nurp42
TRD PreRunner
'24 PreRunner
taco4moro
Los Angeles
2024 Tacoma TRD ORP
RIGID Industries 20" SR-Series Pro lightbar in white spot/flood combo with Amber-Pro lens covers
  • requires some trimming on the oem grille, used Bulletpoint Fab's universal brackets
  • lightbar with the lens cover sits perfectly in the grille
  • true amber lens covers provides protection and modularity, can remove/add them by loosening brackets
RIGID Industries 6" SR-Series SAE fog light kit
  • perfect plug and play fitment
  • didn't opt for lens covers but there is enough space to put them on, will add on in the future
  • these are brighter than the headlights, make sure to properly angle down during install.
will be installing the full RIGID Industries suite over the next few months including: ditch lights, 40" lightbar for the roof rack, chase lights, and rock lights
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9937.JPG
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9935.JPG
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9936.JPG
Slappy
tacoma , highlander
nurp42
TRD PreRunner
'24 PreRunner
do you leave that rack on the truck ?
how easy is it to remove ? reinstall ?
thanx
I leave it on. It's attached using 8 bolts in the T-slots (2 at the base of each of the vertical supports as circled in the pic below). The only situation I can think of where I'd want to remove anything would be needing to fit something in the bed that was taller than the crossbar nearest the tailgate and in that case I'd just remove the crossbar and leave the rest on. Haven't done it, but my guess is that if the 8 bolts mentioned above were loose the whole thing would slide right off the back and reinstallation would require just sliding it back into the tracks and tightening down the bolts again.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ tempImage4X2upV
Toy-truck
Houston, TX
What did you had to trim on the OEM grille and how much trimming was involved?
taco4moro
Los Angeles
2024 Tacoma TRD ORP
this image is from rave offroad with a 20" baja bar, but very similar situation.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 1754005556123-ul
the bolts for the rigid light stick out on the side in similar way, but this actually provides some use as the light bar can be loosened without removing the grille, giving me space to remove/swap out lens covers.
izzy
Bay Area
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 1000004518
This genuinely threw me off for a second walking back to the truck πŸ˜‚
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 1000004528
Did a little walk around on the matching color TRD, this is kinda funky Toyota.. I wouldn't be super happy about that.
SnowmanJPS
Halifax, NS
2025 TRD Pro
Got denied service at Costco for mounting the new tires because I didn’t buy them there, found a local guy running a tire shop out of his garage, he fit me in immediately after finishing up with someone else, I can definitely feel the difference between the stock tires and the new 10ply tires but they’re nice, can’t wait to try them out in 3’ of snow
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_7061
Slappy
tacoma , highlander
the stock tires really suck !
Nice Truck
