k1m
Nathanial
usa
I also just sent an email. Thank you for your help.
taco4moro
Los Angeles
2024 Tacoma TRD ORP
i've been running the ICS Fab dash mount for the last few months and it's been really solid. only have need for a handheld GMRS but it has enough space to mount radio boxes and more.
the 2 hole amps ball mounts with 3" arms on either side are the best mounting points to keep a phone/radio/mic tucked in without obstructing view, rather than mounting ontop of the already big screen.
2024 Toyota Tacoma Dash Mount | ICS FAB - CODE "TRDMORO" FOR 10% OFF SITEWIDE
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups DSC02279-Edit
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups DSC02052-Edit
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups DSC02263-Edit
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups DSC02058-Edit
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups DSC02055-Edit
k1m
Nathanial
usa
Victory4x4 sent a complete replacement dash mount with some modifications to the brackets and the mounting holes on the dash mount. It dropped right in, no fighting, no questionable attachments, no issues. The new brackets have a L and a R engraved into them. The originals took some finagling before i found the right configuration placement for the brackets.
Anyways, its beautiful and I am impressed with the customer service. I'll post pics once I get it all set up with the head unit installed.
One question though, anyone run wire down behind the 14 screen and how did you do it if you did? I could figure it out, but if someones already done it, why reinvent the wheel?
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
[QUOTE="k1m,]
[/QUOTE]
Glad they worked out. I pulled the radio to run wires. It was pretty easy.
MD, USA
4th Gen TRD Off Road Dbl Cab
I also have an IC 2730. It looks like you also ran the wiring for the radio behind the 14” screen. Just curious, where did you mount the body of the radio?
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
Under the passenger seat. Then I put a small remote speaker behind the dash. It works great.
gofastdan
Any word on a version for the 8" display?
Pappy
Albuquerque, NM
I like this idea. I ordered, and I'm waiting for it to ship.
Romer
Romer
Ken
Centennial, CO
Pappy
Albuquerque, NM
MD, USA
sweet. this is where I had it in my 3rd gen- easier now given that the battery is on the passenger side in the 4th gen. Thanks!!
MD, USA
One more question - I also have the ditch light brackets. In the pictures for the dash mount, it looks like you also have a (possibly NMO-mounted) antenna on the passenger side. Were you able to get a standard NMO mounting to the ditch light brackets? it is a little too small for my NMO mount. was there a particular antenna mount that fits well in the ditch lights?
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
If I remember correctly I used this mount and it fit without the oring on the bottom of the nut. You could probably find a 1/2 NMO for thicker steel, but I wanted to keep it all low profile. Don't forget you'll need to remove some powdercoat underneath the brackets for it to ground.
https://www.walcottradio.com/nmo-mo...l259-adapter-for-12in-hole-mounts-p-3456.html
MD, USA
