taco.b0ut.it
Austin, TX
2024 Off-Road Long Bed
After 2 years of ownership and 30k miles finally bit the bullet and did a suspension overhaul. I was running Peak 2 piece front collar kit before all of this.
Icon UCAs
King Sway Bar Links
Dr KDSS Track Bar Correction
Perry Bump Stops
Bilstein Suspension 6112 and 6100
Dobinsons Rear Springs C59-817V
Tundra TRD Pro Wheels
Falken Wildpeak AT4W 35/11.5/18
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul 48294-a90816f666a4ecbf3db43465191bb738
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul 48295-a60d9e9e55d868d896b8a49c75882bc7
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul 48296-749a9e95f61d7c91efd4131cfbfc005f
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul IMG_0805
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul IMG_0806
2024 Tacoma Bilstein 6112/6100 Install + Suspension Overhaul IMG_0807
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
Looks good! What rock rails/running boards are those?
TacoBirdinNW
2025 DCLB SR5
Looks so good ! I bet it rides awesome.
You probably know this, but if not: if those end links start squeaking get yourself some graphite lube. And if they start mad creaking the replacement bearing is a Com10.
taco.b0ut.it
taco.b0ut.it
Austin, TX
Thank you! My mechanic mentioned something about this but I totally zoned out.
bronzilla
chris
colorado
2025 Tacoma Off-Road
Looks great! I’m looking to upgrade to the 6112’s in the next few months. What’s your initial impressions on these vs stock. How’s the ride feel on-road/off-road? Anything come up that you’re were or weren’t expecting?
taco.b0ut.it
taco.b0ut.it
Austin, TX
Thank you! Compared to OEM off-road way better. Nothing unexpected, beefier, less dips, more control, height is nice too. Haven't gotten the chance to take it off roading but based on how it feels so far probably an upgrade. Now I will say I think the price is exactly where it should be. I did alot of research on how the 6112's were for the previous gen Taco and Tundra. If these were any more expensive though I would definitely question it.
Rmarin4272
Nice work man! I almost pulled the trigger on those but didn't want to wait for them to be available and wanted something to handle more weight so I ended up with the OME MT64s.
With the trackbar relocation bracket, which I'm considering, why did you go with the higher hole? From what I could see, unless you were 3"or more in the rear you only need the lower hole?
taco.b0ut.it
taco.b0ut.it
Austin, TX
Nice! OME was a consideration as well.
I was definitely 3 inches higher in the rear. Drives well now. I actually had the rear springs installed first without anything else and the rear would hop it felt like.
