Bilstein products - any news yet?
theKurt
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
5100’s have been launched! Awaiting the inevitable YouTube reviews….
Powhunter
Alberta
I can’t see the 5100s being much of an upgrade over the stock red Bilsteins.
BAQ717
‘24 Tacoma TRD OR
They provide a lift and have longer travel. Best bang for your buck for 95% of those who don’t high speed desert run.
Powhunter
Alberta
Do they actually have longer travel than the new stock red off-road shocks with the piggy back reservoirs that were designed with the sway bar disconnect? This may have been true for the third gen, but now the stocks and the 5100s are the same diameter, plus the stocks have the remotes. I honestly think you’d be wasting your money ripping out the stock red Off-road shocks for 5100s.
Norsk
Greg
Downingtown, PA
5100 is not worth the upgrade. I had them on 3G and felt it may make no difference with the red bilstein our TRD Off-Road have. Wait for 6112.
Rocko
Oregon
2024 trd w/upgrade
My old 2nd gen with 5100's felt better than my 24"OR. Harder to bottom by more than a little bit, it felt more dampened and bombing along rough fire roads was better.
How do the new 5100's handle the bump stop? internal? That may be the problem I am having with the 24 shocks.
Norsk
Greg
Downingtown, PA
What spring did you have?
BAQ717
‘24 Tacoma TRD OR
Granted this video is for the Tundra but the TRD lift is a rebadged 5100 kit regardless of the truck so it is relevant and likely applies the same. The external reservoir on the stock OR is more for show than anything. I love mine, but I want a lift and to keep the OEM look.
Powhunter
Alberta
I would argue the stock Off-road Tacoma suspension is more capable than the stock off-road Tundra suspension. I’d also strongly disagree that the remote resi is for show. It holds extra cooling oil so that more of the shock body can be used for travel. I mean it’s your money, but I would hesitate “upgrading” shocks that may or may not even be better at all. Especially if you actually like the stock suspension and want to keep it stock looking. If you want some lift, there’s several good preload spacers or springs out there that would functionally do the exact same thing as the 5100 lift clips for a fraction of the price. Not that 5100s are expensive, but it just seems odd to me.
I’m sure the SR5 and Sport guys will love the 5100s, but if you already have an Off-road you might need to wait for the 6112/5160 for an actual performance upgrade.
That’s just my $0.02, and it’s worth exactly that.
Chris_2025OR
San Diego, CA
2025 Toyota Tacoma TRD Off Road Long Bed Ice Cap
I ran 5100s in the past on a 1g tacoma, 1g tundra, and 4g 4runner. It's hard to compare apples to apples on the shock because they were all different vehicles with different springs. But, my $.02 is that 5100s are stiffer, so they use their travel more efficiently, but top out and bottom out harder than the stock 4g OR bilsteins. Less compliant ride overall on the 5100s and definitely harsher top outs compared to OR bilsteins, but you can probably rip a whoop section with more control on 5100s. 5100s fade much quicker than the OR bilsteins. Not enough up travel on the stock OR bilsteins, static height is a little too low. Conclusion - I would not change out my stock OR bilsteins to replace them with 5100s, but I would replace the stock spring. Great option for SR, SR5, and Sport though.
BAQ717
‘24 Tacoma TRD OR
Appreciate your input, definitely a lot to consider. The TRD lift kit being on a stop-sale gives me some time to do more research before I pull the trigger. The 6112s will hopefully be on the market soon.
ThatBronze4G
Lloyd
United States
2025 Toyota Tacoma TRD OR
I reached out to Alldogs about these when they made a teaser post about having the 4G 5100s in stock. the perch sits higher on the 5100 so there should be a small amount of lift even at the bottom setting. length wise, the email states that there is less than a 1/4" difference in length between the 2 both front and rear.
Here's some photos i was sent.
Overall, these don't necessarily look like an upgrade over the factory red Bils unless you want to lift with your OE spring.
2024 Tacoma Bilstein products - any news yet? tacobilF
2024 Tacoma Bilstein products - any news yet? tacobilR
