Does your Toyota Tri-fold block the rear camera?
CharlotteBlue
Ilya
Charlotte, NC
2024 Tacoma TRD OR Hybrid Premium
2024 TRD OR premium hybrid, bought it used. Truck came with the Toyota accessory hard trifold, opening it up all the way blocks the rear view camera feeding the rear view mirror. I assumed that was just the penalty for having a trifold but I saw a post on another forum saying they liked their trifold because it didn’t block the mirror camera. So…is mine just installed too far back?
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_6385
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_6386
rijc99
Mine doesn’t cover the camera feed. Make sure it’s folded correctly. There is some adjustment that can be made to how they’re stacked once it’s folded.
EagleTalon
OR
2025 Toyota Tacoma Off Road
It shouldn't cover the cameras, mine also doesn't. like mentioned, looks like you just need to adjust the tri-fold. Slide it a little back towards the tailgate until it clears the cameras when folded.
rijc99
Here’s an example of how the panels are folded can block the camera.
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_5654
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_5653
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_5655
2024 Tacoma Does your Toyota Tri-fold block the rear camera? IMG_5656
rijc99
Hey, so I tested my trifold again but this time using the prop rod as if I was going to drive with all panels folded. Previously I had only driven with two panels folded and tested the third open but while stationary (without prop rod).
On mine the prop when clicked in it does pull the entire set of panels away from the rear window thereby blocking the cameras. I honestly thought I drove it before and there wasn’t an issue. I did take my truck in to the dealer because my tailgate wasn’t releasing so they could have adjusted my cover rearward. It’s in the same position as yours based on your photos.
Zigity
Connecticut
2025 Tacoma TRD Sport DCLB
Mine is blocked almost exactly like your top mirror image. I’m going to see if I can adjust it the way you have it in the second position. Thanks
Planoman
DFW, Texas
same with mine. Once the prop rods are installed the camera is blocked.
CharlotteBlue
CharlotteBlue
Ilya
Charlotte, NC
I confirmed on mine, camera is only blocked when the props are in, otherwise it’s not blocked but you can’t really drive around without the props. Slid the rails as far as I could before they contacted the tailgate when it’s closed, still blocked.
On another note, is something supposed to keep the rails from sliding back and forth other than the closed tailgate? Cranking down on the mounting bolts doesn’t seem to make it stay in place?
KDubZ
Kody
Hawaii
25 Tacoma TRD Off Road Premium, 19 4Runner SR5
My camera doesn’t get blocked with the OEM tonneau cover folded all the way up, even with the prop rods holding it. I think it mainly happens if the tonneau cover is mounted too close against the back of the cab so that when it’s folded back it stands too vertically and blocks the camera.
