Best value mid budget shocks
Best value mid-budget shocks
  • Total voters
    42
TacoTime
Forester
Hello
Although mostly subjective, still entertaining assessment of mid shocks on 3rd gen. Probably under what you’re exactly looking for but shocks seen similar for 4th gen…
Chris_2025OR
Chris_2025OR
San Diego, CA
2025 Toyota Tacoma TRD Off Road Long Bed Ice Cap
Hello
Love the shock value series. I keep hoping they're going to come out with an episode for the 4th gen.
GDTRFB
Ryon
Idaho
2025 TRD OR
Not from the center of the hub, no.
The front was measured at 37 and the rear was at 38 5/8. Both of these measurements were taken from the ground to the bottom of the fender trim.
Hope this is of help though.
That is helpful, thank you.
Did you go with the 0 or 440# rear springs?
Did you change uca’s, or stick with stock?
Are you still enjoying the ride? Any off road testing yet?
Keithz24
Georgia
2024 Tacoma Off-Road
*The rear springs are 0 to 400lbs.
*I did change the UCA's to the OME UCA's.
*Nothing crazy off road. Just a few forest service roads.
Unfortunately, I do have some bad news to report. The strut on the passenger side has developed play in the top hat. It results in a noticeable rattle while traveling down the dirt roads. Man did I go down a rabbit hole trying to find the rattle. 😩
I think it was assembled wrong from the factory. I have been in contact with ARB, and they are supposed to be sending me a new strut to replace it. They want me to send the strut that is damage back once I get it changed out so their engineers can take a look at it.
Here is a video of what is happening. Sorry for the shaking but you can really see it in the last 3-5 secs.
UPDATE
Bad news to report.
I had another top hat failure on my front MT64 struts. This time it was the drivers side. I really don't even push these shocks that hard. Just daily on smooth roads and the occasional forest service road on the weekend.
I got in touch with ARB to warranty it and they told me that it's a common issue and are working to find the exact solution. Told me that it is still safe to drive on, but I may get a rattle and/or squeak sound.
I'm on a hold list now for when the solution is found, they will send me the updated version of the struts. No time frame on that though.
Chris_2025OR
Chris_2025OR
San Diego, CA
6112/5160s are supposed to be released Q4. Feel like that’s going to be the move. I’m going to pair those with the TRD UCAs and call it a day
Do you know the part number on the 4th gen pro UCAs?
1_nutted_wonder
Frank
New Hampshire
2025 Tacoma
I have the MT64's installed. After a few days of driving, they settled 38.75inches in the front and right at 40inches in the rear. Measured from the ground, center of the hub up to the bottom of the fender trim. I have the clip on the front struts set to the second from the bottom (No Accessory added). Runing 28570r17 tires 31 psi. Ride is frailly comfy. It's a little bit firmer. Not as pillowy as the stock off road suspension was. I no longer get the cluck when going over speed bumps though. I will say that I wish that ARB offered some isolators for the bottom of the rear spring. They seem to make some seating noise sometimes when going down the dirt roads.
What setting are the Circlips set on for the front struts?
Chris_2025OR
Chris_2025OR
San Diego, CA
I finally landed on a set of shocks (Falcon 3.2). I spoke with the guys over at Shock Surplus, Ian from Wheel Every Weekend, and a sales rep from Icon to pick their brain about shocks, tuning, and my application. I'll dive into some of the research and my thought process but keep in mind, I'm not a professional and shock tunes are subjective. What's right for me isn't necessarily going to be right for you.
I'll try to keep the summary concise.
1) I wanted better high speed and weight damping, so I ruled out any shocks that were below 2.5 inch diameter (except Falcon with its 2.3in dia. body)
That means:
Eibach Stage 2, Ironman Stage 2, and Icon kits Stages 1-3 are out.
Which leaves:
Fox 2.5 Performance Series, Icon 2.5 front coilovers paired with Icon 2.5 rear shocks, Falcon 3.2 and OME MT 64.
2) Comparison
I recommend these resources to get knowledge from:
- Shock Value Seasons 1-3 + the best value episode on Youtube
- Bilstein Shock Talk Ep. 12, 13, 50 on Youtube
Fox 2.5 IFP - $2,274
- Linear piston, linear valving
- 2.5 diameter body
- No "HTO" on Tacoma versions
- UCA not required
- Notes:
There is a general consensus that FOX's "vehicle specific valving" should be taken with a grain of salt. People think that FOX uses universal-ish valving and doesn't do the same level of behind the wheel RnD as the other manufacturers on this list. The saying goes "(shock) Dynos don't drive cars, people do." However, they were highly recommended if you get them custom tuned because the parts themselves are great, the stock valving just sucks.
My $.02 - From past experience, FOX 2.0 is too soft and FOX 2.5 is too stiff. idk about this newest generation of shocks from them, and I really wanted to get these because they just seemed like the right fit for me. But I was concerned they wouldn't handle extra weight well. They weren't highly recommended by the people I talked to, and I ultimately questioned the valving for what I wanted. And the maintenance intervals aren't great.
Icon 2.5 - $2,745, $3595 w/UCA
- Digressive piston, digressive valving
- 2.5 diameter body
- rear reservoirs
- UCA recommended
- Notes: good vehicle specific RnD, compression damping is the same as 4/10 clicks on their adjuster coilovers, some people have concerns over spring and seal quality, same maintenance intervals as other "race" shocks.
my $.02 - A digressive piston with degressive valving probably isn't ideal for the small bump/trail chatter compliance I'm looking for. Race maintenance intervals. Awkward price point. Wasn't recommended for my application by the people I talked to.
Falcon 3.2 - $2,199
- Linear piston, digressive valving
- 2.3 diameter body
- rear reservoirs
- rear adjusters
- Spring top out
- Foam bump stop
- UCA not required
- Notes: some people say the seals leak, some people say they're up there with King, Fox, Icon, Bilstein. The engineers there are ex fox and bilstein employees. They spend a good amount of RnD on application specific valving and design.
my $.02 - My guess is the valving curve should be pretty good with a linear piston for higher flow on small chatter, digressive valving for control, then a progressive bottom and top out section. I'm looking for weight control and the rear shocks come with adjusters that increase damping specifically for hauling. At the price point, they seem like the best fit for me, and they were highly recommended. Falcon did put out a video about 3 months ago addressing leaking seals and proper maintenance. I'm hoping most of the defective seals can be blamed on improper maintenance from the user🤞
OME MT64 - $2,282, $2962 w/ UCA
- 2.8 diameter body
- Hydraulic top out
- UCA required
-Notes: longest lasting of the bunch, largest diameter piston, hydraulic top out.
my $.02 - 2.8 diameter body and hydraulic top out are awesome. Low maintenance. They're supposed to handle weight well given that they're designed for Australian outback overlanding. This was my second choice but, ultimately, the need for new upper control arms pushed it into a different price category.
Note: Bilstein does not yet have a 2.5 product for the 4th gen Tacoma. However, they are coming out with 6112 front struts paired with 6100 rears by the end of 2025. It's exciting to see the old 2in 5160s replaced by a 2.6 inch 6100 shock in the rear, and they would probably have been my choice as the best value shocks had they been available.
TacoTime
Forester
Updated value series video dropped today. Subjective of course but interesting at the same time 🤣.
ThatBronze4G
Lloyd
United States
2025 Toyota Tacoma TRD OR
i've been running the fox 2.5 ifp shocks for about 5k miles now. super happy with them. they ride fantastic, only real minor complaint is the front end is floaty over larger "bumps" and dips on the highway. paired with the rear ADO springs, they handle my GFC super well.
Chris_2025OR
Chris_2025OR
San Diego, CA
That's great! Are you able to provide more details about the ride, valving, damping and how they handle your camper?
px3_taco
Michigan
I have had the Ironman FCPs on for a couple months. They have been great. Big plus for them is they'll handle the salt in winters better than some of the other options. Dont buy the stage 2 kit though as the UCAs are Icons and started squeaking in under 1000 miles.
If they were out (maybe they were and I didnt notice) I may have went with the Falcons based on the Shock Value vids.
As a side note. the Shock Surplus guys really hate Ironman, to the point its comical.
Tacoyaki
Tacoma TRD Off-Road
Any idea how the Falcon, EMU, and Bilstein would handle 1000 lbs of and gear? I've been looking into upgrades as the stock OR Bisteins can't handle the higher rates of the Dobinsons 821s in the rear. When dropping off rocks/ledges or just small whoops, there's bounce that takes a little while to dampen and settle.
Chris_2025OR
Chris_2025OR
San Diego, CA
Falcon shocks are in. Off to the alignment shop then a weekend of wheeling. I'll do a full review in a about a month or so once I've used them in different conditions.
Install would have been pretty straightforward but one of the front shocks was misaligned by a couple degrees. After some back and forth with Falcon (customer service was great), they suggested I bend the lower mount on the truck and twist the lower mount on the shock to force it into place. They said it's very rare, but they have seen it before and requires some elbow grease to get the shock facing the right direction.
The Falcons are about an inch longer front and rear than the stock Bilsteins. I didn't yet realize where the front strut was going to sit on the upper mount when I took the picture, so it appears shorter in the photo. That's just because the top hat actually sits lower than where I put it in the picture. Falcon says they are 1.2 inches longer front and rear, and that seems to be accurate.
Side note: One of my rear OEM Bilsteins is already leaking oil at 5k miles.
2024 Tacoma Best value mid budget shocks 20250924_165747
2024 Tacoma Best value mid budget shocks 20250925_154945
2024 Tacoma Best value mid budget shocks 20250925_155000
2024 Tacoma Best value mid budget shocks 20250923_122643
2024 Tacoma Best value mid budget shocks 20250923_172500
2024 Tacoma Best value mid budget shocks 20250923_172511
2024 Tacoma Best value mid budget shocks 20250924_140629
2024 Tacoma Best value mid budget shocks 20250926_101900
Keithz24
Georgia
Had a chance to test drive a Hybrid Premium Off Road with the factory 2.5 inch TRD lift. Did a back-to-back test drive with my truck. I wanted to see how the Toyota lift rode. Granted it wasn't broke in. The truck had maybe 12 miles on it. I felt that the MT64 were plush compared to the TRD lift. I felt TRD lift was very firm, not jarring, but firm. Nowhere near as soft as the factory off road shocks. I couldn't help but notice how tight the steering felt in normal mode. I would compare it to sport mode while in my truck. The Premium was equipped with 2657018 tires while I have 2857017 on my truck. Overall, the Premium set higher than my truck parked side by side. I never got a chance to get any measurements though.
Anyhow, just wanted to share some info.
