- First Name
- Brian
- Joined
- Nov 13, 2024
- Threads
- 23
- Messages
- 213
- Reaction score
- 281
- Location
- Pennsylvania
- Vehicle(s)
- ‘24 Tacoma TRD OR
I believe these OR Bilsteins are similar to what certain trims of the Bronco come with. Seems very similar, if not the same shock.I reached out to Alldogs about these when they made a teaser post about having the 4G 5100s in stock. the perch sits higher on the 5100 so there should be a small amount of lift even at the bottom setting. length wise, the email states that there is less than a 1/4" difference in length between the 2 both front and rear.
Here's some photos i was sent.
Overall, these don't necessarily look like an upgrade over the factory red Bils unless you want to lift with your OE spring.
https://offroad.bilstein.com/en-us/a-look-inside-the-all-new-bilstein-escv-for-the-ford-bronco/
