Mild Rattle or Ticking Sound Drivers Side Interior.
MarineVet6113
2024 Toyota Tacoma TRD OR
This is the precise location. Hope this helps.
Yes thank you for the pics. That’s the exact area and it stopped with cloth so I’ll be looking for something to put there permanent. Glad I could sort that out.
Jabstep
Southern USA
TFL guys found a rattle with the tailgate cable. ?‍♂
Can you link the video? I’ve got a rattle on my pssangers side I’m trying to find. It’s only on the interstate or speeds of 50mph +
PaulT
Paul
SC
2024 Taco Sport 4WD
I cannot find it. But I remember...where the tailgate cable connects to the bed, there was some space for the cable to rattle. They put in some rubber of something to remove the space and the rattle was gone.
Taco Azul
MP
Portland
TFL was specifically hearing a bed rattle when someone would shut the passenger door.
Dansflhti
Nova Scotia
Both rear wheel well liners are loose on my long bed. One of the push pins on the top isnt engaging in the hole. I'll investigate more and pick up some bigger push pins.
xraided
Albert
San diego
I get a door rattle when I play music above 35 =(
Cabby30
CA
2024 DCLB TRD OR
I had this as well on my passenger side door.
Here was my working process:
1. I repeatably ran a low frequency sine sweep (via YouTube) in order to better locate the sound.
2. Once I determined the general location, I removed the door panel (also using a video from YouTube lol) & tightened all the fasteners in the area another ~quarter turn (these are self-threading into plastic so dont over-do it; I did notice that the were very low torque from the factory).
3. I also added additional electrical tape to cables in the area that looked like they could be loose or rattle.
4. Lastly, I added a foam shim between the door panel and the door body to eliminate the opportunity of the plastic bosses buzzing on the metal door (although this shouldn't occur if the fasteners are sufficiently torqued).
I'd say 95% of the buzzing went away although it pops up every now and then at a combination of volume & low frequency. Day to day though it is pretty much eliminated.
keonigt
Hawaii
2024 Toyota Tacoma
Have you found out what the sound is coming from?
I found that my seat/lumbar support is very noisy when I turn or lean forward and backward.
entropy
does it sound like this
I get this same exact sounding rattle in my TRD Pro whenever I accelerate. I'm sure its also happening over bumps but its very reproducible even just by accelerating. I haven't tried the solution posted in this thread yet though. Have you guys found any other causes/fixes?
tacomasport1121
Robert
2024 Tacoma Sport
I am getting the same rattle. Did anybody ever find a solution?
Muckle
I have about the same rattle. It happens primarily when accelerating/going up hills and seems to be coming from somewhere around the steering wheel. It is certainly in the area of where the driver sits and does not seem to be coming from the side pillars.
I am going back and forth between living with it and taking it into the dealership, where they could very likely make it worse by starting to pull stuff apart in an attempt to diagnose it.
GMak621
Røgue Valley
26 Tacoma TRD ØR Hybrid
I also have the exact same rattle as the video posted above. Very annoying. Still trying to locate it. Anyone else figure this out yet ?
It’s a loose fender liner clip. Not sure if this was already posted but it takes 10 seconds to find and fix.
GMak621
Røgue Valley
Front exterior driver side fender liner??
Interesting. … it sounds like it from inside the cab
Do you know the location or have a photo?
