FRONT ALIGNMENT HELP NEEDED
zaidenrk
Zaiden
New York, NY
2024 Tacoma off road premium
In need of some help aligning the front of my truck. I have a 2024 Tacoma off road hybrid premium. I recently upgraded from stock suspension to
Front trd pro UCAs
Front trd pro struts
Dobinson .5 inch rear springs
Trd pro rear shocks
The front wheels look like they have some positive camber/caster. I am technician for Land Rover and have access to a Hunter alignment rack at work. I have adjusted camber/caster many times, and toe I just can’t seem to get the wheels cambered in to look even. I don’t know if the truck is supposed to sit this way or if I’m doing something wrong. Attaching pictures to see if anyone with a trd pro or any Toyota mechanics or alignment guys can help me out. According to the machine this is within spec. But front wheels look a little cambered out, I’m worried about wearing the tires out. Also based out of Long Island, NY and willing to pay someone who can help me fix this. Thanks.
2024 Tacoma FRONT ALIGNMENT HELP NEEDED IMG_9471
2024 Tacoma FRONT ALIGNMENT HELP NEEDED IMG_9472
2024 Tacoma FRONT ALIGNMENT HELP NEEDED IMG_9473
Mercedes
ā‰ˆ39N
2026 TRD Sport "Mercedes"
Doing some self-study, I found the attached: an alignment procedure for the '24 Tacoma HV.
Posting here as a reference for anyone interested.
rybern
Ryan
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
Having just over 1° positive camber seems to be within acceptable range. I don't like it and I don't understand why. 0° camber is also acceptable. I asked my alignment shop to get my camber as close to 0° as possible and they were able to do this for me. I have a TRD OR with 1.5" front/rear lift via All Dogs Offroad springs (everything else is stock). So you have even more adjustment than me with the UCA's. My Truck drives great with these numbers. Tires are 265/70r18.
2024 Tacoma FRONT ALIGNMENT HELP NEEDED 20260326_195926
2024 Tacoma FRONT ALIGNMENT HELP NEEDED 20260405_183528
zaidenrk
zaidenrk
Zaiden
New York, NY
Yea yours looks, more flat. What size tires are you running?
zaidenrk
zaidenrk
Zaiden
New York, NY
I have the same size tires just falken wildpeak at4
zaidenrk
zaidenrk
Zaiden
New York, NY
Can
Can you possibly post a pic of the right side of your truck, like the way I have posted. I wanna compare that side.
pepco
Jim
Raleigh NC
2024 LC, 2025 Tacoma TRD Pro
I have a Pro, my front tires are like that, drives fine and tires are wearing even so far.
zaidenrk
zaidenrk
Zaiden
New York, NY
I see so this is normal then. Thanks for the response.
exia
los angeles
24 tacoma hybrid Trd OR
Have you tried the Trd geometry correcting parts ?
zaidenrk
zaidenrk
Zaiden
New York, NY
I have trd upper control arms. Everything else is the same as pro. The lower control arms which have the camber and caster adjustment are the same as a pro
exia
los angeles
The tie rods and lower bracket should be different I would think because the lift kit ones are. I have 2 in lift and got the trd geometry correcting parts off the trd lift kit.
wongaust
Austin
Washington
I have stock TRD OR parts with Bilstein 5100 lift and they also look the same. No uneven wear observed so far (5000 miles on my tires)
Ascent
Bill
Alabama
4G Tacoma, 3G Tacoma, 5G 4R, 4G 4R
Mine also looks the same. I have an 26 SR5 with Bilstein 5100. About 2ā€ of lift. I took my truck into a mom and pap alignment shop. They worked on it for a couple hours and couldn’t get it to look straight. It’s been like that for the passed 3k miles.
It does still bother me though.
