JustDSM
JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
What can we expect with the stage 2? Or are you just in the teasing stage ?
We have some dyno time scheduled to evaluate some different settings. Once confirmed we'll validate in the real world. I think we'll have something by June/July, but that's honestly just me taking a stab at a date for you. I promise it's not just a tease!
Cool! Will there be recommended intakes? I don’t want to have to buy 2 of them.
GMak621
Røgue Valley
26 Tacoma TRD ØR Hybrid
@JustDSM One thing that needs to be apparent, is that if you live in California you have to pay $700!!?
JustDSM
JustDSM
Justin
Ogden, UT
Our MSRP is $650.00 USD
We do not control or manage retailer pricing.
GMak621
Røgue Valley
Our MS
We do not control or manage or control retailer pricing.
Damn you CA. But right on. Going to get it tuned next weekend. I also was wanting to find out when stage 2 will be released ?
JustDSM
JustDSM
Justin
Ogden, UT
Will have an update posted on that shortly. I'll make sure to tag you when that drops!
Briosauce
Michigan
Great question!
With the 4G Tacoma, we’ve revised the tuning approach due to the ECU’s completely different control strategy. Unlike the 3G Tacoma, which used direct throttle angle targets, the 4G Tacoma (along with the 6G 4Runner, etc.) employs a torque-request-based throttle control strategy.
To adapt to this, we’ve implemented a new throttle control method and updated our naming conventions accordingly. Our current throttle settings are:
  • Stock – Retains 100% OEM throttle control/sensitivity.
  • Base – A slight increase in throttle response/sensitivity.
  • Enhanced – A moderate boost in throttle response/sensitivity.
Note: Drive mode-specific adjustments are made independently based on each mode’s intended use.
As for tuning, Stage 1 is our standard performance option, offering higher output compared to Stage 0 and OE Spec.
  • Stage 0: Identical to Stage 1 but with a lower boost target (available on request).
  • OE Spec: Designed for SR trim and manual trucks, unlocking their full OEM potential—bringing them up to 278 hp / 317 lb-ft.
Both Stage 0 and Stage 1 are full engine and transmission calibrations, enhancing turbo spool, response, and overall drivability. Meanwhile, OE Spec retains stock calibration but removes factory detuning, restoring the original full-output OEM code.
Let me know if you need further clarification!
@JustDSM If you applied the OE Spec tune to an Off Road Hybrid, would the result yield a non-hybrid OE engine tune with a non-hybrid OE shift map?
I have a hybrid. No problems with the engine/power availability. I absolutely hate how the transmission is mapped. In my experience it tries to run at lower rpms than what the gas only model would do. (1300 rpm vs 1600 rpm @ 40-ish mph) Creates lots of vibration/shuttering at that speed. Drives me nuts. That's all I'm looking to fix.
JustDSM
JustDSM
Justin
Ogden, UT
Chris,
The OE Spec calibration is only an option for the SR trim trucks which come from the factory in a "detuned" state lowering their output to 228hp from the 278hp of the higher trims on the gas models.
We don't detune the Hybrid trucks for a lower specific output, sorry!
What drive modes do you have issues with? We remap the hybrid models with their own specific transmission tuning compared to the gas models. While our calibration and shift scheduling aren't a massive departure from OE values, they are more in line with what you're looking for.
Best,
Justin
Briosauce
Michigan
Chris,
Best,
Justin
Thanks for the reply. Definitely not looking to detune, just not really looking to change the engine output unless I have to I suppose.
Eco and normal in the hybrid suck at 40mph plus or minus depending on the grade. If I roll around in sport all the time I don't seem to notice the vibration. That's probably because it's running over 2000 rpm most of the time. What I feel like I want is just the stock, non-hybrid transmission settings. What I've experienced in the few that I've driven is they seem to run the revs just a little higher than the hybrid. (1500-1600 @ 40 mph instead of 1250-1300) It might be that they're not locking up the torque converter in those models at that low of a speed either. All these things because they don't have the assistance of the electric motor.
Briosauce
Michigan
@JustDSM
Hi Justin,
Do you have any other thoughts, recommendations, or info to add to the above? Sorry, I'm not trying to be impatient, but I've been 4Runner hunting and seriously considering ditching this truck. This isn't the only reason, but it's for sure playing a big part. If we confidently think this issue could be remedied, I might try the tune first.
Thanks.
JustDSM
JustDSM
Justin
Ogden, UT
@JustDSM
Hi Justin,
Thanks.
You seem to be looking for something VERY specific and without really getting deeper into it (and looking at data from how you're driving) it's very difficult for me to provide an answer of exactly what will happen/when. Many of the events you're looking to change are based on accelerator pedal input and output shaft speeds making the question you're asking quite difficult to nail down. It's not in our interest to mislead you into a sale and tell you it will absolutely cure your problem. Given what you've said here, I do think our calibration is certainly more in line with what you're after, but is that "enough" I can't say. We developed the shift schedule and other areas of the calibration to all work in harmony, so piecing it together is generally not the best approach.
I'm not going to be able to disclose specifics on our calibration details, but I can share some generalities and say all upshifts will generally be commanded at a higher RPM compared to the OE calibration for just about all conditions in normal and eco on the hybrid. You'd find the tuned hybrid shift points to be more similar to the non-hybrid settings (though in some instances a little higher).
I'm confident you'd enjoy the tune, but if you're looking for something ultra-specific, it might not be exactly what you're looking for. If our Stage 1 calibration isn't your flavor, we could do a custom trans tune for you.
Our custom rate is $100/hr and we'll rework things to your liking as long as we're not doing something that would ultimately be detrimental to your safety or the vehicle itself.
Briosauce
Michigan
Thanks again for all of the info. I really appreciate it. Last questions and I'll shut up and go back to my corner.
Does the Stage 0 tune have the same trans map as the stage 1?
Any idea how long a custom adjustment might take, ballpark? (likely less than a full day or multiple days?) And where would that take place?
JustDSM
JustDSM
Justin
Ogden, UT
No troubles! :)
Stage 0 will come with the same transmission tuning as Stage 1.
The amount of time it takes for a custom trans tune really comes down to how well you're able to communicate what you're after (we can talk offline about what information we need from you to make an effective change) and how far your changes take us from our starting point. I have a pretty good idea of what you're after, so I don't think we'd have issues there.
One important thing to remember is that you can't just command the ECU to shift at a specific RPM; the logic is a bit more complex than that, so we model what we want to achieve, and we work with you to to dial that in until it's working as you intend.
We can often get it there on the first revision, but sometimes it takes 2-3 revisions depending. It's not something that should take multiple days or anything like that.
Should this be something you wish to pursue, I'll have you reach out to your nearest retailer (https://overlandtailor.com/retailer-locations/) and work with them to get scheduled. Please be sure to mention you've spoken with me regarding your transmission tuning and let them know to contact me for specific details if they have questions. Once you meet with your retailer they'll work with you 1 on 1 and collect some data while you drive to help us take your input and execute the appropriate edits.
grwil67
Gary
Louisiana
2024 Tacoma Limited, 2018 F150, 2019 Roadking along with a few older F150s and H
Has anyone reported fuel mileage change after doing the stage 1?🤔
Would be interested in what the highway mileage is after.
I just believe it should be better and Toyota is just holding back for 1 of many reasons 😆
I mean, when full size four door 4x4 F150s in v6 and v8 are doing as good "or" better surely something is WRONG js......
