hongerrr
2024 Tacoma Trail Hunter
Exactly. Here’s another one. If y’all air down at all or if you start your truck on a super cold day - one of the tires might freak out on the tire pressure screen and no matter how high the pressure goes afterwards it keeps telling you to adjust the pressure. It’s super cold in Houston this week and this happened - but it picks 1 tire at random and persists - I realize 28 is low but in a couple days it’ll be back to normal and it’s also not so low that it should trigger the warning (when it first triggered it was 26) also when it warms up it’ll still have the warning - I’m sure I can reset it but why does it do this? I think the last time it did this I had to inflate it with more air to get it to stop freaking out (allowing the temp to rise and naturally increase pressure doesn’t work)
I live in Houston also, and just went through the cold weather. I also run my display with a single large Tachometer in the middle. I have my tire pressure set on the right side of the main Tachometer in the smaller screen option and never had it reset on me. Try moving it, to see if this helps.
I have settings in the middle. How do I even do what you’re saying ?? Sent you a direct message. Maybe we can meet up.
hongerrr
This is how I have mine set up. Sorry, tire pressure was set on the left not right. You can adjust what you want to show on the left middle and right. Absolutely we can meet up, it would be cool to see a fellow trail hunter owner in the Houston area. I have not seen many.
Here is a YouTube video that’s is pretty informative about customizing your instrument cluster.
Wow - I did not even know you could do it that way - can you get turbo boost and electric motor on the same screen?
Goriders
2024 Tacoma Sport Plus
Update from my previous post: the bug is back and the tire display is again going back to trip B. It worked for 24 hours or so but now it’s back to being annoying.
Didn’t work for be either. It randomly stays. There’s no pattern.
Lennyz1
Len
NY
I have my tire pressure on page 3 right side. Been there since I set up my display 2 months ago. This is so weird that some hold setting and some do not. Mine was built 10/31. Not sure if date and possible factory loading different software??
bsquaredMTB
El Paso, TX
For what it's worth (yet another software developer here), I have a case with toyota customer support. After much back and forth, I finally convinced them it was an issue. There advice was to take it to the dealer so they can document the issue because there's no current fix being worked. When I spoke to the dealer, they asked me to take it in but they did mention no one has mentioned that this has been an issue (maybe that's true locally, but I thought that's odd). I'm going to take it in so they can document it, but I don't think it'll lead to a solution. Maybe if enough of us take the truck in they'll FINALLY address it. I agree it's a small fix (maybe easy, maybe not?) but we'll see where this goes. I don't have a lot of confidence it'll get updated.
For the tire pressure warning, I did find that there's a psi setting in the settings menu where you can set it to use "current PSI" as the mark for good/bad tire pressure. I set that up when I air down for off-roading and I don't get those annoying beeps. Then I go in and reset it when I air back up again.
frustrating they aren’t even working on it. Zero chance my dealer will do a thing and will claim repeatedly it’s normal — that said I’ll make noise with brand engagement and maybe the dealer
bsquaredMTB
El Paso, TX
Yeah, I had taken it to the service dept and the tech (was nice) but basically said he knows there's nothing they'll do so he didn't document anything. Now I have to take it again to get it documented. But yeah, very little confidence it gets addressed.
love toyota but cannot stand service depts or sales depts — zero fucks given to the customer
Lando
I don’t think all the trucks have this issue. My truck’s went off a couple times this winter, but in both cases went away on its own.
In one case I added some air and it was fine, in another I just let the temperature come up and it went away.
Worked normal in both cases. I keep my tire pressure at 32 psi. I think it went off at 28.
bsquaredMTB
El Paso, TX
I don't think you're talking about the same thing. You're talking about the PSI sensor going off if the tire is low. That (as far as I've seen) works just fine. What this thread is talking about is the actual display that shows the PSI of all 4 tires. That does not persist through vehicle restarts as described in this thread. Just want to make sure we're all clear on the intended topic of this thread.
stuckinsocal
24 TRD OR 6MT
This issue has bothered me enough that I've stopped lurking and created an account here. This isn't the first thread, but the latest. The dealer tried to remove all optional screens except for the TPMS one to try and get it to stick, but that wasn't acceptable to me (I wanted music and some other view for my 2 other dash pages). If someone is ok with that and wants to try it it is up to them. For now, following the thread, I've moved the TPMS screen from the right side to the left to see if it will stick.
It is so annoying because tire pressure is the one thing I check every time I drive
