Most importantly, the customer now understands what happened and is satisfied with the path forward.
This situation required considerably more diagnostic support than would normally be expected from a remote tuner, especially because the underlying failure was unrelated to the calibration. However, I continued asking questions, reviewed the evidence, and helped identify the actual root cause.
My job is not just to send a calibration file. I want the vehicle to run correctly and the customer to be happy with the end result, even when the support goes well beyond the tune itself.
Hopefully, this saves another Tacoma or 4Runner owner from learning the same lesson the expensive way.
CAMTuning
CAMTuning
Cameron
New Mexico
lmaoooooooooo
Not sure if you're agreeing or laughing but if he drove with a clogged cat long enough it could have been really bad for the engine.
TacoBirdinNW
2025 DCLB SR5
This is wild ! Thanks for sharing. I added a fuse to the Tow-ign slot which was fuse free for whatever reason for my Diode Dynamics light bar.
But man, would have never considered this!
Sner
As so goes the story of aftermarket crap, and the cost of DIY business. As a licensed automotive technician, the stories we could share. I know enough to stay away from most of that sort of stuff. I’ve seen cars where the customer decided to put a new customizable ECU in their vehicle, and adjust fuel and ignition mapping, then come in with a blown up engine. Vehicles are very complicated, even as a tech, I wouldn’t adjust fuel and ignition mapping, I have no idea, I just know parameters that’s sensors need to work within. There’s some very special engineers that create these maps at the factory. Some maps could be for emission stuff, I get it. But there’s some serious risk in any aftermarket accessories. And those fuse taps, don’t get me started - your adding an additional electrical load to a pre electrical engineered lighting circuit, with a predetermined amperage fuse for that circuit. This is basic OHMS Law, those fuse taps should just be outlawed.
CharlotteBlue
Ilya
Charlotte, NC
2024 Tacoma TRD OR Hybrid Premium
This is why I’m apprehensive of the “a-hole dealer is screwing me refusing to warranty my engine because I had aftermarket lights” stories. Doesn’t matter how unrelated two things look, a bad enough install job or cheap enough Amazon “accessory” can set off a cascade failure.
Something like this (provided the dealer did the homework like @CAMTuning did) would be a direct use (or not - however you want to see it) of the Magnuson-Moss Warranty Act.
Dealership can't just say "hey, you have those gay raptor lights, which is what is causing your issues".
They have to do the due diligence, and then they can say "hey, you have those gay raptor lights, which we traced back to the IGN fuse that blew, causing unburnt fuel to enter your cat and melt it."
daytonaviolet
Cheater Rockwell
Bay Area, CA
5th 4runner, Tesla S Plaid, Tesla X Plaid
did your truck come with aux1 - aux4 ?
Lando
Thank you for sharing @CAMTuning. This is why I’ve avoided getting a trailer brake controller (and am pissed at Toyota for a: not including it and b: not having a separate circuit or ability to easily add an aftermarket one).
Today’s vehicles aren’t the ones many of us grew up doing self installs of Alpine decks and JBL amps or Kicker subs etc. on.
Still weighing all the facts but ONE of the reasons I may trade up next year instead of running my truck for 8 - 10 years is to have a factory trailer brake.
frosty4x4
Midwest
And give up that Solar Octane? :sadface:
Lando
I know, I love the Solar Octane. It was actually my second choice, Toyota only offers Supersonic Red on the Sport premium and Limited here.
CAMTuning
CAMTuning
Cameron
New Mexico
Quick update on this 4Runner:
The owner received his FaF Race high-flow catted downpipe, installed it himself, and found visible damage to the factory catalyst during removal.
After the new downpipe was installed, we reviewed the data and made the final calibration changes for the new hardware.
It is now running and performing correctly again, and he is back to enjoying his 4Runner.
