Rough engine engagement
vprftw90
Mitchell
Tacoma TRD Pro
So I just picked up a 25 with the I-force max. I’ve noticed when accelerating from a stop, there’s a thud/clunk when the engine appears to kick on/engage. Almost like the engine is engaging the drivetrain.
it’s heard/felt in the rear.
New to anything hybrid so wondering if this is “normal” for a hybrid set up?
thanks in advance!
Bravada
S.E. Texas
That does not sound normal. Perhaps go take a test drive at another dealer to compare? Assuming its not normal, you'll know how much of a fight to give the service department.
vprftw90
vprftw90
Mitchell
Tacoma TRD Pro
Appreciate it! Will go drive another this weekend.
Compherh
Sam
Miami
2025 tacoma limited hybrid
thanks in advance!
I have a 25 Limited hybrid. There is a noticeable engine engagement, but not a clunk. If I'm driving in traffic, I'll put it in tow haul mode so it doesn't turn off the engine. Also after a long highway drive, before getting off the highway, I'll put it in tow haul so the engine doesn't turn off at the first traffic light and the turbo is still hot.
Ron
Samsara
Mine has never clunked - but i test drove one that had rough shifting.
Pushing the shifter to the left (sport mode) seems to do that as well.
If you are in normal and "d", then it should be super smooth other than an extremely mild sensation of the ice motor starting up that matches perfectly with the tach jumping from zero to about 1k rpm, then climbing. Anything else needs to be looked at by the dealership
vprftw90
vprftw90
Mitchell
Tacoma TRD Pro
This is probably a better description of what im noticing. You can hear/feel the ICE kicking in and grabbing the drivetrain.
jboss
Jonathan
Magnolia, Tx
2025 Tacoma TRD-Pro
Curious if this is simply the engine engaging from battery power when at a stop. There is a second or so delay and you can hear/feel the gasoline engine kick in.
Bravada
S.E. Texas
There still shouldn't be a thud/clunk when the ICE is applied. The transition on mine is smooth, seamless.
crepr12
NEast
2025 Limited Hybrid
Mine is not smooth/seemless...but it does not bother me either
vprftw90
vprftw90
Mitchell
Tacoma TRD Pro
Can you “feel” or hear anything when it kicks in?
Bravada
S.E. Texas
With the aftermarket exhaust, and intake, I absolutely hear the ICE fire up. On the feel, I'm an aggressive driver, so I send it, and give it the beans. With aggressive launches I would expect if I was susceptible to a clunk/thud I would observe it then, and I don't. That said TFLTruck just posted a video that concerns me with your symptoms.
AZTaco
AZ
2025 Tacoma TRD Pro
No clunk on mine, absolutely seamless transition. Get it checked out, there should be no clunking.
Taco Ji
New Jersey
2025 Toyota Tacoma
I think everyone’s sensitivity is different. I can certainly feel a slight vibration when switching from electric to gas motor. There is no clunk or thud but it’s a noticeable slight vibration.
Everyone that says it’s seamless are you saying you can’t tell if it’s in ice or electric except by hearing the engine turn on? There is absolutely no vibration felt when switching?
Bravada
S.E. Texas
Yes, I don't detect any vibration. Perhaps because I have full time 4WD? 🤷‍♂️
