I'm not changing the oil viscosity in my Toyota just because GM engines suck
I wouldn’t deviate from what was spec’d in any engine with VVT. If you want to be proactive, change the recommended oil more often.I've been running 5w30 since probable 3k miles on the truck. The motor is a little quieter and smoother as you would expect. I have a hard time believing that a warranty would be denied over it. I am taking the chance. I also plan on keeping this truck for 2-300k miles, so I think the little bit of added protection could help in the higher miles. I'm pretty sure that if CAFE standards or whatever is driving the mpg regs, we would not be playing with 0w20 or thinner oils. Are they adequate in most engines? absolutely. Do I feel better going up one grade? you betcha. Would the manufacturers be pushing thin oils if not driven by mpg standards? I doubt it.
Same here, and I live in New Mexico, pretty hot in summer.idk...I have always used the OEM recommended oil with zero issues
This is also my experience. I have three Toyota engines in my stable (actually 4, but my pushrod 2FE doesn't count). The recommended oil for my 1998 3RZ is 5W30, the 1AR in my 2012 Venza is 0W20, and of course the T24A in the Tacoma with 0W20.I've been running 5w30 since probable 3k miles on the truck. The motor is a little quieter and smoother as you would expect.
yep. over nine years and 107k miles on my ‘17 3rd gen with the recommended and all’s good.idk...I have always used the OEM recommended oil with zero issues
Heat breakdown isn’t the concern here…it’s legitimately oil dilution via fuel, and the resulting “shearing” down of viscosity grade, ultimately resulting in increased engine wear. And yes, oil dilution is proven to be an issue with this engine when operated in cold climates. Speaking for myself and my operating conditions…0w20 simply cannot be trusted.Anyone worried about viscosity should be doing regular UOAs. Just remember that the 2.4T runs a variable oil-pressure system and it is designed around thin oil. If heat breakdown is your concern, try 0W-30. And yeah, 5W-30 is used in Europe, so you’re fine there too.
