Tacoyaki
Tacoma TRD Off-Road
In case anyone's interested, here's latest heigh measurements after installing Alldogs front springs (already had Dobinsons 821 rear springs) (wheel center to fender edge):
Front: ~21.5"
Rear: ~23.75"
There's some load in the truck (guessing ~850-900 lbs...fully loaded I'm closer to 1100 lbs). It's hard to tell if I'm at the center of the wheel and if my tape measure is actually vertical, so +/- 0.25".
So ~2.25" rake that will probably drop to 1.75-2" when fully loaded.
I also did the ECGS bushing and the Icon reinforcement top plate at the same time.
rybern
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
So far I’m liking the springs. No more hitting the bump stops. I’m also able to carry 600 pounds of salt without sagging now. First pic is just after install. Second is after it settled and bed empty. Third is with 500 pounds of salt.
Great info that helps me. Great looking truck. Do you have any photos with better lighting after the springs settled?
rijc99
Thanks, Toyota won’t make me a non hybrid Pro with under seat storage and regular front seats so I made my own.
This one in front of my house is after it settled. But I wanted the front a little higher so I put 0.9 inch Trailhunter spacer from Peak Suspension (next to building photo). Caveat, this did take it out of range for the offroad upper control arms so I had to get the TRD ones.
2024 Tacoma Alldogs Offroad Front Springs Installed! IMG_4593
2024 Tacoma Alldogs Offroad Front Springs Installed! IMG_5153
2024 Tacoma Alldogs Offroad Front Springs Installed! IMG_5154
rybern
Albertville, AL
Haha, Thanks. I wanted the non-hybrid for the same reasons. :) So the bottom two photos are with the extra .90" front spacer, right? I may get both front and rear coils and cut a little of the coil off the rear if it's too high. The rear seems to be pretty easy to deal with.
rijc99
Haha, Thanks. I wanted the non-hybrid for the same reasons. :) So the bottom two photos are with the extra .90" front spacer, right? I may get front and rear but cut a little it of coil off the rear if it's too high. The rear seems to be pretty easy to deal with.
Yes I tried to get the same angle as the springs only photo but couldn’t quite figure it out so I just put both. When you do the rears make sure they transfer all the rubber pieces from the factory spring and loosen and retorque all the suspension links.
Chukwithak
Charlie
ID/CA
25 Undergound DC i-FM OR
@andrewleader Do you use stock shocks with the Dobinsons or did you upgrade? I'm currently running 500lbs in the rear, 700 when my RTT is on, but I'm also installing a C4 bumper, winch, and lightbar up front and having a hard time finding a spring that works with the stock shock. I plan on doing a full suspension in the next year, but need to get the truck to a point it's not sagging in the rear and can handle the bumper/winch up front. Debating ADO F/R but also looking at the icon rear. ANY input is appreciated. Total weight is 175lbs up front, 500lbs rear.
andrewleader
andrewleader
Andrew
Washington State
I’ve stuck with the stock TRD shocks (no changes from my original post).
I have 21,000 miles on the truck now, and just got back from off roading in Moab, including going to the Maze District and also Island in the Sky. The suspension is like 90% perfect for street driving, and 75% perfect for rock crawling… I still get a little more side-to-side sway when dropping off bigger obstacles, which I think upgrading the shocks would help with, but I’ll still wait till the stock shocks are older since I don’t off road too much and it’d be a waste of those new shocks.
Here’s my detailed weight info: https://tacotunesday.com/build/exterior/weights#weigh-in-records (I’ve got 180 lbs of additional weight in the front)
Here’s a short vid of the off roading:
Chukwithak
Charlie
ID/CA
Thanks for the info. I couldn't find any indication whether the Dobinson springs would work with the stock springs.
andrewleader
andrewleader
Andrew
Washington State
I think most ppl in the thread about Dobinsons rear springs also kept stock shocks! There’s some Dobinsons thread on here.
rybern
Albertville, AL
Thanks for the info and suggestions.
Chukwithak
Charlie
ID/CA
Sorry, can you confirm you have the C59-821V Springs! (55mm - 2.25") 440-660lb Load / (30mm - 1.25") with 880-1210lb Load doesn't line up with what you're getting for ride height, so I'm trying to make a decision on which springs. I also have a hybrid, which I know adds weight, so I'm really going through the numbers here.
andrewleader
andrewleader
Andrew
Washington State
My rear springs are Dobinsons C59-819V Coil Springs.
With the stock springs and the Tune M1 (500 lbs on CAT scale) plus ~250 lbs of my camper build, I was at ~850 lbs of constant load. That caused the truck to sit 2" below stock in the rear.
With my stock 5’ TRD Off Road Premium (no hybrid), after installing the 819V, it lifted it by 3", so that it was 1" above stock in the rear.
Here’s some ppl’s aggregated stats on the Dobinsons rear springs with various loads: https://www.tacoma4g.com/forum/thre...on-2024-trd-off-road-longbed.6902/post-109191
A Team Member
adam
Minneapolis
2025 Tacoma TRD Off road
Recently installed the Alldogs front springs with 3/4" pucks in the rear. Have Toyos at 285 70R17s here. Overall very happy, but the truck ended up a little to level for me. Measurements after 40 miles of driving actually had the front 1/2" higher then the rear which I did not expect, so I've ordered Alldogs Rear Springs as I want some rake back.
2024 Tacoma Alldogs Offroad Front Springs Installed! truck
rybern
Albertville, AL
Looks great. But I too prefer a little rake, mainly for when I'm hauling stuff. I also have a non hybrid and did front and rear ADO springs at once and am very happy. The rear is a little higher than I'd like and I still consider cutting 1/3 or 1/2 of a coil off the rear to drop it down a little. But I'm super please overall.
2024 Tacoma Alldogs Offroad Front Springs Installed! 20251206_155113
2024 Tacoma Alldogs Offroad Front Springs Installed! 20251206_155139
