Halifax, NS
2025 TRD Pro
Thank you for a great video.
I bought a cheaper Kill Switch and screwed it all up.
I would like to get this one, even a klutz like me could install it, BUT, there is a serious problem.
My Tacoma is the 24 Trailhunter with no alternator, and the battery is under the rear driver's side seat.
I would have to penetrate the firewall, and I think I read somewhere that there is a hole by the false pedal.
I will contact the company to see if their wire will reach back there.
Again, really nice of you to do this.
Did you skip my post entirely? lmao
trailhunger
2024 TH
I don’t understand this product. I mean I understand how it works and what it does. But why does anyone want to carry around a second remote when buying the wireless one.
here in Canada where vehicle theft is a big deal, what thief’s do is capture your keys RFID frequency and then they are able to start your truck. so what stops a thief from just capturing the signal from your OE key frequency and the one on this 41-22 unit. You can be sure the frequency on the 4122 will be less sophisticated than the OE frequencies allowing a thief to just capture it as well and reproduce it.
You do you. Maybe get a remote battery disconnect/ it’s the CAN BUS attack you’re more worried about. Remember tho if someone wants your shit bad enough they’ll tow it away at 3am. The cool thing about the wireless kill switch is no fking wires to trace, you could bury it in the vehicle in a hidden spot/ leave the backup there or have one fob in the house and simply carry the OE and if you’re parked out & about and want to use the kill switch, there’s one buried in a secret spot
2024 Tacoma 41.22 wireless kill switch install on Tacoma Hybrid IMG_4882
2024 Tacoma 41.22 wireless kill switch install on Tacoma Hybrid IMG_4883
Sner
Good point about only using it at times when parked in sketchy areas. what I’m going to do is have a TAG installed in mine. I don’t believe any of their claims. Anyway to each their own like you said. The TAG system makes sense and gives a discount of about $500 per year on insurance depending on provider in .canada. It’s $400 to install it, and the “tags” that are installed last 5 years.
trailhunger
2024 TH
There’s additional security that was dealer installed on my TH; I have a Rockledge Security system on board / opted not to pay the sub in it when I took delivery but it definitely works (found out months ago when I was attempting to the start the vehicle from digital key on the phone after multiple failed attempts), that hardware is imbedded.. aside from a kill switch I run a steering wheel to seatbelt lock only at night, I have an OBII lock on 24/7, 2 AirTags one in my gfc and another buried deep within a locked goose gear rear delete. So even if it gets towed & CAN BUS attacked / new starter solenoid the works… police can ping it, clock is fking ticking for these douche bags.
remove the battery when catching a flight out of town (super PITA for hybrids), can even get a motion sensor for that’ll ping you at night if it measures a bump or movement. And I disconnected my tailgate button on the driver console (can’t smash the glass and drop the tailgate).
That sucks that Canada seeing a lot of vehicle theft but that shit can happen anywhere at anytime to anybody
Sner
The thing with the TAG system is they guarantee recovery, so it takes the burden of the loss off the insurance company. in all honestly if my truck were to get stolen, just keep it, I wouldn’t want it back. I keep mine parked in a garage at night and at work it’s never out of my sight. Pretty pathetic this is what owning a new vehicle amounts to in modern times To be honest.
Tom Sellick
Ontario
2024 TRD Pro
I would imagine no system is absolutely full proof. I have a kill switch installed. My understanding is it uses rolling RF codes (changes every time) which would require specialized gear to capture and is not very common. It also doesn’t constantly broadcast like the Toyota fob. As a result, the thief would need to be physically near me (10-20ft) at the exact moment I press the lock button. This is my understanding anyway.
trailhunger
2024 TH
If you charge enough for an “anti-theft” or tracking device and you roll that into an insurance policy with your business trust you can guarantee anything as long as the underwriter says the math works. But when your truck gets loaded on a boat for Malaysia that’s shits not coming back and some insurer is in the hook to replace it. Doesn’t matter if you etch the glass, sprinkle it with holy water or slap security stickers all over it.
Sner
Yup, well said… but in the end yes it’s an inconvenience to lose a vehicle, but I don’t care where or who pays to have it replaced.
Tom Sellick
Ontario
2024 TRD Pro
A tow truck and it’s gone I guess 😂. Did forget to mention….discount on the insurance paid for the kill switch so maybe no further ahead but no further behind either.​
trailhunger
2024 TH
I gotta look into that, I asked about anti-theft devices on my policy they originally told me no impact (Progressive)
OttawaTaco
Rob
Ottawa
2025 Tacoma
Nobody has any info on putting a kill switch on these new trucks and with a hint from 41.22 reminding me fuse taps exist I got to work installing my kill switch, I’m super happy with the result, minus putting a wood screw through a piece of plastic trim.. but whatever
I tapped into the 10amp fuse for the S-Horn which is 12v constant, ran the ground to the bolt holding the front side of the fuse box down and I used the reverse relay out of the box (there’s two relays) it replaces the only purple relay in the fuse box, it's labelled ST for starter relay, I'm keeping the original relay in the truck just in case
I ran the excess wires into the fuse box and out through the side, the cover still fits without modification but its slightly cranky about it
all in all it could be a cleaner install but I can’t see it with the hood closed
how many pins were on the 41.22 relay that you installed? I had their kit on my 2025 4Runner gas and moved it over to my 2026 Tacoma hybrid today but can’t get it to start after I test the kill function (after pressing on on the key fob)
jsuber
juke
Jls297#40601
All of this is pretty cool, but if they want your truck they can use a wrecker to haul it away with a signal blocker onboard. Just saying. Tacoma is the most popular military vehicle without a military contract.
Halifax, NS
2025 TRD Pro
Are you using the reverse relay? Both only have 3 pins versus the 4 on the OEM relay. I press the on button a couple times out of habit and it seems to be working great
