12v battery (hybrid) runs low after sitting for a week
MustardTiger
TacoMAX/Tundra/SDuty/Dmax
My truck does quite a bit of sitting in the garage, as I'm away for longer periods of time. I've been monitoring the state of the 12v battery...and after returning a week later, I unlock truck and open hood...let things settle for 15 mins...and battery shows 12.0v. I feel it should be at least 12.5-12.6 (like 80-85% charge). Before driving it, I connect a 7.5 amp NOCO charger and let it complete a charge cycle. The truck has never not started for me however.
A couple things to note:
-my truck was delivered in the dead cold of winter, it was like -30c temps. The day I went to purchase, it was out on the lot, -35c...they just started it...immediately backed up through a snow bank and into the shop.
-it had been sitting on the dealer lot for about 1 month (in said cold temps) before I seen it and purchased
-after getting it home, I noticed the little red flip cover on the boosting terminal was broken at the hinge...and it was obvious booster cables had been attached at some point, maybe during transport? hard to say
Maybe...my battery was in a very low state of charge for an extended period, in freezing temps, prior to me buying it, and it either froze or lost a significant amount of life/amps
Anyone else have a 12v issue like this? Particularly the drain after sitting for more than 5 days?
Lennyz1
Len
NY
2024 Tacoma TRD Sport Hybrid Bronze Oxide
You battery is an AGM. Charge should be 12.7 minimum at rest which is approx 12 hours since last charged. Typically 12.4 VDC or lower and it should be considered for replacement. If it is at 12.0, then it probably was at one point heavily discharged and damaged. I recommend having dealer test battery
MustardTiger
MustardTiger
Charged the battery yesterday, then drove the truck for an hour...come home, left it in the garage with the hood up and doors locked. 12 hours later...battery shows 12.4v. Ugh...looks like i need to take it to the dealer, hopefully they replace the battery. I'm doubtful
max911
max
AB Canada
I just dropped my truck off at the dealer for a similar issue. Getting tired of having to pull out my booster pack every morning, or every time i have the tailgate down and doors open for ten minutes.
Will let you guys know how it goes.
AZTaco
AZ
2025 Tacoma TRD Pro
Out of curiosity, do you have a '24 or '25 hybrid? They added the alternator to '25 hybrids but only if you have the 4th Aux switch. The theory is that the alternator is needed if you are running all four aux switches at once.
I find it hard to believe that, after one year, Toyota received so much feedback for the need for a fourth aux switch that they went to the effort to add an alternator to make the switch work.
But if it were to solve a battery charging issue, why wouldn't all of the hybrids get the alternator?
FYI, the first Pro I ever saw (2024) was on the side of the road with the dealer. I stopped to look at it and 1. They were trying to jump start it directly from the battery by removing the rear seat, and 2. They said the battery died because it was just trucked in from Mexico (BS because Hybrids are shipped to the US and at most it was trucked from a port in CA to AZ).
MustardTiger
MustardTiger
@AZTaco mine is a late model production 2024…I purchased it in early February 2025, and I think it was delivered to the dealer around mid January. I do have the aux switches (3), no alternator. I’ve been watching the volt meter gauge in the cluster as I’m driving…it doesn’t seem to apply a charging voltage (14+) all that often. Idk…the truck has always started…but I have been topping up the batter now and then with a charger
My truck has always started just fine, but reading this inspired me to check the battery level. Checking it at the jump point in the fuse box it reads 11.89 VDC right now, which seems like a problem to me. I might put it on a maintainer for a while and see what happens and then talk to my dealer.
I don't think Toyota would have added the alternator just to get another AUX, I think the design is screwed up and all hybrids should have an alternator, not just trucks with 4 AUX switches.
max911
max
AB Canada
Picked up the truck. New battery installed on warranty.
(monitor recall performed as well)
Old battery was tested and would not accept/hold a charge properly.
I noticed on the drive home that the volt meter stayed at the mid point- 14v. Whereas before it would drop down to 12v after five or ten minutes of driving.
MustardTiger, I too picked up my truck from the selling dealer during a cold snap in December. -30ÂşC.
When new i found one of the push pin fasteners in the console and couldn't figure out where it came from. When accessing the battery under the seat I noticed one fastener missing. Guessing the dealer lifted the back seat to boost the battery. They might not have known about the +post in the fuse box under the hood for boosting as I think this was one of the first Hybrids that they sold.
Points to the possibility that the flat battery was damaged somewhat by the extreme cold.
Now I have to go through the procedure of shutting off some of the nannies that have been reset by default. No biggie. Happy i didn't have to shell out for a new battery myself.
MustardTiger
MustardTiger
This doesn’t look like an AGM battery…
@max911 great news, glad it was no hassle for you to get it replaced! I’ll be leaving my truck sit for a good 2 weeks. May as well leave it as-is without a trickle charger attached…and if it doesn’t start when I get back, then a new battery will be indisputable
MustardTiger
MustardTiger
I also think there’s more to the story with alternator addition. I wonder if the Grand Highlander MAX is experiencing a similar issue, and if it has an alternator or had one added too
MustardTiger
MustardTiger
Hmmm…interesting results.
also…I would guess my selling dealer had already replaced the battery…as this one isn’t a factory one. It’s a Toyota (Canada) parts counter battery
Lennyz1
Len
NY
Could be different in Canada. AGM in my 24.
I believe this is the Toyota battery for hybrid.
This is the battery that is in my LTD HV straight from factory (the vehicle was less than 2mo from factory build to my hands and 5w of that was Toyota transport from factory to dealership).
@Lennyz1 My battery has never read at the levels you posted. I returned about an hour ago from a 30 mile freeway drive and it now reads 12.22 VDC. My last reading was 11.89 V after it sat for two days. I suppose it might be my meter, but the readings I get from it make sense when I use it for other things. It still starts fine but I guess I need to find the time to take it to my dealer and see what they say. I have not opened up the back seat to see if it is an AGM or not.
gpburdell
GA
3G Tacoma
Out of curiosity, do have a '24 or '25 hybrid? They added the alternator to '25 hybrids but only if you have the 4th Aux switch. The theory is that the alternator is needed if you are running all four aux switches at once.
Adding an alternator won't have any benefit unless you're drawing more power than the hybrid motor/generator can supply.
Also given other threads it's not clear that all 2025's are getting the alternator.
12.2VDC after a 30 minute drive is a bad battery (or bad charging system) regardless of AGM or lead-acid. Given the amount of self-discharge in two days it's likely the battery unless there's some significant parasitic draw.
