Rubenc87
Ruben
2025 TRD PRO
Thanks for the post, I added the Sport Bar to my Taco cause I like the look, then after getting it as I was installing it I thought "how can I get a tonneau cover on it now" LOL I was thinking of doing the same thing you just did but I like the flush roof/Sport Bar look. :headbang:
Looks good.
Sommebitch
Jarret
2025 Trailhunter
Great thread. I considered keeping my ARB rack but took it off. I have the same tonneau cover as yours. Great combination on your part.
I looked at that as an option too, but it looks like the Diamondback flips up? If that’s the case, you could cut the mounting tabs off the sport bars and bolt them to the top of the cover. The limitation would be that the front section of the cover would only open 60% ish.
I’m going to look into that .. I wouldn’t mind .. it bugs me I can’t use the sport bar
Hatman
Hatman
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
Happy to send more photos/info if you have questions.
FunTaco
Julia
Big props to you for cracking the code on this one! I live in the PNW and for me, the rain makes the truck bed unusable w/o cover 5 months out of the year - but I've agonized over removing the sport bar.
I've completed the cuts on the bar and getting ready to drill the holes for attaching via the T-slot bolts. Did you retain/reuse the foam that came with the ARB Sport Bar? Also, did you run into any challenges with rattling or vibration having changed the way the bar is anchored? Any tips there?
Thank you so much!
Hatman
Hatman
Argyle, TX
Thank you so much!
I didn’t reuse the foam padding. I bolted it directly to the T rails and it doesn’t rattle at all. It’s really solid on there. I did buy some 1” marine foam to add to the bottom where it hangs over the edge of the rails (just to fill the gap), but never used it since it doesn’t really look bad the way it is.
Airborne
Upstate,NewYork
Looks great very nice work, thank. You for sharing , would love to be able to fit the O.E.M. Cargo divider ,with the OEM Bed cover, if you do that please let us know
thank you
heavylunch
Wisconsin
2025 Tacoma Bronze Oxide Trailhunter
Did you notice any change in wind noise with the 3/4" additional height gain on the roll bar? Thanks!
Hatman
Hatman
Argyle, TX
I drove it before and after with the back window open and there is no difference in wind noise. You can compare this photo to your setup and I think it actually raises just enough to make it more streamlined, so the air flows under the front edge of the bar rather than into it?
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_0513
heavylunch
Wisconsin
Nice. I am hoping to get a Trailhunter soon and would like to do this same mod. I am really appreciative of you sharing the details of how you did it.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I have this ARB adaptation on my growing list of truck and house chores to accomplish. I have a Trailhunter with 6’ bed. What would you like yours to have?
heavylunch
Wisconsin
I ended up getting a year end 2025 Bronze Oxide Trailhunter with the 5 foot bed. $4000 off TSRP, seemed like a good deal to me. I plan to do this same exact mod to the ARB rack with the Retrax Pro RX tonneau cover. I am hoping my angle grinder skills are up to the task. I am assuming that is the tool of choice for cutting the metal and then grinding it down.
lauren01
Lauren
Ventura, CA USA
I’m wondering the same thing about the tool. All I have currently is a multitool. I hope I can find a friend who will help me cut with the right tool.
