MilCon Taco
Tim
Annapolis, Maryland
2026 TRD Off-Road Premium Long Bed
Hey everyone, saw this post once before talking about it and giving directions here: Trail Hunter Retrofit, and just figured I'd give my two cents after doing it myself.
First off, the original post is a pretty great walkthrough of how to hook everything up. One thing I'd like to add is that you need to actually go out and buy steel rivet nuts, a rivet nut setter, and have a 9mm or similar size drill bit to drill the holes (I was running around after realizing I didn't have a bit large enough). You'll also need something to cut the rectangular hole for the actual compressor to sit in. I used an oscillating tool with a carbide-grit blade, which worked really well for someone who has never had to cut into fiberglass composites.
All this being said, if you are someone who was questioning this retrofit as I was before, I'll just say this was (other than the stress of cutting into the bed) a very easy retrofit. As stated in the other post, the part number you need to purchase this compressor is #PT949-35240. This will get you all the parts you need (other than the tools stated above). I will say I don't think Toyota really planned/ wanted people to do this retrofit, because when I asked the parts guys in the dealership if I could buy the compressor directly, they said 1) it wasn't possible to install it on anything other than a Trailhunter as it's exclusive to that truck, 2) that they didn't sell just the compressor. So, if you want to do this, you have to buy it online through the part number directly, which on their site will come up titled as: "Tacoh Obtrifr Kit".......... yeah, whatever that means.
Other than those little confusing things, the hookup, as I said, is quite easy. With that being said, you NEED the premium package or at least the power to the bed to pull this off. There may be an even wilder retrofit where you run wires all the way to your battery hookup and maybe do an aux trigger, but at that point, just get an ARB twin and call it a day. If you do have the premium package, though, this retrofit is basically just a bed cut and a glorified plug-and-play.
Now, there have been discussions talking about how this one is slow (takes about a minute to fill a tire from 15-30), but IMO, I think this compressor is by far the best-looking, least complicated bed-integrated compressor on the market, and that alone is enough for me to have maybe a 30-second slower compressor. Also, if any issues end up coming out with it in the next few years, you'll be in the same boat as all the trail hunters, so when there is a fix or update, you can just follow their lead directly, unlike if something goes wrong with a 3rd party bed mounted compressor.
Video of it running:
Let me know y'all's opinions and whether you have done this retrofit or went with something else!
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Nice job, top shelf! I’m so impressed with folks who can figure out the big mods.
My OEM compressor on the Trailhunter takes only about a minute to inflate a tire from 15 psi to 31.5 (a psi number that seems to give me a nice road ride.)
MilCon Taco
MilCon Taco
Tim
Annapolis, Maryland
Thanks! and Good to know, I'll actually update the post with those times (tbh I haven't used it yet, but I took that time from google whos ai said 2-2&1/2 minutes hahaha)
TFOUTS
Timothy
Northwest Florida
2024 Tacoma Trailhunter, 2003 Tacoma TRD OR, 2003 Toyota Sequoia
When I have been airing up and airing down, it takes me all 4 tires at the most 10 minutes; just set the psi you want, screw the hose onto the valve stem and it does it automatically, either direction up or down. I find I used this air compressor quite a bit, I am amazed at the number of people I come across who need a tire aired up.
VB Tac
Virginia Beach, Virginia
I have been eyeing this mod. You have pushed me closer to making this happen.
Trying to find someone that has a rivet nut gun. Can't justify buying one just for this mod.
Thanks for the update.
lauren01
Lauren
Ventura, CA USA
I’ll put in a good word for that rivnut kit. It has all the sizes you could probably ever want, although you may need a longer attachment if you ever need to put in much longer rivet.
I bought that same kit to mod the hatch in my Integra for cargo net mounting points. Used it on the Tacoma and Subaru to add rivets to the sides of the center consoles and Subaru hatch for fun/useful molle panel installations. Used on truck bed for adding rivets to install bed supports. One of my upcoming projects is to add bed molle — for that I might need an extended M6 or M8 attachment. Otherwise it was money well spent. The tool had to break in a bit and then became easy to use. The one from Harbor Freight might be easier to use. Maybe others can weigh in.
MilCon Taco
MilCon Taco
Tim
Annapolis, Maryland
Glad to hear it, also do you air up each tire individually when you do this or do you use one of those all in one connectors to connect all the tires then fill up?
MilCon Taco
MilCon Taco
Tim
Annapolis, Maryland
So I actually got the one from Harbor freight for this : here is it and ill say it was extremely easy and simple to use, just watch a youtube video and you are good to go. Seems good quality, comes with steel rivets which is nice and a bunch of different heads including the m6 (the one you will mostly use for Tacoma's and the one you need for this retrofit). I will say though make sure whatever tool you get says rivet NUT setter/tool. There are rivet setters/guns that looks almost exactly the same but are not the tool you need and cannot be used on rivet nuts.
TFOUTS
Timothy
Northwest Florida
Each tire separately as that was the way the air compressor was designed to work on the TH. Just 10 total minutes, all four tires separately.
Kodachrome
Can you do me a favor if inclined and when you have a chance? I need the outside measurements of that air compressor control box faceplate. I am going to have to re-locate mine on my Trailhunter so I can access it with a slide-in camper on. I have a place in the camper that could work if not too big.
MilCon Taco
MilCon Taco
Tim
Annapolis, Maryland
Can you do me a favor if inclined and when you have a chance? I need the outside measurements of that air compressor control box faceplate. I am going to have to relocate mine on my Trailhunter so I can access it with a slide-in camper on. I have a place in the camper that could work if not too big.
What measurements exactly? The size of the baseplate isn't the same size as the hole you need to cut to have the control panel. Also The control panel is directly hooked up to the compressor by 3-4 different connections, so you'd have to extend all those connections and hoses somehow and figure out how to fill the hole it leaves when you take it out.
Kodachrome
Hi there, I have my Trailhunter now, will get around to figuring it all out soon. Thanks!
