Best value mid budget shocks
Best value mid-budget shocks
  • Total voters
    43
Chris_2025OR
San Diego, CA
2025 Toyota Tacoma TRD Off Road Long Bed Ice Cap
It's time to upgrade the stock TRD offroad bilstein shocks (I have them on Alldogs offroad springs.) They're great for low speed off roading but they just can't hang at higher speeds and don't dampen extra weight very well.
I'm looking for a best bang/buck suspension setup - 2.5 or 3.0 front and rear shocks with resis, adjusters, upper control arms, bump stops, sway bar links, diff drop, etc. start at $5k, but I have a feeling that there's a sweet spot right around $2-3k that will get you most of the performance at a better value.
Compared to stock, I'm looking for a shock with better bottom and top out control, firm and controlled damping through the travel of the shock, something that will dampen 400+ pounds of gear in the bed but still be somewhat comfy for the lady when I'm chattering her teeth away on a rocky road for hours. I live in the southwest and I like to drive fast when I'm on dirt, so I'm really looking for better high-speed performance compared to the stock Bilsteins, but I'm not sure I need the whole big expensive 2.5 resi adjuster setup. (maybe I'm wrong?)
I've narrowed it down to these 3 options, but I'd love to hear about any other shocks you think would be a good fit. If anyone has any of these installed on their vehicle, I would also love to hear your feedback. Would love to hear anyone's $.02 on the subject in general.
Icon 2.5 Stage 3 - $2,838
Falcon 3.2 - $2,200
Fox 2.5 Performance Series - $2,273
2024 Tacoma Best value mid budget shocks Icon
2024 Tacoma Best value mid budget shocks Falcon
2024 Tacoma Best value mid budget shocks Fox Front
2024 Tacoma Best value mid budget shocks Fox Rear
BAQ717
‘24 Tacoma TRD OR
Ive been doing a lot of research and it seems the best bang for your buck setup is the Bilstein 6112/5160. However they’re not released yet. The Eibach stage 2R shocks get solid reviews as well. The Fox 2.5s seem nice but I don’t want a shock that needs rebuilt every 30-50k miles.
I’ve been pretty happy with JRI.. I was in the same boat trying to stay under 3K and rebuilds every couple years, hoping these don’t need rebuilt? They say lifetime’s warranty for what that’s worth? Having adjustable reservoirs is really nice and won’t by a set again without. Keep an eye out they’ve had a couple of pretty good sales on them, picked mine up for $1500
https://www.tacoma4g.com/forum/threads/jri-6-stage-adjustable-shocks.8196/page-2#post-173971
Transient
CRF230L
FWIW I had a fox 2.5/eibach combo on my f150 with the same rebuild interval from Fox. They lasted me 75k (mostly pavement, washboard and beach) without any issues, no need to rebuild for me, despite having the same 50k max rebuild life. Sold the truck at that point so can’t comment on them beyond 75k but would run that setup again.
MERAKIAUTOWORKS
Joshua
Anaheim, CA
We do a lot of Fox as bang for buck, Icon is up there as well. Then King for the $$..
-Josh
tkrum015
Ted
Olympia
I am in the same boat here. On my 2010 TRD OR I had the Icon 2.5 stage 5 kit. Loved it I did have the shocks rebuilt once and the ran out to 120k till I got rear ended.
I also have been running the Falcon 3.3 Sp2 on my 20 jeep JLU with a 3 inch lift and they are amazing.
The problem I see with the falcons for the Tacoma, it seems you need to get new springs! But I am very interested in them.
GDTRFB
Ryon
Idaho
2025 TRD OR
Any reason you didn't throw the Old Man Emu MT64 in there as a consideration?
Chris_2025OR
Chris_2025OR
San Diego, CA
Nope, no reason. It's on the poll now. Any experience with it?
GDTRFB
Ryon
Idaho
2025 TRD OR
No experience, looking at it as well. Eibach 2R, MT64, and Fox 2.5 performance are my shortlist. In that order right now.
Chris_2025OR
Chris_2025OR
San Diego, CA
I ruled out the Eibach 2r personally because it's a 46mm piston same as the stock red bilsteins, but without a reservoir so it has even less oil capacity than the stockies. Falcon is a 2.25 body, everything else on the list is a 2.5, and the MT64 is 2.8 which is the biggest body shock you can fit on stock mounts. For my application, I know I want the extra damping and oil cooling capability of a 2.5 shock, the question for me is which has better valving for my weight and driving style, which is totally subjective.
GDTRFB
Ryon
Idaho
2025 TRD OR
I ruled out the Eibach 2r personally because it's a 46mm piston same as the stock red bilsteins, but without a reservoir so it has even less oil capacity than the stockies. Everything else on the list is a 2.5 piston, and the MT64 is 2.8 which is the biggest body shock you can fit on stock mounts. For my application, I know I want the extra damping and oil cooling capability of a 2.5 shock, the question for me is which has better valving for my weight and driving style, which is totally subjective.
That makes perfect sense. I like the idea of the mt64, but for my current needs it is overkill, and I only plan to run 33’s so it is a little tall, eibach seems to review as an upgrade over the stock bilsteins but you make an interesting point. I just havent seen any other reviewer or vendor with that assessment. I had actually picked up the 2R kit but think I am going to hold off for a bit. I like the look and height of the Fox’s, I just really dont like the service interval. Real world sounds like 50k should be doable, but if it ended up being more frequent it really wouldnt be worth it to me.
Keithz24
Georgia
2024 Tacoma Off-Road
I have the MT64's installed. After a few days of driving, they settled 38.75inches in the front and right at 40inches in the rear. Measured from the ground, center of the hub up to the bottom of the fender trim. I have the clip on the front struts set to the second from the bottom (No Accessory added). Runing 28570r17 tires 31 psi. Ride is frailly comfy. It's a little bit firmer. Not as pillowy as the stock off road suspension was. I no longer get the cluck when going over speed bumps though. I will say that I wish that ARB offered some isolators for the bottom of the rear spring. They seem to make some seating noise sometimes when going down the dirt roads.
2024 Tacoma Best value mid budget shocks MT64
2024 Tacoma Best value mid budget shocks MT64 Front
GDTRFB
Ryon
Idaho
2025 TRD OR
Do you happen to have measurements before and after from the center of the hub to the bottom of the fender?
Keithz24
Georgia
Not from the center of the hub, no.
The front was measured at 37 and the rear was at 38 5/8. Both of these measurements were taken from the ground to the bottom of the fender trim.
Hope this is of help though.
