Follow-Up Trailhunter Pulse Vibration 30-40 MPH
JeffG
Tacoma4214#
2024 Tacoma Trailhunter
I had posted this several months ago regarding my 2024 TH pulsing/vibration at 30-40MPH.
Dealer confirmed the problem during 2 visits and I paid $75 tire balance recently with 5,000 miles (Claimed all were off >2.5 oz) still the same problem. (They refunded me $75 after yesterdays test drive)
My 3rd visit yesterday, after they had a new TH in the lot. The service manager and I confirmed the 2025 TH has the same issue.
We then drove a Tacoma TRD, SR5 Hybrid than a base 4 cylinder. ***They all did the same thing!
They are offering me a great deal on a Tundra TRD I’m considering.
I’ve seen no similar issues posted on this forum but when I did an internet search tonight I found this.
Guessing future class action lawsuit… but I don’t see anyone here with the issues or how it was resolved.
A common issue reported in both the 2024 and 2025 Toyota Tacoma is a vibration or shudder felt at speeds between 30-40 mph. This issue can be quite noticeable at a constant speed in that range and may be accompanied by a hesitation during acceleration or rough gear changes. Some owners have described it as a feeling like the engine is misfiring or dropping a cylinder.
Here's a breakdown of potential causes and solutions:
Possible Causes:
  • Tires/Wheels:
    Out-of-balance tires, cupping, or even mud buildup on the wheels can cause vibrations.
  • Driveshaft:
    A bent driveshaft or worn U-joint can also be a culprit.
  • Engine:
    While less common, a slight engine misfire or issues with the engine's low-end torque can contribute.
  • Suspension:
    Issues with suspension components, like control arms or ball joints, can also cause vibrations.
  • Needle Bearing:
    Some owners have reported issues with the needle bearing in the front differential, especially after lifts.
  • Transmission:
    While less likely, some owners have reported transmission issues, including rough shifts and hesitation.
Troubleshooting Steps:
  1. Tire/Wheel Inspection: Check for cupping, balance, and ensure there's no mud or debris causing imbalance.
  2. Driveshaft Inspection: Inspect the driveshaft for damage and check the U-joints for play.
  3. Engine Check: Consider having a mechanic check for misfires or other engine issues.
  4. Suspension Check: Inspect suspension components for wear or damage.
  5. Dealer Diagnosis: If the issue persists, take the truck to a dealership for diagnosis. They may need to contact Toyota corporate for further assistance.
  6. Consider a Third-Party Shop:If you're not satisfied with the dealership's diagnosis, consider taking it to a reputable tire and wheel shop for a thorough inspection.
Important Notes:
  • Some owners have reported the vibration being described as "normal" by dealerships, but this is not always accurate.
  • Some issues, like the needle bearing problem, can be addressed with aftermarket parts like the ECGS bushing kit.
  • If the vibration is felt in the seat, the issue is more likely in the rear, and if felt in the steering wheel, it's more likely in the the front end
I have similar on my LTD HV.
Dealership claiming something is normal just because other vehicles also do it is the most absurd excuse I've now encountered. If the vehicles are so missing a lug nut, does that make it normal? In my case they even refused to do a road force balance test or alignment without me paying for it directly. They even had the guts to claim you can't do an alignment check without doing an alignment. (End pissed off rant)
I'm in the midst of trialing whether octane makes a difference. As much as it *shouldn't* I'm out of brainstorming options on what I can try beyond an OTT tune cost. I had the wheels balanced and the alignment performed at a tire/mechanic shop that I trust over the dealership. I personally couldn't identify a difference or change to behavior based on drive mode (normal v sport v eco). I don't drive a lot so the experiment is really drawn out. But so far I *think* what I'm noticing is that on 87 octane the back of seat vibration shudder occurs pretty pronounced at low rpm between 37 and 47 mph. When fully on 93 octane I *think* the effect is both dampened and shiften to more the 29 to 34 mph range.
This is one case where I wish I drove more so it wasn't such a memory recall.
Chico
Arnaldo
2024 Toyota Tacoma
I have a 2024 Toyota Tacoma Trail Hunter with just over 5,000 and I have not noticed that issue on mine. I drive 30-40 MPH quite often, as I am retired military and drive on the military base quite often, but honestly I haven't had that issue with mine at all. I only use the recommended 87 octane Top Tier gas. I also drive mine on ECO mode all the time.
TFOUTS
Timothy
Northwest Florida
I haven’t seen this on my 2024 Trailhunter but my truck is out fitted with all kinds of stuff (extra weight). I also drive an eco mode.
The sensation bring describe here is mild but noticable. It's not jaring or in your face. Low rpm, easy on the pedal. There is a very distinct "driving sensation" change crossing into the zone, once in it's a mild sensation on your lower back and your legs, you can see it vibrating a bottle in the cup holder, but the steering wheel is dead calm. And as you cross out of the zone it all goes away and becomes incredibly smooth again. You're almost minimally feathering the accelerator pedal. If you speed up too quickly or slow down too quickly or have it running at a higher rpm for some reason, it does not occur.
Mycool
Michael
US
2025 Tacoma TRD Pro
I’ve got a 2025 TRD Pro and notice a vibration between 42-47 mph and then again over 80 mph.
Thought it was a balancing issue so took it to a tire shop to have balance. They balanced the wheels but said the tires had a flat spot so the vibration would come back.
Sure enough a couple days later it was back. Taking to a Toyota dealership tomorrow to see what they have to say
Let us know. I'm still on Factory/OEM General Grabber tires.
I was trying to play around today, and I was not finding a real difference on Eco vs. non (due to other comments above I tried again).
It appears to kick in when between 37 and 47 (most noticeable as you said around 42mph until crossing to 48mph). looks like it needs the RPM between ~1500 and 1600, and the turbo has to showing no used or barely showing anything on its meter.
Let's keep sleuthing together since our dealerships don't give a...
bemmster
2025 Trailhunter Long Boi
I thought I had a slight vibration between 30-40 on my TH. It was the tires. Its gone now that I have Toyo 35" tires. Not sure about other models but the tires coming with the tock THs have lots of balance issues. If you look them up on Tire Rack all the comments are people not being able to get them balanced.
@JeffG I looked up this thread because I remembered reading it and being glad my Pro wasn't doing anything like that. That was until today, when it did it with constant throttle between 30-40 mph. It was exactly like what you described. It felt like the engine was constantly cutting in and out causing the whole truck to vibrate. I have had this truck for over a year and it is the first time it has done this. But I doubt that I have driven at a steady speed in that range very often before and maybe the problem has always been there. But I am certain that it was not a tire or drive shaft problem because the engine sound was pulsing at the same rate as the vibration shaking my truck.
Now I will see if I can duplicate that. If I can I don't think I would be able to accept a truck that at certain speeds vibrates like a 20 year, worn out POS. I think it was caused by either the engine or the transmission, but that is just my guess. Did you ever make any progress with getting this fixed on your TH?
redlimitediforcemax
Oregon
2024 Tacoma Limited I-force Max
Might be something to do with the hybrid system and transmission/torque converter. The more throttle you use, the less you feel it. Using a lighter and constant throttle application, you can feel it like it's pinging. I did get it OTT tuned at one point and the problem persisted so I don't think it's a timing/tune issue. It's probably mechanical.
So far I can't make this happen again, luckily. These transmission are definitely not consistent in how they work, so I guess that is not a surprise. I have shifts into reverse that are smooth as silk and ones that sound like high centering the transmission on a rock, but mostly it has been fine since about 1k miles.
My truck is covered by the TSB for debris in the torque converter, so it makes sense that could be part of the cause. I can't help but wonder if it will impact how long these transmission last, but Toyota has not said anything about this beyond the TSB.
Darn it... I was really hoping that an @JustDSM OTT tune would have adjusted the throttle and shift points just enough to negate it.
I wonder if it's something Justin would be able to identify and tweak for in their wizardry with the right direction and test rig to recreate it. I know I can trigger it on demand, but I'm a few thousand miles away.
Outside of this (and it's 1/3 strength repeat up in the 62-73 range), my engine and shifts are so smooth from stock. Forward and reverse.
Yotota
SW WA
24 TRD
Bringing this back to the top...
My 2024 TRD OR just started doing this at 9700 miles. It seems to vary a bit, but when it's bad it's BAD. My dealership initially said it's "normal" but after opening a case with Corporate Toyota I'm going back in next week for another appointment.
I'm getting pissed at the situation.
Anyone else find a solution?
TFOUTS
Timothy
Northwest Florida
My trail hunter is at 26,010 miles. I have not experienced anything of the vibrations, I am curious to know that if you have a trail hunter that is doing this, what is your truck number off the assembly line?
pepco
Jim
Raleigh NC
2024 LC, 2025 Tacoma TRD Pro
I notice this to sometimes on my 2025 Pro, happens at low RPMs around 43 to 46 mph. Goes away if I accelerate or when I get to about 48 mph. Seems to do it more when engine is cold.
