dvrgz
Los Angeles
Just installed a single Renogy 120W ShadowFlux™ Anti-Shading Solar Panel to my Sherpa rack.
For now, It’ll mainly charge an EcoFlow Delta 3 Power Bank in the back seat.
Share your solar setups. Still learning about this whole solar world.
2024 Tacoma Solar Panel Setups - Post Yours IMG_6529
2024 Tacoma Solar Panel Setups - Post Yours IMG_6524
trailhunger
2024 TH
BougeRV Yuma 100w CIGS. 17% efficiency. Not as efficient as the high output inverter on the Trailhunter, but a nice trickle charge while I’m parked.
For bigger trips like Baja picking up some fold out arrays. My power station accepts 600w solar, but for most use cases happy I went with just 1 panel as the truck predominantly throws the power.
Fully electric camp setup. No propane.
2024 Tacoma Solar Panel Setups - Post Yours IMG_8714
Pappy
Intermountain West
Zamp Solar 190W on top of my Dirbox canopy camper. There is enough room for a second panel, which has been ordered. Solar powers a 100ah Li battery in the camper. Battery runs a fridge, the camper lighting, the water pump, and outlets in the camper.
Solar panel on top of the camper.
2024 Tacoma Solar Panel Setups - Post Yours 20250519_160047
Plug where the solar enters the canopy.
2024 Tacoma Solar Panel Setups - Post Yours 20250519_160013
Solar controller with bluetooth.
2024 Tacoma Solar Panel Setups - Post Yours 20250708_132723
Battery and fuseblock.
2024 Tacoma Solar Panel Setups - Post Yours Camper battery-sm
gofastdan
I'm running 3 - 100 watt Renogy flexible panels glued to my Lone Peak. They charge an Ecoflow Delta 2. When on longer trips I can also plug in a Delta Max extra battery.
Due to the Delta 2 only having one solar input I'm running the solar through an ETaker F2000, which has inputs for both solar and 12v from the alternator, combining them into one output that goes to the Ecoflow. I'm limiting the total output from the ETaker to 500 watts, which is all the Ecoflow can handle. I've limited the alternator input to 400 watts. I figure that should be a safe number to protect the alternator since that's the limit applied to the AC converter built into the truck.
I've been experimenting with a couple different induction stoves and at this point pretty much am done with propane. I do have a Chinese Diesel heater for the winter but my Ignik Topside blanket is fine down into the low 40's.
2024 Tacoma Solar Panel Setups - Post Yours PXL_20250923_001517373
grizzlyoutlaw
MTN WEST
TACOMA
I just looked that up and it looks like a great panel. Withe the 120W at 41", Do you think the 200W at 49.6" wide would fit between the rails like that? Two 120Ws are the same price as 1 200W so it may be better to split up the panels.
dvrgz
dvrgz
Los Angeles
I just measured across the Sherpa Rack. Doesn’t look like the 200 would fit in-between the rack. I’ve got 48.5 from one side of the rack to the other.
2024 Tacoma Solar Panel Setups - Post Yours IMG_6581
2024 Tacoma Solar Panel Setups - Post Yours IMG_6586
Pappy
Intermountain West
I added a second panel to my camper, and upgraded my controller from a 30A PWM to a 40A MPPT. Right now the panels (190W each) are wired parallel. As soon as I get the cable, I will wire them in series.
2024 Tacoma Solar Panel Setups - Post Yours Twin panels
2024 Tacoma Solar Panel Setups - Post Yours 40A controller-sm
2024 Tacoma Solar Panel Setups - Post Yours Fuse Block-sm
