- First Name
- Ryan
- Joined
- Jun 14, 2023
- Threads
- 70
- Messages
- 795
- Reaction score
- 859
- Location
- Alberta, Canada
- Vehicle(s)
- 2024 Tacoma Sport+ 6M
Towed a rental camper through the Alberta Foothills and into Kananaskis Country this weekend.
I rented a 3000lbs dry weight camper as I figured something smaller would be much better going through the hilly terrain, man was I wrong.
Let's start with the sag. Good god. I understand the hitch weight got a lot to do with the sag, and the tongue weight was heavier than average but I'd take my bet and say it wasn't far from any bump stops. I had to tighten the sway bars on the weight distribution hitch to get it as level as I could, still had some sag afterwards and was still fairly bouncy.
Starting off in 1st definitely takes a little more umph as expected, and city driving was actually quite pleasant, hardly noticed the camper (once the weight distribution hitch was setup), but highway driving was a nightmare.
The trailer its self didn't push or pull my truck at all, unless I hit a fairly big bump. But the powertrain was horrible. My cruising gear was 4th, I could do 5th going down hill or at a crusing speed on a flat. 6th, forget it exists. Hitting a slight incline I could keep my current speed in 4th by hitting a steeper incline I had to bang it back to 3rd and stay damn near on redline to gain or keep my current speed.
Going out my motor sounded fine, the turbo was definitely working overtime which do worry me if I was to ever haul a camper long trip (this one was about 150km there and back). Coming back my motor actually started to concern me. Under load going up any inclines it sounded absolutely god awful and was genuinely concerned I was going to grenade it at certain points. I can't replicate or even explain the sounds I was hearing at times, I wish I had to get a video.
Fuel milage, lmao. I didn't record it properly, but I did note what I burnt in 114km of towing the camper, I would burn in 210kms without towing, comparing it to a similar trip I take every weekend.
Overall, not impressed. This thing is rated to tow 6500lbs, and after towing 3000lbs I can very confidentiality say I will never tow over that with this truck and will really have to consider towing even 3000lbs again.
Granted, I had about 700lbs payload with passengers and gear (including myself), but still.
