Cabby30
CA
2024 DCLB TRD OR
Hi All,
Firstly, I've had rodents attempting to live in my truck, specifically the cabin air filter, a few times already and this results in rodent food (acorns), poops, and their nests living on top of the filter, and subsequently falling into the HVAC fan motor when replacing said filter. This results in you needing to remove the motor, which is easy (three 8mm bolts), but annoying nonetheless. So I decided to make a screen inspired from the 3rd generation taco forums.
Rodent screen installation write up:
  1. Remove the wipers, 14mm nut on both. They weren't that tight but the wipers are clocked on a tapered, splined shaft. I used a little wiggle and a few taps from a plastic head hammer to get them to pop off.
    2024 Tacoma Rodent Screen Installation DIY IMG_8868
  2. The cowl cover has two plastic rivets on each end that you can use a flat head to pop up the center and then remove. The plastic corners of the windshield also clip into the cowl cover and simply pull up and out with a wiggle.
    2024 Tacoma Rodent Screen Installation DIY IMG_8872 2
    2024 Tacoma Rodent Screen Installation DIY IMG_8873
    (Once unclipped, I left these loosely in place)
  3. The cowl cover itself pulls out straight towards the front of the truck. In order to make this happen, there are clips on the engine bay side that need to be pulled up & disengaged vertically before it'll come forward. Unfortunately, I did not take picture of this since I was wiggling and pulling on it, however it is fairly robust. Start at each end and wiggle it loose. Once you have each end disengaged, and the center clips pulled up vertically; pull the whole thing forward (towards the front of the truck) and it should come out.
  4. Remove the windshield wiper heater cable, it's clipped in, you simply squeeze the clips on the bottom-side, under the sheet metal, to pop them out. I then made a cardboard template and also procured some gutter guard ($4) from Home Depot.
    2024 Tacoma Rodent Screen Installation DIY IMG_8875
    (mice chewed my defroster cable)
    2024 Tacoma Rodent Screen Installation DIY IMG_8883
    2024 Tacoma Rodent Screen Installation DIY Screenshot 2026-01-12 at 6.16.00 PM
  5. I used my template to help size up the gutter guard and get the angles right. I used tin snips to get it to size and then added relief cuts in order to bend the ends and match the angle along the firewall. All the pre-bending utilized the edge of my work bench and a hammer.
    2024 Tacoma Rodent Screen Installation DIY IMG_8882
    Note: I kept most of the top, angled portion in order to be able to use 2 holes along the firewall for zip ties.
  6. Once I got it to approximate size, I put it on the HVAC intake and bent (used ball peen hammer, my hands, etc.) the remaining edges until snug around the flange. I double zip tied everything and that's that. Note there are also two holes on the upper firewall side that you can also thread zip ties thru in order to secure the rear, once again using the angled bit of mesh (kind of) shown above.
    2024 Tacoma Rodent Screen Installation DIY IMG_8890
    2024 Tacoma Rodent Screen Installation DIY IMG_8884
  7. To wrap up, I plugged the windshield wiper heater cable back in (Mine had been chewed thru ((image in step 4)) so I spliced them back together). I zip tied the cable to the new grate just along the front edge. The cowl cover is a pain to put back in. There is the rubber portion that seals on the windshield and a secondary plastic "shelf". That secondary plastic shelf has to go below the sheet metal on the firewall and inserted straight back in. Once that happens you can push the rubber seal up against the glass. There are also a few tabs that also go under the glass to keep the seal tight against the glass surface. Once again, no pictures of this because I ran out of hands. You'll get it. Be patient and don't force it. Once seated, pop all the vertical clips back in on the cowl cover. Reinsert your plastic rivets on the corners and pop the clips for the windshield corners in as well.
  8. For the wipers, you'll be able to see on the windshield where the defrosters are. Align the wiper center to the defroster lines center and then thread the nut by hand. This should hold it in place until you snug it down with your wrench. I don't have the torque spec but I did "good n tight" with a normal 14mm wrench. BTW, add some anti-seize to the splines if you have it.
    Thanks for reading. Let me know if you have any questions.
Dayen
Daniel
North Kingstown RI
2024 Tacoma SR 6MT, 1985 BMW 316 5MT, 2004 BMW 325i 5MT (sold)
Thank you for the guide, I will do this soon!
I have already replace the cabin air filter twice and am currently running without one...
Cabby30
Cabby30
CA
2024 DCLB TRD OR
I use these ones. They work and are much cheaper than OEM, especially since I was having to replace them often due to rodents.
2024 Tacoma Rodent Screen Installation DIY Screenshot 2026-01-12 at 6.57.55 PM
MJB4450
2025 SR5
No thanks. Made in China. No standards. So you don't know what they're really made from or what kind of particles you're breathing in from them. I still remember all the homes that had to have contaminated Chinese drywall removed and all the dead pets from contaminated Chinese pet food and on and on. I'm very selective when it comes to products from China.
LincolnSixAlpha
Phoenix
I had a rodent destroy some expensive electronics in a BMW I owned years ago. I only drove the car in the summer, and during the winter parked in a garage. Luckily the dealer fixed it for me under warranty. Was a month long fix since they ate some fiber optic cables to some kind of router/distribution system.
I've been doing this for 5 years or so now. Haven't had any further rodent issues.
https://www.amazon.com/dp/B07LCKBGY8
2024 Tacoma Rodent Screen Installation DIY 1768275693395-vu
TacoEd
Ed
Denver
2024 Tacoma TRD Pro Hybrid I-Max
Hat off to you! I like the clear photos and detail in your description. Thanks for sharing!
MalloryKawa
Toronto
2025 Toyota Tacoma SR5
Hi All,
Firstly, I've had rodents attempting to live in my truck, specifically the cabin air filter, a few times already and this results in rodent food (acorns), poops, and their nests living on top of the filter and subsequently falling into the HVAC fan motor when replacing said filter. This results in you needing to remove the motor which is easy (three 8mm bolts), but annoying nonetheless. So I decided to make a screen inspired from the 3rd generation taco forums.
  1. Remove the wipers, 14mm nut on both. They weren't that tight but the wipers are clocked on a tapered, splined shaft. I used a little wiggle and a few taps from a plastic hammer to get them to pop off.
  2. The cowl cover has two plastic rivets that you can use a flat head to pop up the center and then remove. The plastic corners of the windshield also clip into the cowl cover and simply pull up and out with a wiggle.
  3. The cowl cover itself pulls out straight towards the front of the truck. In order to make this happen there are clips on the engine bay side that need to be pulled up & disengaged vertically before it'll come forward. Unfortunately I did not take picture of this since I was wiggling and pulling on it but it is fairly robust. Start at each and wiggle it loose. Once you have each end disengaged, pull the whole thing forward (towards the front of the truck) and it should come out.
  4. Remove the windshield wiper heater cable, it's clipped in, you simply squeeze the clips on the bottom side to pop them out. I then made a cardboard template and also procured some gutter guard ($4) from Home Depot.
  5. I used my template to help size up the gutter guard and get the angles right. I used tin snips to get it to size and then added relief cuts in order to bend the ends and match the angle along the firewall. All the bending utilized the edge of my work bench and a hammer.
    Note: I kept most of the angled portion in order to be able to use 2 holes along the firewall for zip ties.
  6. Once I got it to approximate size, I put it on the HVAC intake and bent (used ball peen hammer, my hands, etc.) the remaining edges until snug around the flange. I double zip tied everything and that's that. Note there are also two holes on the upper firewall side that you can also thread zip ties thru in order to secure the rear.
  7. To wrap up, I plugged the windshield wiper heater cable back in (Mine had been chewed thru ((image in step 4)) so I spliced them back together). I zip tied the cable to the new grate just along the front edge. The cowl cover is a pain to put back in. There is the rubber portion that seals on the windshield and a secondary plastic "shelf". That secondary plastic shelf has to go below the sheet metal on the firewall and inserted straight back in. Once that happens you can push the rubber seal up against the glass. There are a few tabs that also go under the glass to keep the seal tight against the glass surface. Once again no pictures of this because I ran out of hands. You'll get it. Be patient and don't force it. Pop all the clips back in on the cowl cover. Reinsert your plastic rivets on the corners and pop the clips for the windshield corners in as well.
  8. For the wipers you'll be able to see on the windshield where the defrosters are. Align the wiper center to the defroster lines center and then thread the nut by hand. This should hold it in place until you snug it down with your wrench. I don't have the torque spec but I did "good n tight" with a normal 14mm wrench. BTW, add some anti-seize to the splines if you have it.
Thanks a lot. That is exactly the information I was hoping to get. Thanks again.
franx
Frank
Lehigh Valley, PA
2025 Tacoma Limited Hybrid
I never had any success with any ultrasonic devices to deter mice. Now I have all my cars in garages so not a problem. Glad to hear this is working for you at least.
holland1
ct
tacoma
Why isn't this done from the factory, this has been an issue since the first gen. Should be standard but I'd be willing to pay for that than most of the forced options.
Gaspe
Tim
Vermont
2026 TRD OR Tacoma (Bronze); Sprinter 4x4; Subi Outback/Wilderness; Mustang '66
I often park my vehicles in an open, mowed field. Mice have always gotten into their cabin and engine air filters. With my Tundra I finally blocked the opening with stainless steel screening…… that has been successful so far……
