Loading...
slater
san diego
2024 tacoma sr5/2wd, white
im not reading all this.....
I had the chirp in my previous sr5 & now my sport.
Had the compressor replaced under the tsb & all has been find for about 4 months now?
TSB came out just as I was parking at corporate.
I have a good relationship with the shop. foreman at my dealer & been a tech myself for so long...
They reached out to toyota & there was no reason to throw a compressor at it till a revision took place.
No point in throwing the same faulty part at it.
All is good now!
BLtheP
TX
All is good now!
I’m thinking I’m going to buy the TSB part and attempt to replace myself without opening the charge lines up. I won’t buy it until it’s on Black Friday discount. Just not really interested in them opening up the system if it can be avoided. Am I crazy for that stance?
slater
san diego
Maybe....
I wasnt an AC guy....
I do recall my AC guys hammering on compressor clutches pretty hard with a rubber mallet though...
Worse case, remove the fan so you can get more swing, you will have to look at it...
So youre out of warranty???
https://dot.report/bulletins/MC-11029895-0001.pdf
lxs123
24' TRD Offroad
My AC clutch was replaced by dealership under the TSB, no more chirping sounds. They did however had to recharge the AC afterwards which was all covered under warranty. Make sure to check if they plugged the rad fans back in, its a common issue where the tech forgets and then you end up overheating, thankfully i caught that pretty quick.
mrgooden
Richard
Chesapeake, Virginia
[/QUOTE]
Well, picked my truck up after completion of the TSB. This is the second clutch installed in the 2 years I have had the truck, but the part number for the clutch for the TSB is different, so I assume something changed.
Either way. First time starting the truck without a double chirp in months. Oddly enough, while waiting on my keys, I heard a double chirp after a vehicle started. Turned to look. Shocker, a Tacoma.
It took about 6 weeks for the chirp to return on the last clutch. Hopefully, it stays gone now.
Richard
About 2 1/2 months later, truck is still quiet. Just posting a follow up.
Richard
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Had mine done today. Had been chirping since day 1. Stupid local dealership fought me on it on more than one occasion. Luckily second time I came armed with 10 different videos of it chirping 4-5x on the first minute after startup. Even with those, they still didn't want to do it. Looking forward to starting it cold tomorrow and not hearing that stupid noise.
Got a brand new Corolla for a loaner. Surprisingly nice place to spend time. I'd actually buy one of those. I like how simple and smooth they are. 45mpg doesn't hurt either.
iron.head
Michigan
2025 Tacoma TRD Off-Road Premium
Why would you pay for it out of pocket?
BAQ717
Brian
ā€˜24 Tacoma TRD OR
So far so good with the TSB my chirp has been remedied. An unexpected benefit was that the AC engagement has been less rough and less noticeable when sitting at idle. Highly recommend for all of those OCD people like me.
jahpahneh
HI
2026 TRD OR TACOMA, started chirping at around 2,000 miles. The chirp is definitely quieter than my 2026 though, but still annoying. Noticed that the chirp is louder when I’m on the throttle.
I wish they would make this a recall. I'm out of warranty now but have the chirp fairly consistently now
jahpahneh
HI
Yes I wish it was a recall, I took my 2024 in multiple times and showed video with the chirp on start up. They could never reproduce the chirp, that may sound familiar to a lot of 4th gen owners. I do wonder if the 4Runners chirp like the Tacomas.
SKYRNCHEXP
MIKE
KNEEVADA
2024 TACOMA SPORT
After a replaced compressor/clutch last year for the chirp and it only lasted a couple days. I finally got the TSB done a couple weeks ago and it has been noise free. The clutch kicking on is still pretty noticable at idle. It seems if I raise the idle rpm 50-100 rpm it goes away. Wonder if i can get the rpm raised with one of the tunes avail once i go that route
Got mine replaced today $1075! Thankfully I did get the 5yr 100k warranty ($895)
T-SB-0016-26 February 26
Part number T,8841060530 CLUTCH ASSY, M
Labor $308.31
Parts $766.79
Strange but I think my MPG’s are better by about 1-2?! Could a bad AC clutch cause extra drag on the engine šŸ¤”
No more chirps and squirrel cage sounds šŸ˜Ž if the noises come back I’ll be sure to report here.
wretnuh
AZ
25 TRDOR
Got mine done last week under warranty. Worked great, no chrip since then. Go prepared with vids, as the redacted techs couldn't reproduce the issue the first go around. Sent the videos & gave them the instructions of starting it all the way cold with AC off, let RPM's come to regular idle, and then turn the AC on (with hood closed). This was my only surefire way of getting the chirp to fire. They reproduced it and replaced the clutch assembly. ~1k parts + labor. They then proceeded to not install one of my clamps on my inter cooler hoses correctly which caused my rig to throw a 'reduced power see dealership flag' on the drive home <1 mile out. They gave me a loaner and fixed it same day. So, check your clamps and your fan plugs after this TSB is performed.
