trailhunger
2024 TH
The goal is a 400mi tank on a stock Trailhunter. Got a Go Fast Camper + a Martin Off Road Roof Rack w/ a big ass spoiler. Currently getting 18.5mpg @ 7,300 mi. Nix the OE sport bar and the rear recovery points (swapping for SixthElement aluminum), added constant is ~350lbs with the kit.
Notes: Minimal cutting on the chin spoiler itself, had to get some aluminum angle brackets and utilize a few OE mount locations. The most time spent on this was shaping additive spoiler near the high mount cutout bumper. Did that with a type of urethane foam (DivinyCell), carbon fiber & resin, bonded them to most outer edges of the dam wings, EVA 1/16” stand-off cushion against the bumper). With the airdam clearance is 11” H w/stock Goodyear Wranglers. The mounting points do not interfere with skid plate mounts at all. All said & done 6 bolts, disconnects in ~5min when I want to get more into crawling on trail.
Just finished it yesterday and will drive it ~1k and then look at the numbers. Expecting ~20mpg+ highway at minimum driving speed limit adaptive cruise etc. If it underwhelms I spent $15 for the airdam on Fb market place & an afternoon modifying with random extra materials in my garage.
for the gerrys who want to shoot shit down & correct & be a doosh & say it looks weird & whatever else causes you chaffing & harm in life: no one cares betches ?
I personally think it has gen 4 XRunner vibes and that might be the coolest taco yet, albeit a concept. To each his own ?
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_0076
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_0041
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_0016
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_0014
Beto
Robert
El Paso, TX
Toyota Tacoma Trailhunter
The look isn't bad at all. Curious to see your results. It would be great if it somehow the air dam could use a quick-release system for when the truck goes off-road.
DENNISD
Dennis
Omaha
I just took that "dam" thing off. It looks like "dam".
Okay, enough with these dam jokes. I don't have enough dam time to continue.
Proceed..................:sunglasses:
Echoedlite
Wisconsin
So the idea is to change the angle of the air dam to angle it moreso to the ground as well as to deflect wind from the tires?
rybern
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
The Trailhunter and Pro have more of a high clearance bumper than the other trucks. The fill in area that the OP added gives you an idea of the difference.
Props to OP, I'm curious to see how the experiment turns out. (y)
exia
los angeles
24 tacoma hybrid Trd OR
Will you be changing tires at all with. I would like to see how much mpg on 33
trailhunger
trailhunger
2024 TH
Wrong. fairing on the Martin OR rack literally brought it from 15mpg to 18.5mpg. Aero & rolling resistance.
Drove up to the high country today, ~40 mi trip, 17mpg up / 28 down. Just about at sticker print for the combined now. The airdam and the roof spoiler do work. Distance factor needs to be logged to really get a solid number tho.
Gonna toss up some pics once I have ~1k mi and a solid trip out to Moab in strong headwinds.
trailhunger
trailhunger
2024 TH
gonna drive the 33 wranglers until hit the wear indicators, then likely staying with a 33 but something like a Nokian Outpost or a Michelin 3 peak,. For the first few years no major rock crawling, swapping the OE Rock Rails for PRO’s composite rocker protectors, get me back closer to original dry weight of the TH…
trailhunger
trailhunger
2024 TH
Look i respect what youre doing, but i gotta say, i would rather have 5mpg than have that airdam look on my truck
you do you bud. I’ve now spent more time on tac4g on this thread than modding the plastic itself. 400mi+ tank is the goal, not what people think about how it looks. If I get there, money for more trips. If I don’t get there, who cares. Unbolts in 5 mins.
That said, there’s some sick looking rides that rock a double chin.
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_0163
Smugly1169
Doug
Tacoma, double cab TRD sport
I might have missed something, but how did you get a trailhunter with an air down? Or did you add it afterwards? And I average 20.8 miles per gallon in my trailhunter.
2024 Tacoma Modified Air Dam on a stock 2024 Tacoma Trailhunter 4th Gen IMG_4075
trailhunger
trailhunger
2024 TH
Yea the OP explains everything. Bought it for $15, made modifications to it. Current trip reports are 23mpg w/the air dam, ~65mi logged w/it installed…
DENNISD
Dennis
Omaha
From this video, it shows that you are gaining less than 1 mpg (0.8 to be exact).
If you drove 12,000 miles per year and and averaged 22.2 mpg you would use 540 gallons of gas.
If you averaged 23 mpg, you would use 521 gallons of gas.
The average price of gas is $3.16. You would save $60 per year. For the first year, you would need to subtract $15 for the cost of the chin spoiler. You now are ahead $45.00 (not factoring in the time you spent purchasing it and placing it on). Add on the fact that you most likely drove to the person's place to obtain said spoiler, you may have just broken even on the first year.
If I am doing the math correctly, to each their own. Yes, you are saving money but if you really wanted to save gas I would simply let up on the gas pedal just a touch and your savings would be even more. If you go from 65 to 60, you will save on average 3 mpg. If you wanted to save .8 mpg (what the chin spoiler would most likely achieve), you are looking at only around 1 to 2 mph less mph to achieve the same results.
But hey, if it works for you I say go for it. I just wanted others reading this thread to know the estimates that one may achieve if you are considering the same.
