Yotota
Zane
SW WA
24 TRD
Surprised the 5100s are an upgrade from the red external resevoir bilsteins on the TRD OR. Glad to hear they are working out!
Depending on your preferences and driving style, they are or they aren't.
The 5100s will have firmer damping at ride height. The Taco TRD OR ESCV shocks firm up substantially halfway through the travel to be firmer than 5100s, with more bottoming resistance. The vast majority of people who say their TRD OR Taco "bottoms out" are actually feeling that mid travel ESCV "tap". And at least on my truck, that feeling softens once the shocks break in.
JayTech
Jay
2025 Toyota Tacoma TRD ORP
External reservoirs don't necessarily mean better dampers, they just have the potential to handle cooling of the fluid inside them better during more strenuous use. The valving internally which determines the flow rate(which in turn determines how soft or stiff they are) under both compression and rebound could be far superior on the 5100s vs the stock OR dampers. The external reservoirs on the OEM shocks just means they might be able to last longer before getting serious suspension fatigue during off roading.
828findadventure
Eric
North Carolina
2025 Toyota Tacoma SR5, 2021 Toyota Tundra SR5
Here is how I set up my 21 Tundra with 5100s. The same but not the same. I set my 5100s at the top notch for the most lift of 2.5". Since I had the tow package, the truck had an extreme rake for towing. The top notch leveled it out and looked great. Since I did haul stuff in the bed and had a topper, I needed something to keep it level when full. I went with Fire Stone Air Bags, and they did the trick. Note: I did not use blocks in the rear, just 5100s, so I needed the bags. The ride quality with OE springs will not change regardless of which notch you choose on the 5100s. If you add a stronger spring, like the Old Man Emu made for heavy bumpers, or adding a winch, you will see a ride quality difference. Just throwing some information out there.
