- First Name
- Jeff
- Joined
- Jul 18, 2025
- Threads
- 1
- Messages
- 36
- Reaction score
- 39
- Location
- Argyle, TX
- Vehicle(s)
- 2025 Tacoma Trailhunter / 2022 Bronco Badlands
If you don’t like the ARB sport bar, you can move on to the next thread. I happen to like it but I wanted a tonneau cover too. I had 2 ideas to make both possible. The first idea was to make a plate that sits under the lip of the cover and allows you to bolt the bars on after cutting them up a bit. The second idea was more expensive and raised the bars up 3/4” higher, but it was easier, so here’s how I did it:
Remove the bars and cut all 4 mounting tabs off, flush with the base plate. Grind it smooth and hit it with flat black (or dark gunmetal) paint.
Install your favorite tonneau that has T-Slots. I went with the RetraxPro XR. The bonus with this setup is there is plenty of room to add track accessories later. Mark the T-Slot lines on the bottom of the bars and drill 2 holes in each section. I bought M8x25 T-slot anchors off Amazon and they worked perfectly. I would not go any longer, but you could go down in length to 18mm with no problems.
Toss the bars back on and you have the best of both worlds!
