Premium Fuel or Regular
CanyonFisherSummitSeeker
Chapman
2024 Tacoma TRD Off Road
While the knock sensors can adjust the skew, you don't NEED to run these higher octanes. The engine is built expecting 87, and i honestly just like to keep it vanilla. If you flash an ECU tune that expects 91, then sure.
If this was true wouldn’t the manual would say 87 only and not 87 minimum?
cswitz
2024 Tacoma TRD Off Road iForce Max
this will be unpopular, but you don't just "use better gas" if the engine is tuned to run 87, which these are. the octane rating only determines the pressure required to detonate, so if an egine expecting 87 gets 91 put in it, it's not "better because it costs more", it expects a certain pressure to combust, and you're skewing that value.
Youtube is great! I agree with you (and the ChrisFix video), except dyno shows these engines produce more power on 91 than 87. 91 isn't inherently better quality than 87, these engines just run a little better on it, according to dyno testing. The ECU can compensate for either one. You can have higher quality or lower quality 87, that's the intention behind Top Tier gas qualification with the additives. That's also mentioned in the manual and in your video. I agree these engines run fine on 87, you're just leaving power and efficiency on the table. Whether that's worth it for the cheaper cost per gallon, only you can decide, and I think that was probably the question for this thread. Sometimes the cost per gallon difference is pretty extreme at the pump.
I drive a lot of mountain passes a little faster than I should with the turbo spooled up for long periods of time sucking gas, and for me personally, I think premium is worth it. But that absolutely does not mean everyone agrees or it's worth it for everyone. If you don't use the whole gas pedal you probably would feel less benefit. In Colorado my options are 85, 87, or 91. I ran 85 in my 3rd gen for tens of thousands of miles just fine at altitude. The idea behind 85 at altitude is that there's less oxygen in the air to combust, which impacts timing, and 85 burns easier than 87. Except these newer trucks have turbos to compensate for that already and shove more air in. My 24 is a rocket ship compared to my 19 over the same mountain passes. At 10k+ feet going uphill the newer truck feels like it easily has double the power over the old one.
Kdbradley85
Kevin
2024 Toyota Tacoma TRD OR MT
No, because it says 87 is fine so you don't need to run higher (but you can if you want).
They pointed out earlier that the power figures and ratings given with these motors and presented on the window sticker were found using 91 octane (hence, the “research octane number”). The manual states to use at least 87, not that you need to use 91. I only use 87 in mine, but I’m also perfectly happy with a slightly “de-tuned” and less efficient performance. 91 costs significantly more per gallon, so I think it’s kind of cool that Toyota allows us to use a lower octane fuel in these without issues. I’ve never owned a turbo motor which didn’t require minimum 91 octane fuel, so it’s a welcome change from my point of view.
Chico
Arnaldo
2024 Toyota Tacoma
I put the recommended 87 octane and top tier gas very important.
Northern Illinois
2024 Tacoma TRD Sport Premium 4Dr 4X4 Automatic Trans
I just had a 1,000 mile trip, driving interstates doing the speed limit (mostly 75-80) and averaged 21.1 MPG. Stock ‘24 Tacoma Sport with tri-fold tonnau cover. My truck is now at 6,500 miles. Always on regular unleaded gas from Costco.
BAQ717
‘24 Tacoma TRD OR
Truck makes more power and the engine sounds smoother on premium. That being said, it’s great to have the option. It’s premium for me but I’m used to putting it in my vehicles anyways.
tacomasport1121
Robert
2024 Tacoma Sport
Cheapest top tier I can find. Usually chevron gas.
cswitz
If my math is correct–assuming you floor it–that's a 7% increase. I don't think a butt-dyno will feel it.
I'll stick to 87,
That’s another way to look at it. 7% hp gain for 30% higher fuel cost per gallon depending on the station. You also hit peak hp at 6000 rpm, so if you don’t wring it out that far, you won’t see the biggest gains.
I don’t have a consistent mpg improvement number, but theoretically there’s that too. My mpg has changed pretty dramatically with the weather so it would be hard to say.
Having the choice to use whatever gas you want, even with the turbo, is pretty great by Toyota.
goin2drt
KY
Perfectly stated and I align with this theory.
Good point. My mpg seems to change quite a bit almost every time I drive my truck, so it would be tough to figure out if premium made a difference for me.
gpburdell
GA
3G Tacoma
I think you've misunderstood the research octane number reference.
Octane is determined by two different methods - Research Octane Number and Motor Octane Number. MON tends to run about 8 points lower than RON. In North America the pump octane number is the average of the two and you'll see "(R + M) / 2" on the labels. So pump octane ends up being 4 points lower than the Research Octane Number.
So when the owners manual says "87 (Research octane number 91) or higher" they're saying choose a pump octane of 87 if it's labeled using (R+M)/2 method, or 91 if labeled using just the RON measure. It's the same fuel.
BTW - my 2017 Tacoma owners manual also says "87 (Research octane number 91) or higher"
Exactly. I'm reasonably sure I've floored my pedal once in 12,000 miles.
