PerpetualTraveler
kathy
Florida
2024Tacoma SR
I have a 24 TRD Sport 4X4 with the towing package. I pull a 21 foot Winnebago Minnie with a leveling hitch but still had too much sag. I discovered these Timbren bump stops. Three bolt install after slightly lifting the rear end with a floor jack. Totally solved the sag issue for less than $300.00. Picture shows the difference between the factory stops and the Timbren. Timbren's ride about one inch above the axle with no weight in the bed, so it doesn't change the ride when not hauling. Highly recommend them!
2024 Tacoma Anyone brave enough to tow a camper yet? I was. IMG_2973
Gurvy522
Chicago, IL
2024 Tacoma Limited
Chicago to Moab & back last year. Similar results to others, maybe about 12-13MPG. So basically about 200 miles of range per fill. Trailer is around 4000#.
No problems up and down the Rockies either. Only scare was slightly elevated trans temps at one point during stop-and-go traffic on I70 up grade.
2024 Tacoma Anyone brave enough to tow a camper yet? I was. PXL_20240910_134746982
wlmartin86
SW Arkansas
2025 Toyota Tacoma TRD Off-Road Hybrid
I've got a Flagstaff E-Pro E19FDS on order that should be here later this month or next. I can't wait to hook it up and see how my Tacoma performs - I think it'll do great. Dry weight is around 3500 lbs.
wlmartin86
SW Arkansas
Looking forward to seeing how it does! What trim do you have?
I've got a TRD Off Road Premium with the hybrid. I've pulled a boat, lawnmower on utility trailer, and ATV on utility trailer and so far everything has done very well. I know the camper will be a different experience due to more weight and frontal area, but it should be fine. I had a 2008 4Runner with the V8 and pulled a 24' camper that was over 5K dry and had no issues so I think this will prove to be a great combo. I expect it to be ready within the next few weeks.
PerpetualTraveler
kathy
Florida
2024Tacoma SR
Nice!!! Yeah, you shouldn’t have any problems and it sounds like you’ve done your research. And, I assume you have the TBC. The only thing we’ve noticed is some ‘porpoising’ when on roads that have seams, or onto bridges. Thinking about sumo springs?? Other than that the truck tows perfectly! Just stopped at a scale and got all our weights today. Enjoy!!
wlmartin86
SW Arkansas
2024 Tacoma Anyone brave enough to tow a camper yet? I was. IMG_9628
We picked up our new camper today. The Tacoma pulled it so well. We took the scenic route home through some very hilly and curvy areas and I never felt like the truck was struggling. I am very impressed! We will go on our first trip in about a month so now the fun part of getting it set up how we want it has started.
PerpetualTraveler
kathy
Florida
2024Tacoma SR
Excellent!! Which E-Pro model. Everything looks perfectly level so good job!
wlmartin86
SW Arkansas
It’s the E19FDS model. I didn’t look at the label but it’s around 3500 lbs and 400ish tongue weight I believe. I got a Fastway E2 equalizer hitch with it and it did a great job. I’m very impressed with how the Tacoma pulled. Tow mode is beastly - I had to actively tell myself to slow down to keep it around the speed limit!
wlmartin86
SW Arkansas
We went on our first trip since picking our camper up last month. It was about an hour and a half each way through some hills and the truck did great. I need to adjust my hitch up a few holes to account for bed weight (we had firewood and some gear in it so that things are good and level, but the power was there and the brake control was great. My dad shot a little video of us hitting the highway. These trucks can tow well!
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
Picked up our R-Pod 195 last week, the truck towed it fine on the way home with a sway bar hitch. Can't wait to get it out there for real!
Camperbunga
Connie
PA
2025 tacoma TRD OR
I switched from towing with a Subaru Ascent to Toyota Tacoma TRD Off road; Starcraft Autumn Ridge 19 BH; 4000 lbs loaded. Wow, what a difference. Barely knew it was there.
