Trying out 5w-30 engine oil
gmalkmus
SW Missouri
First off: yes, I know that the user manual says to use 0W-20. You don't need to tell me. I know. I get it. Toyota recommends US customers use 0W-20. Yep. I know.
I've owned 4 cars that call for 0W-20 oil from the factory - my 2015 Mustang GT, 2019 Civic Si, 2024 Honda Ridgeline, and now this 2025 Tacoma TRD Offroad. The Mustang is now running 5W-50 and I used 5W-30 on the Civic, Ridgeline, and now the Tacoma. On the Civic and the Ridgeline, I noticed that the engines ran MUCH quieter and smoother with the 5W-30 oil. I got 60,000 trouble-free miles out of the Civic running 5W-30 and noticed that it helped a lot with the oil dilution issues those 1.5T engines are known for. I run the Mustang hard and the heavier oil runs great (actually recommended by Ford for track duty, or in my case, heavily modified street duty).
I changed my oil on the Tacoma at 500 miles, 1500 miles, 5000 miles, and 10,000 miles, all with 0W-20 oil. Every time I changed the oil, it came out watery, black, and smelled faintly of gasoline. I've always noticed that the engine just sounds ROUGH all the time, clattering away even at low loads. I heard this was just injector noise but it sounded bad for sure. Seeing that Toyota specs this engine to run on 5W-30 in Mexico, I figured it would be safe to run in mine as well.
Immediately noticed a difference in how the engine runs. It is much quieter - at least a 50% reduction in clattering noises. The engine also feels much smoother -definitely will be sticking with 5W-30 for the life of the truck.
AGAIN. I KNOW TOYOTA USA DOES NOT SPEC THIS OIL. YOU DON"T NEED TO TELL ME.
SKYRNCHEXP
MIKE
KNEEVADA
2024 TACOMA SPORT
I ran 5-30 mobil one all summer without issue. About 8k miles in 105-115 degree temps.
I went to 5-20 as it is now getting cooler and i still had some stock of it. But i may just switch to 5-30 after its gone. It may just be me but i feel i lost a little mpg going to 5-30 but it may have been summer and driving habits
395North
TRD PreRunner
CA
2025 TRD PreRunner
I live in Socal, OC. Lowest it ever gets is about 30F and highest about 103F. 5W30 will be just fine.
I don't care about MPG.
Lando
I want to switch to 5w20 but don’t want an issue with my warranty so I was gonna switch after. I’ve had my truck for 2 years and 1 month and just had its last covered in the maintenance package oil change.
IDontWorkForTheWaterCo
2026 Tacoma SR
Totally unrelated to the T24 engine, but I've been running 5w30 in our 0w20 spec'd 2ZR powered Corolla since the 1000 mile mark. It has nearly 80k on it now. Runs flawlessly.
2024 Tacoma Trying out 5w-30 engine oil 20260815_110832
I wouldn't hesitate to run 5w30 in my Tacoma. But I have a decent sized stash of 0w20 at the moment. I'm also waiting on Lake Speed's conclusions with his Tacoma. If there's any measurable benefit, I'm in.
I ran 5w30 in my 2GR 3rd gen.
2026 Tacoma SR
They list 0w20 as a recommendation only. I can't find anywhere in the manual where it says using something other than that will void the warranty. I would think it would be in bold print somewhere if it were that critical.
But I totally understand you being cautious about it.
gmalkmus
gmalkmus
SW Missouri
For winter folks - Redline makes a 0w-30. Im gonna drop that in prob beginning of Nov.
5w-30 is good down to like -25 F. Unless you’re up in Alaska or something, you would be better off with 5w-30.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
It might be good, but in previous vehicles there is a noticeable difference during early morning startups with a 5w-30 on a typical NM winter morning.
gmalkmus
gmalkmus
SW Missouri
I’m in SW MO and will be using this all through winter. We routinely get temperatures down to 0 degrees, sometime less. You should be totally fine in New Mexico, thats warm.
2026 Tacoma SR
Not really much difference in cold temperature start-ups as 5w20 and 5w30 both have a 5w winter rating and will have similar cold flow/pump-ability characteristics. Personally, if I'm moving to a 5w it might as well be a 30. But if you have 5w20 sitting around I don't blame you for using that up.
