17 x 8.5 better than 17 x 7.5?
greenno
San Diego Cal.
2026 Tacoma Offroad
Just picked up a gen 4 and immediately swapped out the tires to Wildpeak 285/70 r17 tires and kept my original stock tacoma wheels.
Looked ok as I had also popped in some RC 1 1/2" spacers in front to level it out a bit.
Here is a couple of pics with the stock rims 17 x 7.5 +55 offset.
2024 Tacoma 17 x 8.5 better than 17 x 7.5? IMG_0568
2024 Tacoma 17 x 8.5 better than 17 x 7.5? IMG_0586
Now my conundrum.
Just got a good deal on some Method 305's in black sized at 17 x 8.5 and +25 offset and popped them on.
Maybe its because the rims are 1" wider making the tires look fatter, as they are of course, but looks a little odd to me.
That being said I am getting a Dirt King pre runner kit installed next week and so that will raise the body a bit and create a larger gap/space around the tires next to the body making it look more proportional in my eyes.
Here's a couple pics of the methods on.
Which look better?
Fire away.
2024 Tacoma 17 x 8.5 better than 17 x 7.5? IMG_0590
2024 Tacoma 17 x 8.5 better than 17 x 7.5? IMG_0588
Probably just being a little girl....
Looks good to me, being a long bed it will last ok fantastic when lifted 🤩
Will721
Will
Quad Cities
2025 TRD OR
Looks fine to me, but I suppose I'm not entirely sure what you are referring to. Are you meaning that the wider wheel makes the tire itself look funny, as in less "balloon" or are you referring to the different offset pushing the tire outward and away from the fender?
greenno
San Diego Cal.
2026 Tacoma Offroad
What I mean is the tire is wider and maybe doesn't have as tall as look as it did with the narrower rims.
Im hoping after getting the lift to space the tire away from the body it will look more proportional, for me anyway. Going from the +55 on the 7.5" wheels to the +25 on the 8.5's sticks me out about an inch more or so which is fine.
Will721
Will
Quad Cities
2025 TRD OR
I see, that's what people around here refer to as "poke", or how much it pokes out from the fenders. Your current setup with the methods is probably the most popular. Raising the suspension will pull the front wheels in slightly but not the back, but you can always go back to stock. Even if you sold the OE wheels most would make that trade with cash on top for the methods.
Btw the increased "poke" is supposed to be ideal for larger tires especially off road. Also, you'll probably wanna upgrade those mudflaps to a set of Arks or something if you end up keeping that setup. They OEM barely does the job at stock offset.
BLtheP
TX
I like stock much better, but I pretty much don’t like any aftermarket wheels in general.
Airborne
Upstate,NewYork
Truck looks very nice, from pictures you seem to be doing nice job, enjoy your taco
Yotota
SW WA
24 TRD
Every tire model and size has a specified wheel width range, per the manufacturer. Running a wheel on the wider side of that range can give a bit better road handling, at the expense of offroad performance (especially when aired down). Vice-versa for a narrower wheel.
Yotota
SW WA
24 TRD
"Poke" is created by tire width and the offset of the wheel. Wheel width does not have any impact on "poke".
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Guess what will go through your mind after the lift… I need 35” tires now. :)
I installed 285/70/17 wildpeaks on my 0 offset wheels immediately after I purchasing my truc with stock suspension. This is My first truck ever and km contemplating going 35” but with the zero offset I’m certain to trim.
2024 Tacoma 17 x 8.5 better than 17 x 7.5? 178248B9-5805-4051-9DC9-7D39863E8ECE
izzy
Bay Area
True, generally when wheel width is increased, the added width is "inside/car side" of the centerline of the wheel. You can increase width and have the same offset.
ie 17x7.5 +45 vs a 17x8.5 +45, same offset, just more wheel inside the fender.
Now my conundrum.
Which look better?
Fire away.
I also run 17x8.5 and it looks awesome - I think that’s what you should be running for 285s anyway.
Yotota
SW WA
24 TRD
When wheel width is increased and offset stays the same, half of the width change is on the inside of the wheel and half is on the outside of the wheel.
But on trucks like ours, the tire is always wider than the wheel. So the wheel may get wider, but the tire stays in the exact same place.
"Stance cars" with stretched tires that are narrower than the wheel gain more poke with more wheel width.
This calculator is accurate and a great tool. Notice that wheel width is not a variable:
https://tiresize.com/wheel-offset-calculator/
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
so what is the maximum tire width can my 17x8.5 wheels accommodate? Can I safely go to 315?
izzy
Bay Area
True but just because you have a big wheel doesn't mean you will for sure poke.
I have 17x9.5 +45 TE37SL on my WRX hatch but it doesn't poke because of the +45.
I've found it takes almost nothing to get "flush" fitment on these truck if you have an SR/SR5. 265s on 17x7 sticks out a little beyond the fender.
