JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
Got a package in the mail and was too excited not to share! We'll be posting more information and results from testing this on a variety of setups here very soon. This option will likely serve as the backbone to our upcoming "Stage 3" setup for those curious. Thought I'd share a little teaser as some of you might like to see what's coming.
100% Bolt-in
100% Stock appearing (it uses the OEM housings)
Stock Turbo Specs:
• IHI SPEC VB51
• Compressor Wheel 42.87mm x 58mm
• Turbine Wheel 51mm x 40mm
• Single sleeve bearing, no thrust bearing, dual piston rings on turbine end, single on compressor
OEM Turbo Upgrade Specs:
• Built on the OEM IHI SPEC VB51 housings w/ upgraded wheels
• Comperssor Wheel 49.70mm x 67.40mm
• Turbine Wheel 54mm x 48mm
• Prototype variant uses the OE configuration CHRA. Production versions will come with a custom ball-bearing CHRA upgrade
XXFactor
Alex
Knoxville, TN
2024 Tacoma SR
Gotta say, this is very exciting and appreciate the updates as they come in. Not sure if this would be an option for an SR model but this is great!
What else will the kit include?
JustDSM
JustDSM
Justin
Ogden, UT
Appreciate your enthusiasm and support! The turbo's used on the Tacoma are the same across all trim levels (including the hybrid models), so this upgrade would fit just like your OE unit on the SR trim.
I'm told it is likely to be offered complete with no core required, as a core option, and will be available with an optional install kit with a complete set of gaskets, hardlines, nuts, hoses and clamps to completely replace your OE unit.
I'll be sharing a list of all the part numbers for these parts should you seek to procure them yourself or just need a replacement.
what will this provide?
An approximate 40% additional airflow potential, bringing the output potential up pretty significantly over stock with proper tuning.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Would be nice to include the performance specs after this “upgrade” or no one knows yet?
Edit: Just saw your other reply. 40% increase with a proper tune? What does the proper tune mean. We need to install a tune to benefit from this bigger turbo kit?
LincolnSixAlpha
Phoenix
Can our 4bangers internals handle this 40% increase of airflow...I had to ask
I'd imagine that the lower end of this engine is fairly stout -- all things considered. Now are you gonna stuff crazy PSI and expect 1000hp outta this motor.. No friggen way, but mild increases, including a turbo upgrade, I'd have to guess would be just fine as long as you're not straying into exotic fuels and ultra high compression.
But really it boils down to the rings ability to deal with the extra compression. Unfortunately with manufacturers switching to low tension rings, I have no clue how they'd fare with the increased pressure as I've not seen inside of one of these engines. However, personally, I believe this engine is built right so I'd have to speculate that the engine will be just fine. Just my 2 cents from an age old computer network engineer (lol)
Andrace
2024 TRD Off-Road 6MT
This guy does a great job summarizing the strengths and compromises in the 2.4Turbo engine. I'm still very curious about the "crankshaft hammering" Sheldon mentioned, specific to the MT tune, but I look forward to seeing the weak links emerge as the platform is pushed.
All that said, I'm glad to see the development like this high-flow turbo. It would be super tempting to upgrade the turbo along with a Banks inlet elbow, boost tubes, and intercooler when available.
https://bankspower.com/pages/vehicle-configuration/2024-toyota-tacoma-2-4l-gas
I fully plan to put 200k plus on my truck, and in that vein would be curious if the turbo kit could be fitted with a post oiler as well.
https://www.cantonracingproducts.com/canton-24-154-accusump-turbo-oiler-compact-turbo-oiler/
JustDSM
JustDSM
Justin
Ogden, UT
Very intrigued
Glad to hear it! We’re pretty excited too — this setup has been in the works for a while, and it should finally give us the headroom the stock turbo just can’t support. We’ll be posting data from testing very soon so everyone can see what it’s capable of in real-world conditions.
We’ll have full dyno data and test results once development is finished, but based on preliminary modeling, we’re expecting around a 40% increase in flow potential over the stock turbo. On the upper end, that could mean up to ~425whp with high-octane fuels or ethanol blends. On typical pump gas, I’d expect something closer to ~350-375whp (on a gas truck). Of course, we’ll defer to the actual dyno results once the turbo is on the truck and properly tuned.
To your second point: yes, a proper tune is required. The factory calibration is designed around the stock turbo’s flow limits and won’t make use of the larger compressor and turbine wheels. With our calibration tailored for the new hardware, we’ll be optimizing fueling, ignition, cam phasing, boost targets, and torque management to safely unlock the extra headroom this turbo provides.
Great question, and one we’re keeping a close eye on, which is precisely why we perform this kind of development on our own vehicles, not on customer trucks. The short answer is yes, the internals can handle it, within reason. This upgrade was intentionally spec’d as a conservative option that does not exceed the mechanical capability of the OE engine. Toyota built these engines with a decent amount of headroom, and everything we’ve seen in testing so far suggests the internals are up to the task when paired with a safe calibration.
We’re not building “race trucks” with this package. Our entire development philosophy and upgrade path is centered on giving owners more performance without compromising the core design and purpose of these trucks. We’re not going to release anything that undermines why you bought the vehicle in the first place.
Stage 3 is meant to give the platform room to grow and to provide something with more potential than Stage 1 for those who want it, but not to turn the engine into a hand-grenade.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
100% Bolt-in
Stock Turbo Specs:
• IHI SPEC VB51
Will this work with the OTT tune 🤔 I have already?
Tacorey
Corey
Atlanta, GA
2025 Tacoma TRD Offroad; 2007 Infiniti M35
Will the stock injectors be able to keep up?
JayTech
Jay
2025 Toyota Tacoma TRD ORP
I wouldn't go by anything he says in that video for reliability. He has inaccurate knowledge. He is comparing it to the 3.5L. The old Tacoma had a 4 cylinder engine option as well and this one doesn't weigh much different than it. Also that water flow valve is NOT the thermostat. These engines very much do have a thermostat and its part of a thermostat housing. It is a completely different part that is used in conjunction with the thermostat. You should watch the video that is in another thread here about the motor straight from the chief engineer. I'd say this engine is built quite robustly. Especially seeing it was designed to make torque at low rpm which can directly affect the rods and pistons.
Not sure I’ll ever do this - but on the hybrid you think I could get 450HP out of it with this bolt on?
This truck has plenty of low end power - it’s the power band after 3,000 RPM that drops off quick. It needs more upper end power. Basically the opposite of the third gen.
