TacoBirdinNW
2025 DCLB SR5
New license plate bracket and light for the Dirtcom. I liked the one that came with it better, but it protruded a little too much into my tire and didn't want to run a spacer. +1 that the $40K license plate frame fits.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 5527
SnowmanJPS
Halifax, NS
2025 TRD Pro
Has anyone with a pro removed the back trim to access the suspension in the seats? Mine is creaking something fierce and I want to oil up the shaft of the shock if possible, I haven’t seen any post on it or YouTube videos, any help would be appreciated
edit: oops the shock didn’t have any air in it, silent now 🀣
Mercedes
β‰ˆ39N
2026 TRD Sport "Mercedes"
Break-in complete. 1015 mi / 1633 km.
Did first oil change today. Installed Fumoto drain valve.
For those that DIY but have not done an oil change yet, some tips:
- Fashion an oil drain "slip 'n slide" to guide the oil into the drain pan. I used cardboard covered with tin foil. The oil does drain quickly
- Be sure to remove the factory drain plug gasket, either to inspect or when replacing with an aftermarket valve. Mine didn't want to let go from the pan at first
- Loosen the oil filter and let drip until that stops. Once unseated, about a cup of oil, probably from the cooler, will splash out
Otherwise, it's like any other oil change you might have done before.
The break-in process went very well. Coming from a Gen2 to a Gen4, a steep but welcome learning curve getting use to the electronics. I did find a few quirks which I've read of in other threads:
- TPMS reports tire pressures 1-2 psi / .06-.12 bar lower than actual, all four tires
- The rearview mirror is stuck in anti-glare mode. Like others, I tried a few things, but nothing worked. I've gotten so used to it I almost never notice it
- I had a rattle in the rear seat. Pressing down on the horizontal portion, I confirmed it was the anchor used to lock the seat back to the cab. Two wraps of electrical tape around the anchor to make it wider to the latch and I haven't heard it since
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 20260715_143955
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 20260715_142915
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 20260716_065551
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 20260716_072830
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
3 hours with tech support, a little welding, and a prayer. Behold…, knob 2.0. Took less than 5 seconds to swap out. So much better. Part # 90011-23050.
Your forum fans are gonna need a video of what happens when the Bats button is pressed.
mylittlefupa
Socal
First Mod! My wife needed a little boost, and I noticed that the curbs at the new Costco next to my place looked a lot higher than usual.
I plan to build the truck more of an OEM+ look, as I'll only be doing moderate offroading and camping. The NYTOP seemed to fit the bill for that. My only complaint is that I wish they were a bit wider, maybe a little closer to the Caliraised.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ NZF_0857
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ NZF_0860
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ NZF_0864
lauren01
Lauren
Ventura, CA USA
Welcome, fellow Californian. I like a lot of the NYTOP stuff, including those steps-they look great and look like they function well. Are they also rock sliders?
Did you guys decide to install yourself or go visit them or another installer?
TacoBirdinNW
2025 DCLB SR5
I love those. Someone on here has a set for sale and is totally snag them if I wasn't so far away. Sleek
mylittlefupa
Socal
Thanks! Yes they are also rock sliders. The are some videos of a Tacoma on YouTube beating the absolute snot out of them, so I felt pretty comfortable with their protection.
I installed them with a friend. Took about 20min. Very straight forward. I plan to get nytops skid plates if I can find a good deal!
SnowmanJPS
Halifax, NS
2025 TRD Pro
Finally ripped the back cover off my seat (literally) I filled the air up 9 days ago as per my last post, and my pressure is down 20psi, so I oiled up the moving bits and the seat is much quieter, added 20 more psi, and I changed the factory valve caps to one with a seal on it in hope to diagnose the issue before ultimately complaining to the dealer which I’m not looking forward to
Being a Journeyman welder it's really cool to see the QC by marking the welds with black marker
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_2652
