Banks Pedal Monster
GZShiny
Las Vegas
Finally got around to installing a Banks PedalMonster on my 2024 TRD Sport. Crawling underneath to get to the accelerator pedal connector was a pain, to say the least. 😅
I started with the Mid mode at Level 5, and wow—it definitely woke the truck up. I’m curious how everyone else has theirs set up.
What mode and level are you running? Have you stuck with your original settings, or did you end up dialing it back after living with it for a while?
reg23x
reggie
chicago
2025 Toyota Tacoma Sport & 2025 Toyota Tacoma Off-Road
I've had it for 3months and i have it on High Torque, level 5 and trim set to 5. anything higher is too much imo. Throttle response was vastly improved and i feel my mpg improved as well. I think the OTT is something to consider down the road, but i like the flexibility of disabling the pedeal monster as well as removing it easily for maintenance visits to my dealership.
GZShiny
GZShiny
Las Vegas
Yo! Thanks for chiming in! I find it interesting that your mileage improved, however slight, on High, #5. I like the flexibility of increasing or decreasing torque depending on the situation.
Sticking to 2 in mid for daily driving.
redlimitediforcemax
Oregon
2024 Tacoma Limited I-force Max
Sorry to burst your bubble, but no pedal commander or similar device will give you more torque. It merely increases throttle input position and input sensitivity. I like to say its the equivalent of wearing platforms or boots that push down on the pedal further with less foot pressure and effort lol. The power output is 100% stock with zero gains.
gmalkmus
SW Missouri
I don't understand why people can't seem to understand this. You'd think it would be common knowledge at this point.
redlimitediforcemax
Oregon
I have a good example of this. I have two shoes I wear every day. One is my regular comfortable shoe that I wear most of the time and the other is my steel toe work boot. Whenever I wear my work boot while driving, I have to completely readjust my seating position because the extra inch of padding on my boot pushes the throttle down much more than my regular shoe and for that reason my acceleration is more rapid and twitchy lol. My normal seating position and my work boot seating position is the difference of 1 inch of pedal travel. I also switch it to eco mode because the throttle is more linear in that mode. The pedal commander, sure it's programmed with different settings but the results are similar.
Andrace
2024 TRD Off-Road 6MT
I usually have it in the high-torque range, mid-range of those settings. I'm just aiming for a linear slope of the throttle map. Wakes up the response and "makes it feel how it should be".
MJB4450
Arizona
2025 SR5
I agree they make the throttle respond as it should have been from the start. But I'm wondering if anyone who has ever used any brand of these devices has noticed increased downshifting. I once put a Pedal Commander on my Challenger and set it to a high position. Drove it for a while and not only noticed increased shifting but also had the smell of transmission fluid. Red flag on that. I set it to a lower setting and no issues after that. So something to maybe monitor for a while if you go with the aggressive setting is your trans fluid temp.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
That isn't surprising at all if you've read any of the posts above yours. More throttle input... more revs... auto transmissions will downshift to get you the power you're telling it to provide. *magic*
