Hatman
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
If you don’t like the ARB sport bar, you can move on to the next thread. I happen to like it but I wanted a tonneau cover too. I had 2 ideas to make both possible. The first idea was to make a plate that sits under the lip of the cover and allows you to bolt the bars on after cutting them up a bit. The second idea was more expensive and raised the bars up 3/4” higher, but it was easier, so here’s how I did it:
Remove the bars and cut all 4 mounting tabs off, flush with the base plate. Grind it smooth and hit it with flat black (or dark gunmetal) paint.
Install your favorite tonneau that has T-Slots. I went with the RetraxPro XR. The bonus with this setup is there is plenty of room to add track accessories later. Mark the T-Slot lines on the bottom of the bars and drill 2 holes in each section. I bought M8x25 T-slot anchors off Amazon and they worked perfectly. I would not go any longer, but you could go down in length to 18mm with no problems.
Toss the bars back on and you have the best of both worlds!
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4083
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4064
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4082
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4081
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4084
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4055
Rubenc87
Ruben
2025 TRD PRO
Great job. It looks exactly like the Youtube video that I had posted but had no idea what they had to do to accomplish it. How smooth (level) was it after the cutting?
Hatman
Hatman
Argyle, TX
Perfectly level. I took my time grinding it flat and sanding it smooth. The last 2 photos show the after and before (I kinda sucked at the post) that show how much higher it is after the install.
bsquaredMTB
El Paso, TX
I'm not a huge fan of the sports bar but I definitely appreciate good workmanship. Looks great!
trailhunger
2024 TH
Somebody needs to send this to ARB & Sheldon’s team, the OE needs to be designed shorter height so that the integration with the cover gets it flush for aero.
I got rid of my sport bar for GFC, but that first couple weeks w/it definitely head turner distinct trim differentiator. Should make the sport bar have better resale despite sitting high off the cab as the only compromise
Any ideas how to make it work with a Diamondback?
Hatman
Hatman
Argyle, TX
I looked at that as an option too, but it looks like the Diamondback flips up? If that’s the case, you could cut the mounting tabs off the sport bars and bolt them to the top of the cover. The limitation would be that the front section of the cover would only open 60% ish.
grwil67
Gary
Louisiana
2024 Tacoma Limited, 2018 F150, 2019 Roadking along with a few older F150s and H
Looks AWESONE, great job!
Rubenc87
Ruben
2025 TRD PRO
Measure and measure ten measure again before cutting. Looks factory. Is it me or does it look more narrow (just a tad) from the back looking towards the front of taco?
Hatman
Hatman
Argyle, TX
I squeezed the bars closest to the cab in about 1/8 - 3/16” on each side just to minimize to amount of overhang out from the tonneau track. But I don’t really think that made much of a difference. Unfortunately I didn’t take any before photos from that angle to compare.
Rubenc87
Ruben
2025 TRD PRO
I think it might be because they are not mounted to their normal mounting points that give it a different look.
25TacomaTRDSport
2025 Toyota Tacoma TRD Sport
Thanks for the post, I added the Sport Bar to my Taco cause I like the look, then after getting it as I was installing it I thought "how can I get a tonneau cover on it now" LOL I was thinking of doing the same thing you just did but I like the flush roof/Sport Bar look. :headbang:
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) Front of the hous
Hatman
Hatman
Argyle, TX
I was worried about the same thing. My first choice was a BAK roll top cover. Mount it sitting on top of a plate that connected to the rail system and had bolts going up for the bars, instead of the T-slots. That was just too much fabrication and I couldn’t find anything on the market that I was sure could work. RC makes a set of plates but I couldn’t be sure they would work with the cover.
In the end, I don’t really notice the extra height in the bars. It might actually be a bonus if I ever wanted to mount lights on the bar.
25TacomaTRDSport
Hey,
Yeah, I see that being an advantage when adding lights.
