AllDogs Lift - Anyone have one?
Romer
Ken
Centennial, CO
https://www.alldogsoffroad.com/alld...hT4RkP5k8ESZNzG-QfZRaVNrPBK7dNgIaAsJPEALw_wcB
I am looking for a small lift on my OffRoad, for clearance and also to offset any droop from front and rear bumpers. My Land Cruiser is my main wheeling rig, but that doesn't mean I shouldn't set this up well.
I like what I saw as it uses the existing shocks and doesn't seem to require swapping control arms or a diff drop. It is an inexpensive solution to get me exactly waht I am looking for. I don't want to go the spacer rout, at least on the front.
Looking for feedback from anyone who has tried one
  • Any comments on the difference in ride from stock springs
  • Did you install it yourself? I have spring compressors I used on an older LC, wanted to know what you did there and if you had to get a bigger torque wrench. Back looks easy, front a bit more complicated so any comments would be appreciated.
  • Did you have a shop install it? What was the cost
  • Any comments on CV angle after install?
  • What lift did you end up with front and rear? It says 1.5" front, but his video said 1" was the result.
Curious if someone researched the stock shock to see what the extended travel was and how much margin was there over stock and with theese springs
I see Dobsons also has springs, but months to get. Can't really tell if there is a difference in the two.
Any other comments?
Ready to make the purchase, just want to get a perspective from anyone who has installed them
Thanks in Advance
mikeymtbs
Atlanta, GA
24 TRD Offroad Premium
I have the All Dogs lift but have only installed the front so far. Truck is 38-1/4” from the floor to bottom of fender. A Westcott preload collar was in the truck before, installed by the prior owner, so not sure what the actual lift would be from stock. I’ve also got 285/70-17 tires. The Westcott collar also put the front of the truck at 38”.
I still have the Westcott collars on the rear and haven’t yet installed the ADO springs. I can’t compare the front ride to stock as I didn’t have the truck then, but as compared to stock with the Westcott collar, it is a fantastic ride. No mure clunking and overly firm feeling front suspension. It’s a very, very good ride.
As for install, it’s the same as any other strut/spring install. Remove the coil over from the truck, compress springs, loosen top nut, decompress springs, swap springs and reverse. Removal of the coil over and reinstall was as easy as I’ve ever done before, literally 15 min per side to remove and maybe 20 min per side to reinstall.
I don’t have a pic of how the truck sits but will snap one and post it up. FWIW, Chad and the guys over at ADO are great to work with.
2024 Tacoma AllDogs Lift - Anyone have one? IMG_0742
2024 Tacoma AllDogs Lift - Anyone have one? IMG_0743
Romer
Romer
Ken
Centennial, CO
Thanks for your response Mike
What spring compressors did you use? have old style compressors I used on springs for solid axle vehicles (non strut) they were always a bit flakey. Thinking of getting this. I like the bar thaat goes across holding the two clamps together. Interested in what you used
2024 Tacoma AllDogs Lift - Anyone have one? 1741654921514-o
I
mikeymtbs
Atlanta, GA
That looks like a solid option; however, all of those units can be dangerous. I’d be sure to lay a moving blanket across the spring while compressing.
I’ve got a neighbor that does a bunch of Yota work, TORX Off-road - you can find him in the SE forum on the TW forum, and he has a commercial grade, wall mount spring compressor like the one below. It was definitely safer but still sketchy. I’ve used the parts store rentals plenty of times with no problem, but I’m always nervous as hell doing it.
The other option is to use the truck’s weight to release spring tension. I’ve don’t that before as well and it works good. Leave the lower shock bolt in place and the 4 top hat nuts. Place a jack under the lower knuckle for support, remove the two lower knuckle bolts and slowly release the jack releasing spring tension. YouTube has some good videos on how to.
Good luck!
2024 Tacoma AllDogs Lift - Anyone have one? IMG_0800
mikeymtbs
Atlanta, GA
Here you go… Alldogs springs in the front, OE springs with the Westcott collar in the rear, which gives about .75” of lift. The rear ride is fine, the rake is about 1” taller in the rear.
The tires are 285/70-17 on Black Rhino Rivals, +25mm offset.
2024 Tacoma AllDogs Lift - Anyone have one? IMG_0801
Yotota
SW WA
24 TRD
I
I've used my old-style basic spring compressors on IFS Toyota suspension, and it's always a little risky. They take quite a bit of force to compress the 600-700 lb/in springs. But it's always worked for me.
Another option is a basic hydraulic press. Put the shaft of the shock down through the base plate, support everything well so it's square and stable top and bottom but with access to the top nut, and squish everything with the press.
Romer
Romer
Ken
Centennial, CO
Any more feedback on the ride from owners who have them?
mal363
Mark
Northeast OH/Western PA
2024 Tacoma DCSB OR
Any other comments?
Thanks in Advance
I installed the ADO Spacer Eraser kit. Four springs to replace the OEM springs.
Ride has improved (topper weighs ~350) overall. Prior to lift I would often hit bump stops in the rear over dips on pavement roads. Post lift I have not hit bump stops.
Installed myself using a Vevor spring compressor. It was much easier than the ones you rent from a hardware store. I used lift and jack (the jack helps with supporting the rear axle while changing rear springs.
Front driveline seems to be visually okay as far as angles go. I did take it to a shop for an alignment after, and they said it was needed. I am comparing it to past Bilstein lifts installed on 2nd gen taco and 2nd gen tundra, which has noticeable change in drive (also were higher lifts ~3”).
Wheel hub to fender measurements.
Prior to lift: front 20.5” rear 21”
Post lift: front 22.5” rear 23.5”
Tires are 285/75r17, and have not noticed rubbing yet on pavement. Have not had it on trails post lift to check rubbing with articulation.
2024 Tacoma AllDogs Lift - Anyone have one? IMG_2833
2024 Tacoma AllDogs Lift - Anyone have one? IMG_3475
Romer
Romer
Ken
Centennial, CO
Thanks for the great review
dapperdan
WI
2024 Tacoma off road
Thanks for this! I think it is just what I needed to know. I might not have quite as much weight out back with my Diamondback, but I do have skids and sliders. Seems this would also be good for when I do tow as well. Looks like it is time to pull the trigger!
muymal
Michael
Hawaii
2024 Tacoma TRD Offroad
Looks great! This is exactly what I'm trying to do. Did you have to remove the crash plates to fit the 34" tires in the front? Or any other mods to fit them?[/QUOTE]
Drifte
Colton
Iowa
24 Tacoma, 20 RAV4, 10 Tundra, 99 C5
I installed the Alldog springs for my OR.
I pull a small square drop camper at about 2klbs and the truck sags a bit. I am hoping this lift is enough that I can get around decently on fire access roads etc. And not bottom out the rear so easily. Still on OEM tires, but planning to go to a 255/80 17 and hopefully thats all the ground clearance I need (7' clearance parking garage everyday for work).
You can see the bump stops being used, and thats with zero off roading being done. That was the oem springs.
2024 Tacoma AllDogs Lift - Anyone have one? 20250901_140901
2024 Tacoma AllDogs Lift - Anyone have one? 20250903_181442
mal363
Mark
2024 Tacoma DCSB OR
[/QUOTE]
I did not. After installing the ADO springs, I have not had any rubbing.
muymal
Michael
Hawaii
[/QUOTE]
Thank you!
