Rear Coil Recommendations for ~400# constant on TH bed
trailhunger
2024 TH
Anyone know offhand the product codes for ARB OME & Dobinson for the TH rear coil upgrades that are designed for ~400# constant on the bed?
I'm keeping the stock tire dims, only interested in eliminating some sag in the rear, it's not bad TBH, impressed at how well it's handled & distributed thus far. But once I have the gear slide built & installed probably gonna really want that upgraded rear spring kit.
Gracias Usted
2024 Tacoma Rear Coil Recommendations for ~400# constant on TH bed IMG_8807
trailhunger
trailhunger
2024 TH
Open Ai deep research yielded this. Anyone installed any of this equipment? Ride quality? Cheers
2024 Tacoma Rear Coil Recommendations for ~400# constant on TH bed IMG_9340
Pappy
Albuquerque, NM
I have more weight than you do. Lots more. I installed the 819V springs in the rear on Dobinson's recommendation, and they compensated for the weight, but I didn't get the lift I wanted. The 819V were pulled and I installed 821V and it's better, but still not where I want it. I think the weight recommendations from Dobinsons is optimistic. Here is what Dobinsons says about their rear springs:
Rear Coil Spring Specs:
  • C59-869V (30mm - 1.25") Stock Load / (Stock Height) 50-100lbs
  • C59-817V (55mm - 2.25") 50-100lb Load / (30mm - 1.25") 175-330lb Load
  • C59-819V (55mm - 2.25") 175- 330lb Load / (30mm - 1.25") 440-660lb Load
  • C59-821V (55mm - 2.25") 440-660lb Load / (30mm - 1.25") 880-1210lb Load
  • C59-823V (55mm - 2.25") 880-1210lb Load / (30mm - 1.25") 1400-1600lb Load
  • C59-825V (55mm - 2.25") 1400-1600lb Load / (30mm - 1.25") 1800-2000lb Load
My 819V are available if you want to chat.
Pic with the 819V. Camper-canopy: 450#. Rear bumper with dual swing-outs: 350#.
2024 Tacoma Rear Coil Recommendations for ~400# constant on TH bed 20250515_191928-sm
trailhunger
trailhunger
2024 TH
I have more weight than you do. Lots more. I installed the 819V springs in the rear on Dobinson's recommendation, and they compensated for the weight, but I didn't get the lift I wanted...
thanks for the info...
I like that Dirtbox setup, nice rig. Had I went w/a Tundra, the Dirtbox was my #1 preference.
Pappy
Albuquerque, NM
I looked at a lot of canopy-campers. The Dirtbox stood out, by a long shot. It's not perfect, but nothing was.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Gracias Usted
Dobson 819 rear coils i have them on my 24 Tacoma I'm not sure if they'll work with the trail hunter. I don't know why they wouldn't
2024 Tacoma Rear Coil Recommendations for ~400# constant on TH bed 20250523_145947
grizzlyoutlaw
MTN WEST
TACOMA
Beto
Robert
El Paso, TX
Toyota Tacoma Trailhunter
Hey Pappy... do you still have those coils available?
Pappy
Albuquerque, NM
Beto
Robert
El Paso, TX
What are you asking? I just got a bed rack and RTT for my Trailhunter, and could use a coil upgrade.
Pappy
Albuquerque, NM
Beto
Robert
El Paso, TX
Sold. I'll hit you with a DM.
