Romer
Romer
Ken
Centennial, CO
Two dealers wanted almost $600 to Calibrate the sensors
So I went another path that does not require calibration.
The ARB Bumper comes with all new sensors, all 4 the same part number
The stock bumper uses the same sensors in the center, but different at the ends
The Parking Assist feature is off because it does not recognize the new sensors or at least the two at the ends that are different part numbers at least that is my theory.
I took the bumper off and partially disassembled so I could swap the sensors with the stock ones in the stock locations.
Now everything works as it should. If there is a difference in the sensitivity or angle detection, I can’t tell the difference from the drivers seat
The bottom line is for these Rear ARB bumpers, if you use the set of new sensors, Calibration is required or it won’t work. If you use the stock sensors, then the systems all work fine.
Romer
Romer
Ken
Centennial, CO
There must be a way to register the sensors easily rather than do a full calibration testing angles etc. The next person to do this may figure that out or just use the originaal ones. Be nice to know though
TFOUTS
Timothy
Northwest Florida
Thanks, so you are confirming you have the same unused connector. At least I didnt miss anything in my install
I wonder what it is for?
So, I had my 5k service today at my local dealer, and I walked through the showroom and they had two Tacos, an SR5 and TRD. Looking underneath the back both had this same plug, as well as my TH. I asked the tech guy what's with the plug? All the Tacos have it. Without extensive research, which he was going to do, he said it's probably something to do with towing and a camera system.
Tacoma nut
Seattle, Washington
2024 Tacoma Hybrid Limited
There must be a way to register the sensors easily rather than do a full calibration testing angles etc. The next person to do this may figure that out or just use the original ones. Be nice to know though
Thanks for doing all the research and leg work and then sharing with everyone
Romer
Romer
Ken
Centennial, CO
That is what these forum communities are all about. I have benefited from others research as well.
Andrace
2024 TRD Off-Road 6MT
Question to anyone who has installed the ARB rear bumper, do you gain any additional clearance (while acknowledging the hitch is the lowest point and that won't change)?
It doesn't look like too much of a difference just looking at the photos, so any info is appreciated.
And to anyone who has swapped, are you happy with it?
Thanks in advance
Romer
Romer
Ken
Centennial, CO
on the sides you don't get anymore clearance, you are alsso above the frame rails in stock vs with the ARB
In the center you see a sharper angle maybe giving a slight advantage to the ARB
But with the ARB hooks installed at the frame rail and the tow reciever the lowest point, there isnt a way to really get more clearance.
If you want clearance on the rear, go with bigger springsf
Its more about protection than clearance and I am still very happy with it.
Andrace
Thanks, that's what I figured, but I had heard mentions of additional clearance and was curious in case the photos were deceiving me.
OldOre
AC
TEXAS
2024 TRD OffRoad
Anyone have the weight of the ARB bumper compared to the stock TRD OR bumper? I searched for 15 minutes or so and can't find any weights associated with the part numbers. Just curious, because, I have a RSI top and already get pretty saggy with a full load on camping trips.
Also, many thanks to @Romer for all the info on this mod.
Romer
Romer
Ken
Centennial, CO
from what I remember, it was close to all the parts removed. Thinking 80 pounds but could be wrong. I noticed no sag with the swap
mrtimo
CA
When you took the bumper off again, did you manage to lift the treads without snapping the fastening cleats? Or had you not yet put the those on? Asking for a friend :)
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
I believe that connector is a termination point for the CAN Bus (Controller Area Network). There are several other connections around the truck that are the same. The only reason I recognize that connector is that I pulled the one on the driver kick panel out when I tuned my truck. This is the terminator that I removed for my other harness, and it fits in the connection at the rear of the truck that you have in that picture.
Love the bumper though. It's tougher than stock but not rough edged metal like some of them.
Romer
Romer
Ken
Centennial, CO
I think 1 of those snapped, but still went on securely
mrtimo
CA
Thanks…while I know I snugged up the main anchoring bolts, I didn’t set them to torque spec. Idiot move by me. Now I have to (a) go ahead and remove the treads with the risk of snapping a cleat, or (b) not worry about it….
Jeff11
Pittsburgh
2025 TRD OR
Wondering some opinions. Got the bumper together and ready to install on truck. I can either install my original sensors into the new bumper with the corner ones wrapped in matte black vinyl to match the bumper (my truck is blue, so would look weird if they were left as is, and I checked to see if they work after they're wrapped and they do).
Or... A local place can recalibrate the new sensors that come with the bumper for $475. Cheaper than the dealer.
What do you guys think? It does seem like the stick sensors work just fine in the new bumper from what people have said. But then again, I am installing the bumper myself so I am saving all that money and can spend some on the new sensor calibration.
