- Joined
- Nov 17, 2025
- Threads
- 6
- Messages
- 136
- Reaction score
- 141
- Location
- SW Missouri
- Vehicle(s)
- 2025 Tacoma TRD Offroad 6MT, 2015 Mustang GT 6MT
Ugh what is with all this AI bs? Just drive your truck man good lord
Age 62 and challenged to use a car cover? Older than you and I thought I was bad to not like the increasingly bothersome loading 75 pound boats on the roof of my Tacoma, and admit getting a bunch of posts and foundation rock last week was harder but not a problem. It's just "WTH" and worrisome to me when I see people even a lot younger in poor shape.It is easy to keep clean and hides car wash brush marks well. I had to get a fancy color like Supersonic Red to be special. I am on a limited budget for paint upkeep. I live in an apartment and have no hand-washing accommodations here. I have no covered parking in central Iowa. At age 62, using a car cover is too much trouble. Hand waxing is for the young, strong and the bold. I had a red 1992 Corvette at age 28 and Saturday morning hand waxing and buffing was a monthly ritual.
I can't use touchless washes in central Iowa. I have to use the local Mister Car Wash monthly Platinum package with underbody wash and hot wax. However, that carnauba hot wax alone in the tunnel is just not enough to fill in those fine scratches.
The birds attack my freshly-washed paint. I am now parking my truck away from my apartment building and away from lamp posts. Google told me to park away from places doves and other birds like to perch.
Touchless washes just don't clean as well but Mister Car Wash is leaving brush marks on my premium clearcoat paint quite visible under the night lights of my a parking lot. I am also getting those annoying white spots on my hood undoubtedly from bird droppings. I have a fancy color ideal for rich Tacoma owners with private garages in sunny California who can pay detailers hundreds or thousands of dollars for fancy paint protection services. Right now, I have another 53 payments of $363/month left. Those body wraps and high-dollar ceramic jobs. It's not enough to live with just good hand waxes anymore.
So, I did some Google studies to find the best paint care I could find on the cheap to come up with a plan.
Some Tacoma owners here might also be stuck with automatic brush tunnel washes. If you have silver, cement, pewter, white, platinum, champagne/gold or gray metallic, you probably will never see the swirl marks. Am I correct? Black and other dark colors shows up scratches horribly.
I am contemplating this master plan of tactical defense against that horrible Mother called Nature, that rotten Father called Time and that devil's invention, car wash brushes.
12-MONTH DIY PAINT PROTECTION MASTER PLAN
Custom Routine for 2026 Supersonic Red Tacoma Truck (Pleasant Hill, IA)
SUPPLY CLOSET ESSENTIALS
- Meguiar's Ultimate Compound: Spot-eraser for faded white bird marks or physical road debris scuffs on red paint. Do not scrub mindlessly.
- Turtle Wax Hybrid Solutions Ceramic Spray: Full-body chemical shield. Blocks bird acid, sheds rain, and creates a slick anti-friction brush barrier.
- Premium Microfiber Towels: Keep at least 3-4 clean towels in a closed container to avoid trapping hard dust particles.
- Emergency Cabin Spray Bottle: Keep a clean bottle filled with tap water and one microfiber inside the truck to melt fresh droppings instantly.
STRATIFIED WEATHER RULES (CRITICAL FOR OPEN LOT)
- Temperature (55°F – 85°F): Too cold prevents bonding (turns to gel); too hot flashes the liquid into permanent streak marks.
- Humidity / Dew Point (Under 70%): High humidity stalls evaporation. Spray will smear like oil on glass. Check morning forecast.
- Sunlight (Complete Shade Only): Never work on warm or hot sheet metal. Use a closed bank drive-thru canopy or deep building shade.
- Precipitation (0% Chance): The spray requires 24 hours of complete dryness to fully cure and lock onto the clearcoat surface.
12-MONTH OUTLAY SCHEDULE
SEASON / MONTHS CORE SERVICE TYPE EXACT WEATHER STRATEGY & ACTIONS
SPRING
March
April
AUTOMATED TUNNEL ONLY
(Zero DIY Work)
• High rain risk & heavy air humidity stalls curing.
• Use Mister Car Wash Platinum package to flush winter road salt brine out from underbody frame rails.
• Let tunnel Hot Wax temporarily hide surface micro-marring.
LATE SPRING
May
FULL RESET & SHIELD
(DIY Application #1)
• Target ideal weather morning (60°F-72°F, humidity <60%).
• Wash at tunnel opening (8:00 AM), move immediately to shaded structure.
• Spot-erase faded white bird spots on hood with Meguiar's Compound.
• Wipe Ceramic Spray over entire body to seal paint before summer sun.
SUMMER
June
July
August
AUTOMATED TUNNEL +
LOCAL SPOT CARE
• Extreme humidity & hot panels will cause ceramic to smear.
• Run through friction tunnel for continuous cleaning and underbody flushing.
• KEEP CABIN WATER READY: Instantly melt and dab off fresh summer bird droppings to avoid baked-on clearcoat damage.
EARLY FALL
September
GLOSS REFRESH
(DIY Application #2)
• Cool morning window drops humidity back to perfect levels.
• Clean truck at tunnel opening, drive straight to building shade.
• Spend 15 minutes spraying and wiping Ceramic Spray over entire body. Instantly hides fine brush lines from summer car washes.
LATE FALL
October
WINTER LOCKDOWN
(DIY Application #3)
• Clear, crisp morning window right before early freezing frosts.
• Apply a comprehensive layer of Ceramic Spray across every panel.
• This creates a slick surface that keeps slush and de-icing rock salt from sticking tightly to your clearcoat.
WINTER
November
December
January
February
(Zero DIY Work)
• Frozen temperatures (under 50°F) turn ceramic into a non-bonding goo.
• Keep spray bottles stored safely inside your warm apartment closet.
• Drive straight through Mister Car Wash on mild winter afternoons to let high-pressure floor jets blast rock salt away.
THE 15-MINUTE SHADE METHOD (FOR APPLICATION MONTHS)
1. Arrive at Mister Car Wash right at 8:00 AM opening to beat line backups and hot midday sun.
2. Drive out of tunnel and head straight to local covered shade (First Interstate Bank or Library overhang).
3. Dab Meguiar's Compound onto a towel and gently circular-rub faded white spots on the hood for 30 seconds.
4. Spray Ceramic Spray onto towel (1-2 sprays), wipe over one body panel, flip towel to a dry side, and immediately buff clear.
Iowa has horrible weather for most of the year. Tornados, flash floods, sporadic summer rains, snow, bird droppings, ice, humidity, morning dew, hail and winter road salts. My pretty truck feels vulnerable like Frosty the Snowman trying to navigate across Death Valley, California in August mid-day. It will take some kind of magic hat to pull that trick.
Please let us know how you protect your newer Tacomas with vulnerable paint colors and limited money to baby sit them.
Hello, I have no advice for you but would like to tell you about my experience, and , maybe you can take some of my ideas to your benefit.It is easy to keep clean and hides car wash brush marks well. I had to get a fancy color like Supersonic Red to be special. I am on a limited budget for paint upkeep. I live in an apartment and have no hand-washing accommodations here. I have no covered parking in central Iowa. At age 62, using a car cover is too much trouble. Hand waxing is for the young, strong and the bold. I had a red 1992 Corvette at age 28 and Saturday morning hand waxing and buffing was a monthly ritual.
SPRING
March
April
(Zero DIY Work)
LATE SPRING
May
FULL RESET & SHIELD
SUMMER
June
July
August
AUTOMATED TUNNEL +
LOCAL SPOT CARE
EARLY FALL
September
GLOSS REFRESH
LATE FALL
October
WINTER LOCKDOWN
WINTER
November
December
January
February
(Zero DIY Work)
Please let us know how you protect your newer Tacomas with vulnerable paint colors and limited money to babysit them.
Hello:It is easy to keep clean and hides car wash brush marks well. I had to get a fancy color like Supersonic Red to be special. I am on a limited budget for paint upkeep. I live in an apartment and have no hand-washing accommodations here. I have no covered parking in central Iowa. At age 62, using a car cover is too much trouble. Hand waxing is for the young, strong and the bold. I had a red 1992 Corvette at age 28 and Saturday morning hand waxing and buffing was a monthly ritual.
SPRING
March
April
(Zero DIY Work)
LATE SPRING
May
FULL RESET & SHIELD
SUMMER
June
July
August
AUTOMATED TUNNEL +
LOCAL SPOT CARE
EARLY FALL
September
GLOSS REFRESH
LATE FALL
October
WINTER LOCKDOWN
WINTER
November
December
January
February
(Zero DIY Work)
Given the limitations are fixed, I cannot offer a solution. I will offer some guidance:I have many limitations when it comes to caring for my truck
That reads like you have different and big problems to solve.I am age 62. I have many limitations when it comes to caring for my truck:
1. income level
2. apartment life with no on-site provisions for hand-washing or covered parking
3. old age, I don't have the endurance for too much manual labor
4. a car cover would be too inconvenient for me; it will ruin the paint with abrasion and it is useless during freezing winter weather of the Midwest
5. I use Mister Car Wash automatic tunnel in Iowa: it's $43 and change a month for unlimited washes under Platinum package which does carnauba hot wax each pass and flushes the underbody as well to protect against winter road salt
6. wand car washes are too expensive and labor intensive for me, the nearest one is too far to drive to and none of them do underbody washes
7. there is no perfect solution to paint care that is affordable to me; I have to make the most of whatever cheap spray-on products are amiable on the market, if I can't prevent brush marks, I have to try my best to hide them; do you have a better simple spray-on product than the Turtle Wax ceramic spray in a bottle?
Also, when I park my truck in my parking lot at my complex, I rotate the position of how I park my truck. Each and every time I come home to park, I park the truck facing the opposite direction as just before. This way my truck alters between facing north and south regularly to get even sun exposure all over so the paint may gradually fade evenly all over.
I disagree.62 isn’t that old!
I mean my dad just turned 60 and he rode a 100 mile bike race with me. Just saying, you can still be very active and healthy at 62.I disagree.
Yea this is true. I helped a lady at work with a rib injury who was 102. She got the rib injury during her morning workout and had photos of herself on the walls doing century rides at 80 y/oI mean my dad just turned 60 and he rode a 100 mile bike race with me. Just saying, you can still be very active and healthy at 62.
Yeah, just use some turtle wax hybrid ceramic spray and call it good. Works great.Not also my age, but my budget and Iowa weather gives limited opportunity to do things outdoors. All these paint care products I propose require specific windows in the weather. Wind, dew point, temperature and humidity must be factored in. I have never used ceramic on this truck. It's only been carnauba hot wax from the automatic tunnel. Even with this thin wax coat applied at least twice a week during the summertime, some super-fine haze marks show at night under the parking lot lights. Google studies now suggests Turtle Wax ICE (Turtle Wax ICE Spray Wax: Your primary full-body shield. Blended with carnauba and synthetic polymers to physically fill and mask automatic car wash brush marks across all red paint while fighting Iowa dust) periodically to fill in those fine haze-like scratches that can only be seen at night under parking lot lights and (Meguiar's Ultimate Compound: Your highly targeted "spot-eraser." Use only on stubborn, faded white water spots, bird etchings, or scuffs discovered anywhere across the Supersonic Red painted body (hood, doors, tailgate, or pillars). Do not scrub mindlessly over the whole truck.)
I'm still thinking all this stuff over.
I have not bought any of these products yet. the Meguiar's above is supposed to erase any water marks on hood, acid marks from bird droppings and tree sap marks. Thankfully, there are no pine trees in Iowa I have to park under.
I just don't feel like laboring over a can of paste wax and an electric car buffer at least once a month as I did living in sunny California back in the 1990's. My hands are too busy taking care of a young Ge3rman shepherd and cleaning my own apartment without a wife to help as it is. I realize my truck will age gracefully and one day die like me. I can only devote so much money and so many hours trying to preserve that new-truck showroom shine.
62 is well before actual old age, and someone in their 60s should be able to do either side of 10 or more pushups vs be challenged to wash an automobile. I'm no spectacular or talented athlete, and even with some permanent bad problems plus chronic pain, don't find it hard to meet or beat important measures.I disagree.
