Will721
Will
Quad Cities
2025 TRD OR
If they install the same as ark flaps there's no hardware change required. The bolts and plastic grommets are already there holding the flare and fender liner. Just pull out the bolts, position flaps, and put them back in. Arks came with a bit different style of bolt which I used but weren't necessary. Frankly the easiest install of mudflaps on any vehicle I've seen.
ScottyMcfly
Scott
Western Mass
2025 Tacoma
Awesome, thank you.
PNWkip
2025 DCLB SR5
Those are the ones I was thinking about going with. Do I need to get the inserts/fender grommets to install since my truck didn't come with flaps ?
We don't have flares and I didn't have OEM flaps so I didn't have any hardware on the truck, just female fender grommets, but both the Arks and the Tufskinz come with their own hardware that will screw right into the female grommets on the truck. I ordered a back of 100 grommets for like $1.50 on amazon in case I stripped any.
Leucosia
San Diego
2025 Trailhunter
Did a mini road trip over the weekend to Vegas. Our office participates in a 120 mile relay race from baker to Vegas and I was a support driver and ended up running one of the legs of the relay because the original runner couldn’t make it. This is me getting home on Sunday. Not pictured is the hour or two the next day cleaning all the dead bugs off the front and reapplying some griotts 3in1 and rainx ceramic.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 IMG_3624
Halifax, NS
2025 TRD Pro
Recut new fog light vinyl and installed, would someone be able to measure their non rigid OEM fog lights and tell me if they’re 5 15/16” x 5/8”, wondering if any of the thicker inserts would fit
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 IMG_0903
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! 👨‍🏭 🧰 📸 IMG_0906
