- First Name
- Lauren
- Joined
- Aug 20, 2025
- Threads
- 5
- Messages
- 897
- Reaction score
- 800
- Location
- Ventura, CA USA
- Vehicle(s)
- 2025 Tacoma Trailhunter LB
Sharing a small change to my Trailhunter air compressor gear and want to hear what others suggest or have done.
In the OEM air compressor kit, the air hose has a screw-on connector that goes to the tire Schrader valve. It’s tedious to screw on/off…so after screwing around on Amazon, I’ve tried the following items to speed up the time to connect/disconnect from tires.
After adjusting air pressure in my truck, I did the same for our Subaru (pic attached).
https://a.co/d/0atbaaWw
Evoultes Brass Air Inflator Adapter, 1/4" NPT (M) to Standard Schrader Valve (M), Tire Inflator Connector for Auto Portable Air Compressor/Pump, Air Hose, Air Chuck (2 Packs)
JACO Lightning L2 Quick-Connect Tire Air Chuck - 1/4" F-NPT (Closed Flow)
https://a.co/d/03Wa2h8l
This is working well so far but I’m a greenhorn when it comes to air compressor fittings. Anyone have other setups to improve OEM, please post away.
