- First Name
- Justin
- Joined
- Oct 27, 2023
- Threads
- 11
- Messages
- 217
- Reaction score
- 516
- Location
- Ogden, UT
- Website
- www.overlandtailor.com
- Vehicle(s)
- 2024 Tacoma TRD Offroad
Got a package in the mail and was too excited not to share! We'll be posting more information and results from testing this on a variety of setups here very soon. This option will likely serve as the backbone to our upcoming "Stage 3" setup for those curious. Thought I'd share a little teaser as some of you might like to see what's coming.
100% Bolt-in
100% Stock appearing (it uses the OEM housings)
Stock Turbo Specs:
• IHI SPEC VB51
• Compressor Wheel 42.87mm x 58mm
• Turbine Wheel 51mm x 40mm
• Single sleeve bearing, no thrust bearing, dual piston rings on turbine end, single on compressor
OEM Turbo Upgrade Specs:
• Built on the OEM IHI SPEC VB51 housings w/ upgraded wheels
• Comperssor Wheel 49.70mm x 67.40mm
• Turbine Wheel 54mm x 48mm
• Prototype variant uses the OE configuration CHRA. Production versions will come with a custom ball-bearing CHRA upgrade
100% Bolt-in
Stock Turbo Specs:
• IHI SPEC VB51
