Goriders
2024 Tacoma Sport Plus
I’d get both. Or maybe I should say, I’m getting both. I towed the trailer for a half hour or so. I wanted to see how it handled in general at highway speed. I also wanted to go up a decent hill.
I did both of those things. It handled awesome with the hitch and the engine didn’t struggle going up the hill in tow mode.
Fuel economy went in the dumpster though. I usually get around 22 mpg on the highway as an average. I was around 11 mpg towing the trailer. So we’re going to have to plan trips that have gas stations along the way.
Only had about an inch of squat once the trailer was hooked up with the wd hitch. Which was better than I expected.
Trailer brake controller worked seamlessly as well. I set the gain around 6.0.
Goriders
Advice I would give from all of my research is watch your payload limit. That’s what runs out first once you add up people, gear and the hitch weight
just_rich_young
Lawrence, KS
2025 Tacoma TRD-OR
Just did KS, NE, IA, SD, CO and back to KS. No WDH and it towed fine. MPG were around 11 to 14 in the mountains and 7 to 8 in KS at 75 to 80 mph with a headwind.
2024 Tacoma Anyone brave enough to tow a camper yet? I was. PXL_20260912_201514142
Mrknowitall
SE MI
20 Silverado, 22 XV
Which one do you recommend
The blue ox is highly recommended anywhere trailers are discussed.
I have the Camco Eaz-Lift TR3 and its fantastic. Best for consistent loads, as adjusting the spring tension takes tools. Sway control is much better than the friction bars.
So you’re recommending weight distribution - not just sway control
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Guys I want to tow a side by side (2,000 pound mule) on a 14 foot BigTex trailer (double axle, 1400 pounds). I assume I’ll need a sway control device? Has anyone tried pulling roughly this amount of weight in this configuration?
Towing about the same, side by side is around 1800lbs. With the dual axles it has been solid as a rock. No sway what so ever with just a regular hitch. I even move the weight back towards the rear axle to gain 1.5" of height at the hitch and still solid as a rock.
Exactly. Buddy of mine says I probably don’t need anything.
