2024 Tacoma Transmission Overheating on Long Climbs Off-Road
izzy
Bay Area
Yea, I'm nowhere near redline (6Kish) I'm normally puttering along between 1800 and 2300, which seems to be the smooth mostly quiet range. If left in D, it would drop down to 1300-1500, and I think that's where we are seeing the heat issues. Remember the engine isn't overheating, the transmission is. And those lower RPMS and high torque load really heat up the transmission.
I think the issue is a combination of that ^
and this:
2024 Tacoma 2024 Tacoma Transmission Overheating on Long Climbs Off-Road 1000006177
A lot of torque + not locking the torque converter up to protect the drivetrain and for economy = making a fking ton of heat.
hadelson
NE Pennsylvania
24 Tacoma Trailrunner
The cause of the issue is a Toyota engineer failure to design a cooling system with the ability to keep the transmission from overheating under normal offroad use. It's really that simple and the root cause. My old 17 4Runner TRD Pro no matter how hard driven or run off the road had these issues.
izzy
Bay Area
The cause of the issue is Toyota engineer failure to design a cooling system with the ability to keep the transmission from overheating under normal offroad use. It's really that simple and the root cause. My old 17 4Runner TRD Pro no matter how hard driven or run off the road had these issues.
There's gotta be more to it, the AL80F runs hot even on the street (compared to other ATs). Unless Toyota releases a TSB or other information on the safe operating temp of the AL80F, with fluid change intervals, it's all speculation.
I agree that this seems really odd. My Tundra transmission fluid never climbed like that no matter how hard the truck was working. I will add it to my list of stuff we don't understand about our 4th gens and that Toyota has not bothered to explain.
hadelson
NE Pennsylvania
Thanks for that link @hadelson. My Tundra was older, with the 5.7L V8 and once the transmission fluid reached normal temp it never moved. It sounds like the problem started with the V6 engines in the newer Tundras.
That is what frustrates me. Things like this come up and either the dealers just flat out lie or Toyota never says a word about what is going on. That leaves us with trucks that we don't know if we can trust and we have no idea if Toyota knows what is going on or even cares.
Interesting thread @hadelson. I think the problem is having a heat exchanger instead of an actual transmission oil cooler. Both my 2nd gen Tacoma and my 2nd gen Tundra had real transmission oil coolers and they were fine. I think Toyota cheaped out with this setup and it is another thing we have to fix on our own. Kind of like Off Roads that can't be driven off road withough breaking through their top hats. Or my Pro that can't keep its 12V battery fully charged. Or my friend's SR5 that shifts like a drunk teenager making their first try at driving a stick.
Gfenza89
Gary
2022 tacoma sr5
Yup….crazy times we’re in, oh and Toyota field technicians that also don’t care and are more useless then the dealership.
BAQ717
Brian
‘24 Tacoma TRD OR
Toyota will eventually address this, it’s only a matter of time. I’m sure they’re gathering data and working on this as we speak. These vehicles are too important to their reputation. Maybe that’s me trying to see the glass as half full but I believe they’ll make it right.
Gfenza89
Gary
2022 tacoma sr5
Maybe you’re right, they sure aren’t making it easy to have much faith in their products lately that’s for sure.
I hope that you are right! I know that some other issues with Toyotas has taken a long time for a resolution and maybe they will figure this out too.
2nd gen Tundras had problems with their air injection systems and that was not resolved for years. They did figure it out, but only after a lot of people had trucks going into limp mode at random times and places. It was a fairly simple problem but it was not really fixed until the fifth year of production. One owner made up a little circuit board that plugged into the harness for the air pump. It told the ECU everything was fine and shut down that system. It was a common enough problem that he eventually sold them online to other 2nd gen Tundra owners.
Muckle
Washington
NA
I climbed about 4,000ft yesterday in both 2WD and 4Hi at about 5-10mph with temps in the 80s and while the trans temp did rise, it didn't get close to redlining nor did it go into limp mode. This continues to be my experience whether I'm towing or not. Thankful for no limp mode, yet.
TheDo114
Ford Ranger Tremor 2021
New Toyota's need to be put in 4LOW much more than before. Tundra is having the same issue as well. It honestly fine to run in 4LOW, we can go pretty fast with the amount of gears that newer trucks have, but it's annoying to put it in 4LOW all the time.
Nor Cal
2024 TRD Off Road Long Bed
I added a transmission cooler to my 24 trd off road.I learned with my last truck, a ram 1500, that I shouldn't rely on the dealer or brand to fix it. The truck would overheat when towing. They'd just tell me that they couldn't replicate the problem.
How do temps run with your cooler? My temps regularly get into the low 200s when off-roading, sometimes 220.
