Trailhunter OEM Onboard Tire Inflator/Air Compressor Retrofit into Tacoma Offroad Premium DIY
cape_taco
truro ma
2025 tacoma offroad premium
Dumb question for you....I see in your video you used a green/yellow air hose. Does the one provided not reach all the tires?
The red hose reaches all wheels just fine but only fills one tire at a time. I already had a quad hose setup (morrflate quad) I was using with my old compressor that fills all the tires at the same time without having to go around and switch them from tire to tire. The morrflate is the green hoses and there's the additional yellow hose i got at the hardware store as an extension.
I'll probably end up only using the red hose to fill up the random tire on another car or beach balls or whatever else needs filling /airing down that isn't my truck where I usually want to do all four tires at once. The case it comes in is pretty snazzy though.
VBFD Taco
Virginia Beach, Virginia
Would love to do this mod for just the ease of doing it and it being OME. But for that price, I think my M12 Milwaukee tire inflator will suffice until that price drops some. ?
Nice write up, thanks.
ligershark
New Jersey
2025 Tacoma TRD Off Road
Does anyone know what the differences are between the following part numbers?
PT949-35240
PT949-35240-AA
PT949-35240-AB
There are noticeable differences on prices between sites so I am assuming some parts are missing from the -AA and -AB part numbers.
Thanks in advance.
Bravada
S.E. Texas
PT949-35240
PT949-35240-AA
PT949-35240-AB
Thanks in advance.
PT949-35240 should be the whole kit, the others are just parts of the full kit.
turnermier
oregon
25 trdor hybrid
looks awesome.. I definitely want it but my hybrid has absolutely nowhere to store that compressor kit lol.
VBFD Taco
Good to know.. I'm thinking of installing one but relocating the air compressor so it's not so noisy.
Where would you relocate for less noise? At the back of the bed where this thread shows the OEM location seems the quietest spot on the truck?
turnermier
oregon
25 trdor hybrid
Waiting for black friday 25% off parts to snag this :p.. guess for now ill just stick to the trusty milwaukee
cgdmnky
San Antonio, TX
24 Tacoma TRD OR
Out of curiosity because I'm leasing. Seems great for me as plug and play for the control unit. I will save my TRD OR 12v usb power panel to reinstall when lease is up. Could I just install the air compressor control unit then cut a hole on the blank space to the right (see mockup) of the unit and just have the air compressor silver hose hanging through the hole. I can then stow the actual air compressor inside my cab and then when I need to use it, I bring the air compressor into the bed and connect the silver hose to the compressor and red hose to the control unit? This way I don't have to cut through the bed?
Sounds confusing here is a bad pic (I should have made the green arrows point the opposite direction):
2024 Tacoma Trailhunter OEM Onboard Tire Inflator/Air Compressor Retrofit into Tacoma Offroad Premium DIY 1756484291505-hq
cape_taco
truro ma
it's not just the sliver hose, that's just for air up. there's also an electrical connector for power as well as a blue tube i assume is for air down.
i suppose you could try it but at that point i'd personally just use a portable setup. seems like the worst of both worlds (added complexity & cost, + you still have to lug around the compressor).
